HP Pavilion 24-r111ne bios rebuild
  • IDElectroRep
    • Dec 2020
    • 10
    Hi
    I need help with a corrupted bios. The pc doesn't power on with the original file. I downloaded new file from HP and the pc works but I get the "Manufacturer setup" display. I would really apreciate if someone could help with adding the missing data from the original to the new file. Thank you!
    SN: 8CC8240QTT
    post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
  • maniche
    • Jun 2020
    • 37
    • Kabylie
    try the one below​
    • maniche
      • Jun 2020
      • 37
      • Kabylie
      hi, try this one , pls give me feedback
      • hoaca388
        Badcaps
        • Jan 2022
        • 12437
        Originally posted by IDElectroRep
        Hi
        SN: 8CC8240QTT
        HP Pavilion All-in-One - 24-r111na
        Serial_8CC8240QTT
        Sku_4DW64EA#ABU
        Fearture byte_3E3K3N3Q4C4h6b7B7K7M7S7WaBapaqasaubCbhcbdUdpdqeWfPgfj6.ne
        BuildID_18WW1MOT602#SABU#DABU
        • IDElectroRep
          • Dec 2020
          • 10
          Thank you maniche, that worked!
          • maniche
            • Jun 2020
            • 37
            • Kabylie
            You are welcome
            • to5it0
              by to5it0
              10-24-2025, 01:35 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • maanee11
              Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
              by maanee11
              Hello Everyone,
              I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
              It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
              In the website, you can only see specs etc.
              I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
              11-08-2025, 04:08 AM
            • m1ch43lzm
              by m1ch43lzm
              Hi everyone
              09-06-2025, 05:47 PM
            • iZakre
              HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
              by iZakre
              Hello everybody!
              To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
              The thing is that I had installed TeamViewer and could log into the computer...
              02-19-2023, 02:27 PM
