Thinkpad L13 Gen 2 Password
    Originally posted by Stefan Steff View Post
    Today I have to work with an Thinkpad L13 password remove situation.
    I followed exactly this volinakis guide and it's 90% accurate.
    I must write 00s on position 3. not FF because with FFs I got Error 2204 :System configuration data is invaid.
    Just an observation...
    Big thanks, volinakis!
    thank you for the precision of the 00
      Originally posted by psyjamm View Post
      Re: Thinkpad L13 Gen 2 Password
      Here is clear EC dump, you just need to program your EC chip (nuvoton) with Vertyanov programmer) and after that to fill all information like serial number etc..If you can't fill dmi block by Lenovo maintenance utility, here is adresses of these blocks
      Model name located at 0005C000
      SN,type and board number located at 00058000
      I don't have a Vertyanov programmer.
      Is it possible to add or change the boot order in the locked BIOS?
      The machine I have is fine, except it will only boot from the SSD; USB is locked out, so it can't be reloaded.
        Hi to all, @volinakis bro can you help me to make my readed dump file? Lenovo L13 Gen2 Bios Locked laptop
          post S/N, full name and model, motherboard model,etc.
            unlocked KBC bin (Intel platform)
            for your information, password is stored bewteen address 0x5E000 - 0x5E200. I'm not sure if it is similar for other models. You can erase it with 0xFF manually also. 0xFF stands for empty memory byte
              SN: R9-13P9ZL, Lenovo thinkpad L13 Gen2, Type number 20VH-004EUK 2021/07
                Hi All,
                Can anyone unlock bios lenovo thinkpad L13 intel i5 10th
                serial R9-0ZE8ZQ
                type number 20r4-S28W00
                  Originally posted by mareecki View Post
                  Hi All,
                  serial R9-0ZE8ZQ
                  post the original contents of the bios chip..
                    I tried to use flash programming tool to save bios backup but it stuck on "load failure: security violation.
                    hdd is wiped so do not have an access to windows (windows wont load as well)
                      You will need an SPI programmer to make a full backup.
