Should I buy a Lenovo Thinkpad E495 with bios password?
  • RMDUiFT
    • Jun 2024
    Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
    I have a few questions:
    • If I would buy this laptop and have the bios password removed, do I need any special tools to do so? Can the dumping be done without requiring physical connections to chips on the motherboard?
    • In the autopatcher tutorial thread, the instructions are unclear. From what I understand, after I run the autopatch.cmd with the bios dump, should I flash the patched bios file within the bios menu?
    Thank you for your time, have a pleasant day.
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1641
    • France
    https://www.badcaps.net/forum/troubl...23#post1622423
    • RMDUiFT
      • Jun 2024
      I've done some more research in the link you gave me and through your posts where you short pins with ground to remove the password. I've looked up for schematics for the thinkpad e495 and I found LAD, LPC and ESPI pins. Are they accessible on the motherboard? If I short them will the password reset work?
      Thank you.
      • Olegst44
        Acer Aspire 3 A315-22G - NB8607G02-MB (Compal LA-J761P) - BIOS Password Removal / Clean BIOS Needed
        by Olegst44
        I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
        Device Information:
        - Model: Acer Aspire 3 A315-22G
        - Motherboard: NB8607G02-MB (Compal LA-J761P)
        - BIOS Chip: Winbond W25Q64 (8MB)
        - Serial: NXHE7ER00X95002B784S00
        Problem:
        - BIOS is password protected (Supervisor Password)
        - Boot from USB is disabled in BIOS
        - After 3 wrong password attempts, system shows Unlock Key Hint
        - I have RT809H programmer available
        What I need:
        1. Clean BIOS dump (password...
        04-11-2026, 05:36 PM
      • OBATTAS
        lenovo thinkpad E495 bios password
        by OBATTAS
        hi i need bios dups no password PLZ
        THIS backup...
        06-11-2026, 10:21 AM
      • badzymandiaz
        Thinkpad P14s Gen 4, BIOS Supervisor Password
        by badzymandiaz
        I have a laptop that was purchased second-hand, and I am able to boot Windows on and extract the BIOS dump (ONLY the BIOS region, I was unable to dump anything else due to an FCERR I received trying to dump the other regions) and use normally. However, because the BIOS is locked with a supervisor password, I am unable to use anything else except for Windows, and it has also disabled some hardware features of the laptop itself, such as the fingerprinting module, etc. that I really do wish to use.
        I have been digging around for nearly 2 weeks trying to find any mention of the same model...
        09-28-2025, 10:49 AM
      • TopPop
        Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
        by TopPop
        Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
        I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
        12-14-2025, 09:40 PM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
