Rexpower PL-400 rebuild
    master hoarder
    • May 2008
    • 12175
    Re: Rexpower PL-400 rebuild
    Get rid of that big load resistor on the 3.3v rail. Looks like a 10 Ohm. If it is, that's almost 1W of heat there and you'll be cooking your new caps. Change it with a different resistor that's 25 Ohms or more (but not more than 500 ohms). Seems like the 5vsb also has a big loading resistor (51 Ohms?). Change it to 100 Ohms or a bit higher. Less heat and improved efficiency when the PSU is loaded.
    See if there are any other load resistors on the other rails.
    PSU looks solid.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      Originally posted by c_hegge
      It actually had schottkys for the other two rails (Mospec S20C40C). The only fast recovery was the F12C20C on the 12v. As a replacment for the 12v rail, would an 80EPF10 do the job? (80A, 1000v VRRM)
      I believe etnietering tried using a Ultrafast 250v in place of a 200v Ultrafast on the 12v rail of his logisys 480W he was rebuilding and it failed to start up with it installed.
      Something like a 40A, 45V or 60V schottky would work fine. Using two 20A schottky's would be best as they would produce less heat, but a single to-247 40A or even a 30A would work just fine.
      • c_hegge
        • Sep 2009
        • 5219
        There's only room for 1 on the 12v rail. The 5v is the only rail where two can be installed. Would the STPS3045CW work fine or would a 48CTQ060PBF be better?
        • 370forlife
          Large Marge
          • Aug 2008
          • 3113
          The 48CTQ060PBF is in to-220 form and can do 40A at 110C. The STPS3045CW is in to-247 and can do 30A at 155C. Now because you won't reach 110C in the PSU it will probably be fine to use the 48CTQ060PBF.
          • c_hegge
            • Sep 2009
            • 5219
            I've given it some additional modifications. It previously had a thermister in series with the fan to temperature control it. I've replaced that with a proper temperature controller I pulled from an failed antec SU-380. I also have replaced all of the connectors (the originals only had 20 guage wires). It now has a 24 pin ATX connector, 8 SATA connectors, 6 Molex connectors and 2 floppy connectors.
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              #26
              Great job!
              I would love to see some photos
              • c_hegge
                • Sep 2009
                • 5219
                It aint finished yet. I'm still waiting on that 12v schottkey diode to arrive. I placed a few on back order from RS compunents (they didn't have it in stock).
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  I hate waiting for stuff to arrive - its frustrsting!
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Unfortunately the 48CTQ060PBF is discontinued. I was just informed by RS this morning, so I'm going to have to find an alternative part to use. Would a BYV42E-200 200V Ultrafast work?
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      #30
                      I think it should be ok but better wait for others with more experience to respond, for example 370forlife.
                      • everell
                        • Jan 2009
                        • 1514
                        What about the 5vsb circuit? If it fails, everything goes down the tube. Now might be a good time to try getting rid of that two transistor 5vsb circuit and installing a pwm chip.
                        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3113
                          I would imagine it would work.
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            #33
                            You don't really need a 200v part, a 100v one would work fine. MBR30100. But the one you linked to will work just fine as well. It has a bit higher voltage drop, but it'll do fine since i doubt the transformer in that can do 30A.
                            A working TV? How boring!
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3113
                              Sometimes the cheap power supplies will have a hard time using a regular schottky on the 12v rail. It will just act like there is a short, and only a ultrafast can be used. Rather be safe than sorry.
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Done for now. I might give it the 'everell mod' to the 5vsb later. Feel free to laugh at my new label. I'll test it when I get brave enough to power it on
                                • everell
                                  • Jan 2009
                                  • 1514
                                  I really like that "cool" double fan arrangement!
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2850
                                    • Greece
                                    #37
                                    It looks great
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      #38
                                      Looks good indeed. Is the secondary heatsink from a HiPro PSU?
                                      I was like that about 1 year ago. Now I just plug in things without getting any second thoughts. Not sure how that happened. I guess I eventaully got over it once I did a few repairs.
                                      With that said, fire that s*** up and let it burn if it so desires .
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        #39
                                        Believe it or not i've seen it on gutless wonders before.
                                        • c_hegge
                                          • Sep 2009
                                          • 5219
                                          The primary heatsink is from a Hipro, but the secondary is from a Seasonic-OEM Antec SU-380.
                                          • emil_t
                                            RTX3090 working fine but fans not spinning
                                            by emil_t
                                            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                            04-12-2024, 06:54 AM
                                          • b-slayer
                                            Asus Strix-G15-G513RM fans don't work
                                            by b-slayer
                                            I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                                            The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                                            (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                                            (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                                            ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                                            09-04-2025, 04:58 AM
                                          • JayPoorJay
                                            Hot Water Rad - A Few ECU Fans and a Timer Switch
                                            by JayPoorJay
                                            Good Afternoon, Good People.
                                            I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                                            I REALLY would appreciate y'alls help.
                                            This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                                            10-29-2024, 12:54 PM
                                          • amansr12
                                            Asus Rog strix G513 keyboard, fans not working, battery not charging, works on ac
                                            by amansr12
                                            Hi, I recently open my Asus rog strix g1513 laptop to clean the fans and while disconnecting the battery there was a spark near the connector (c6000) and a capacitor (C60050 ) and the keyboard , fans stopped working and the laptop only works when charger plugged in, otherwise no. I removed the burned capacitor and the nearby caps stopped shorting but the problem didn't go away when I turned the motherboard some capacitors ( c8047 c8048 c8049 c8050 c8051 c8053 - connected to pin 25 and 57 of the u8003(ite252e248a) and c8023 c8024 c8046 connected to pin 24 ) are shorting ,,,,pin 26 is ground...
                                            11-20-2025, 09:38 AM
                                          • sda sad
                                            my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
                                            by sda sad
                                            Hope this is the right place, someone can help me.
                                            My laptop started having a really strange problem....
                                            When I turn it on the fans start working at a crazy rate and with random breaks...
                                            They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
                                            And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
                                            The model of the computer:
                                            Xiaomi Notebook Pro X 15 OLED (A30)
                                            04-23-2024, 09:55 AM
