improve cheapo psu
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    improve cheapo psu
    in what ways could i improve this psu?
    this one:
    http://hardwareaware.com/review/linkworld-430w/
    i was thinking of improving the input filter and recapping it and adding more caps (if possible)...
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: improve cheapo psu
    I wouldn't even bother with this particular unit.
      • 31163
      remove & keep the fan, cables, inlet and gray thermal insulators & bolts/bushes.
      remove the NTC inrush limiter and send it to me
      then bin the rest.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        I know its a hunk o shit but i would learn more if i tried to improve it. And it was only like $12 or something so no biggie if i blow it up.
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          You mean you paid for it?
          Anyway, I am one of the few who believe that linkworld psus are well designed and they can work good for years if you recap them and add the missing components.
          The one you own is one of the worst linkworlds I have seen (not the only one though).
          You can start by adding a full input filter. That includes MOVs too.!
          Next, you may consider to replace the 4 diodes with a bridge rectifier (4A will be more than enough for that psu if you live in a 230V country).
          Next step, I always replace the primary main capacitors with 470uF 200V or more.
          You should also replace the secondary caps with low esr ones of same or bigger capacity .
          Finally, you can try to add some plastic cover among the pcb board and the metal case of the psu.
          If you really want to improve it, you should replace the secondary rectifiers with bigger ones, or add in parallel.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            If it's for learning purposes, then okay. Just keep in mind that if you ever test this PSU on a computer, you may ruin the computer if something goes wrong. With that said, I don't advise you test this PSU on any computer you would consider important/valuable. Also, most of these cheapo PSUs have weak 12v rails, so don't try it on a P4 computer or anything that draws lots of amps from the 12v rail. Better suited for older P3 and PII systems.
            Now for the PSU improvements: first and foremost, give us some pictures of the inside so we can see what you're working with. Then we'll go from there.
            I was thinking the same thing .
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Look at the review i linked to. It has pictures.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                pack it with m80's,thread the fuse through the vents,lay on ground light fuse get away.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  2: Post pictures or video of said event on Badcaps
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Im sure explosives would output some nice ripple-free 12, 5, 3.3v outputs. But it might not last very long
                    So unfortunatelyni think i have a slightly different version than in the linked review. So i may jave to post some pictures later
                    • everell
                      • Jan 2009
                      • 1514
                      Remove the components in the 5vsb circuit. Build DM311 circuit on small piece of perfboard. Then wire it in where the old two transistor 5vsb circuit was. Much more reliable, no more over-volting.
                      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        now THAT is too complicated
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          if only the rest of it were worth the powder to blow it up.
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            That's why I asked you to post pictures. Even if it looks the same or similar, you never know for sure if the guts inside are the same or not.
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              well um...
                              sorry for the bad pics. im moving so im not sure where my real cam is so i used my iphone 3g...
                              hope theyre good nuff.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                It looks... bad enough. Just your average gutless wonder. First thing i'd do is install a proper transient filter (hint: it needs a coil, a couple X capacitors and proper safety rated blue Y class capacitors instead of those brown ceramic pieces of junk). Then add more/better caps to the secondary, and some coils if you have them, if not, it'll do without.
                                A working TV? How boring!
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  heres what would be very helpful to me:
                                  take one of my pictures, and draw in with arrows/circles/etc what the pieces in need to replace are called and what do replace them with. because i dont know what a y cap looks like versus an x cap. tyvm!
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    I'd expect you to use google... Anyway here's my favorite PC power supply article. http://www.hardwaresecrets.com/article/327 <- Check Page 4 for an explanation of what the transient filter needs to have and how the parts look like.
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      Aha-very useful aricle. Will look it ver more thoroughly later today when im not in the bus
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2850
                                        • Greece
                                        If you post some better photos it will be easier for us to help
                                          RCA WHP141 wireless headphones wired up
                                          by momaka
                                          OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
                                          Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
                                          As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
                                          02-22-2023, 06:28 PM
                                        • NecroFlex
                                          Adding/unlocking CPU support for an HP EliteOne 800 G2 AIO
                                          by NecroFlex
                                          I bought a used HP EliteOne 800 G2 All in One PC, that has an i5 6500 in it with BIOS updates going into 2023. The Chipset in the AIO is a Q170, so in theory it should support 7th gen.
                                          HP site only shows a few 6th gen supported, when i inserted an i7 7700k (dead mem. A channel, but would be good in the AIO since i can just put a single 16GB stick in there) with the newest 2.60 bios, the AIO powered on and beeped/flashed an error code for the RAM (3 long 2 short) in the first ram slot and in the other slot it powered on, restarted and then stayed on a blank screen.
                                          I'm...
                                          02-22-2024, 11:56 AM
                                        • flat-earther
                                          Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                                          by flat-earther
                                          I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                                          To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                                          I have opened the camera and I think there is enough room to add something inside to accomplish this:
                                          The camera is powered by a 3.7V nominal single cell lithium ion battery.
                                          So I need to connect another battery in...
                                          06-08-2025, 02:00 AM
                                        • joelz
                                          pin Setting parameter line or set lines menu for adding ITE5571e on RT809F programmer
                                          by joelz
                                          Hi, sorry if i here to request if anyone know number of pin to set lines for reading ITE7751e on RT809F..i try to see on schematic but i dont know how to choose it..pleasee..
                                          11-18-2024, 06:02 AM
                                        • obdcart
                                          Asus X415ea Adding a Keyboard with Backlight
                                          by obdcart
                                          Hello my friends i hope you can help me, i have just replace a keyboard with non backlight on a Asus X415 Laptop and i already install a Keyboard with backlight, the motherboard has the conector and ic's to control the light but i doens't work, i already try with a new installation of Windows and it's the same and injecting 3v/5v to the backlight flex it turns on the light, i think must be disable on Bios or need a jumper configuration.
                                          I hope you can give me some help
                                          06-28-2024, 02:21 PM
