Rexpower PL-400 rebuild
Re: Rexpower PL-400 rebuild
Oops, that was meant to be 10A from the 12v rail (well, 9.6A to be exact). I don't know where I got 5A from. All rails were loaded roughly equally. If I reduce the load on the 5v rail down to 5A, I can squeeze an extra 2.4A from the 12v, bit it's still too low for me. I want my labelled ratings.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Disable OPP. Disconnect pin 4 of the SG6105 from existing circuitry and connect to ground. Up the load 'til it blows. Fix it, then set OPP to 80-85% of the load you had when it blew. Done.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
OK. How do you reconfigure the OPP? Sorry, I'm still not as experienced at this as you and 370.I love putting bad caps and flat batteries in fire and watching them explode!!
sounds like you may not be able to... i bet the labeled rating was PEAK... go ahead and prove me wrong, but doesn't sound good.Oops, that was meant to be 10A from the 12v rail (well, 9.6A to be exact). I don't know where I got 5A from. All rails were loaded roughly equally. If I reduce the load on the 5v rail down to 5A, I can squeeze an extra 2.4A from the 12v, bit it's still too low for me. I want my labelled ratings.sigpic
(Insert witty quote here)Comment
Get the SG6105 datasheet, first. Page 1 and 2 give the pinouts and their functions, while page 11 shows a typical circuit for the OPP. My guess is you will have to lower the resistance of R3 in that circuit. Do this until you get the desired wattage (or until the PSU blows up - in which case you can just follow Th3_uN1Qu3's advice and set OPP to 80-85% before the PSU blew up).Originally posted by c_heggeOK. How do you reconfigure the OPP? Sorry, I'm still not as experienced at this as you and 370.
Personally, I wouldn't set OPP to more than 300W, though.
In any case, trace out the circuit first and see which resistor(s) in your PSU corresponds to R3 in the OPP circuit in the SG6105 datasheet. Perhaps it would be a good idea to post it here as well.Last edited by momaka; 12-09-2010, 09:27 PM.Comment
I'm having a bit of trouble tracing it out, but I have an idea. Since R3 just seems to go to ground on the datasheet, could you simply connect another resistor between pin 4 and ground?I love putting bad caps and flat batteries in fire and watching them explode!!
Well, the circuit may not be an exact copy of the one given in the datasheet, but it should be close. Just start at pin 4 on the SG6105 controller and trace back to the middle transformer.
If you want, you can also post a pic of the underside of the PSU for me to try and trace it.
Yes, but you still need to trace out the circuit and see what values the other resistors have so that you can get an idea of what resistor value to use.Comment
Sorry to dig this thread up, but I thought I'd give an update on how it's all going. I'm gonna just leave the OPP disabled and not load it past 400W or so. I now use it as my testing PSU and it works great. Hasn't killed any hardware or anything like that.I love putting bad caps and flat batteries in fire and watching them explode!!
So you did figure it out eh? Good job.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
I haven't actually load tested it since disabling the OPP, but it will do 400W in theory. The switchers were removed from a 400W Antec StupidPower, which can really do 400W, so they should be fine. The secondary is good for up to 30A on the 3.3 and 12v rails and 60A on the 5v, so that adds up to 759 Watts.I love putting bad caps and flat batteries in fire and watching them explode!!
"Should be" doesn't = "will be". With bipolar transistors, if the drive isn't enough, it doesn't matter how good the switchers are... they will still blow.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Need some help with this PL-400. I have a fried resistor, unable to find the color code or the right value for it. Can you help me with this? Here is the issue:Attached Filesif you find these attachements useful please consider making a small donation to the site
I'm not at home ATM, but I'll let you know ASAPI love putting bad caps and flat batteries in fire and watching them explode!!
It's a 1.5K +/-5% (Brown, Green, Red, Gold)I love putting bad caps and flat batteries in fire and watching them explode!!
by emil_tHello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....04-12-2024, 06:54 AM
by b-slayerHi everyone,
I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
(as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
(so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,... -
by JayPoorJayGood Afternoon, Good People.
I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
I REALLY would appreciate y'alls help.
This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold... -
by amansr12Hi, I recently open my Asus rog strix g1513 laptop to clean the fans and while disconnecting the battery there was a spark near the connector (c6000) and a capacitor (C60050 ) and the keyboard , fans stopped working and the laptop only works when charger plugged in, otherwise no. I removed the burned capacitor and the nearby caps stopped shorting but the problem didn't go away when I turned the motherboard some capacitors ( c8047 c8048 c8049 c8050 c8051 c8053 - connected to pin 25 and 57 of the u8003(ite252e248a) and c8023 c8024 c8046 connected to pin 24 ) are shorting ,,,,pin 26 is ground...11-20-2025, 09:38 AM
by sda sadHope this is the right place, someone can help me.
My laptop started having a really strange problem....
When I turn it on the fans start working at a crazy rate and with random breaks...
They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
The model of the computer:
Xiaomi Notebook Pro X 15 OLED (A30)
... - Loading...
