ph-500atx 400w psu rebuild help
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: ph-500atx 400w psu rebuild help
    what resistor would be suitable?
    -brown black brown gold
    or
    -green brown black gold
    or
    -brown grey brown gold
    or would an ntc 5d-11 do it? thats a thermistor right?
      master hoarder
      • May 2008
      • 12175
      Depends on the speed you want. Try each resistor in series with the fan, and see which airflow you like the best.
      For most average PSU fans (rated 0.12~0.18A), you can get a decent range of different speeds with a resistor between 10 and 100 ohms, with 10 ohms making the fan run at almost full speed and 100 ohms at around half speed.
      The resistors you have are 100 ohms, 51 ohms, and 180 ohms.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Bookmark this: http://www.dannyg.com/examples/res2/resistor.htm This way you won't look like an idiot when talking about resistors.
        Btw, i wonder why you got banned again.
        A working TV? How boring!
        • c_hegge
          • Sep 2009
          • 5219
          He won't be able to answer that question, since he's banned permanently afik. I think it might have been in relation to that apology thread.
          • brethin
            • Dec 2008
            • 1907
            Christmas came early this year! Thanks Santa (Topcat)!
            • ledro
              Tuxedo InfinityBook Pro 14 Gen6 - bios request/rebuild
              by ledro
              Hello, I have a Tuxedo InfinityBook Pro 14 Gen6 model PHxTxX1 laptop, which starts but does not display an image.
              Can someone help me rebuild this bios? I posted the old bios and the official update from the manufacturer's website.
              MB : MBPPH4TUXA-1P11
              SN: 2106SN00887...
              10-10-2025, 03:58 AM
            • Waffle85
              Fujitsu Lifebook E756 vPro Bios Repair/Rebuild help
              by Waffle85
              I got a Fujitsu Siemens Lifebook E756 vPro with a corrupted Bios after flashing. Device wont start anymore, only Blackscreen.
              Dumped the Bios and attached it. Maybe someone can help me repair/rebuild the bios?
              Thanks in advance...
              11-24-2023, 12:26 PM
            • khalillll
              maxipower 400W Dead power supply repair
              by khalillll
              The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
              After checking, I replaced the UTC7606D IC to restore the 5VSB.
              I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
              Replaced it again with another UTC7606D.
              Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
              After checking again, I think the issue was with the UTC7520D IC.
              Replaced it with a WT7520.
              Result: PSU fully working again
              09-27-2025, 05:06 AM
            • mferna14
              Bin Files rebuild for HP Pavilion 17-cn1003ca
              by mferna14
              Hi, I am working on a hp 17-cn1003ca laptop., board # VLAD10-6050A3261101-MB-A01(A1).This laptop had gone to another repair shop & for no reason at all they just removed the BIOS chip (Chip missing). Checked the photo with identical board & no BIOS chip on mine & missing chip on these tracks. I downloaded the BIOS files from the Hp site for this model. The Model # is 17-cn1003ca & Serial # 5CG21832ZY. Can someone rebuild the Bin file for this Model & S.No. I have uploaded both, the 8MB & 16MB bin files, I think 16MB is required for this motherboard. Thanks in advance....
              09-12-2023, 09:18 PM
