Thinkpad L13 Gen 2 Password
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    Re: Thinkpad L13 Gen 2 Password
    Sorry, I don't remember anymore. Don't have any L13 to unlock right now.
    • mgjini
      • Sep 2017
      • 199
      • united kingdom
      Originally posted by TiagoNecer
      hello!
      I managed to remove the password from this model of board, I put together a guide explaining the procedures, it is in Portuguese, but I believe it can help some people.
      Hello there, thank you very much for your clear instructions this helped me
      Read 2 laptops lenovo l13 gen 2 and lenovo yoga 13 gen 2, great instructions
      • mgjini
        • Sep 2017
        • 199
        • united kingdom
        Is ok I read the instructions of another user here and sorted 2 laptops, thank you
        • vzrivpaket
          • Jun 2017
          • 11
          • Poland
          Re: "Lenovo Yoga L13 Gen 2" Remove Password..
          Originally posted by just_bios
          hey..
          which programmer supports these eeproms..? i used CH341a and patch with lenovo_autopatcher_0.2 but after patching files is still same ( matched with hex)
          AJ2139
          25B256EYIG
          AJ2117
          25R256DYIG
          Hello.Need dumps of two BIOS chips. Thank you in advance.
          • ryuk1080
            • Oct 2023
            • germany
            hello!
            I was wondering if i can simply replace the nuvoton npce288ga0dx chip from another board, would that also work?
            • ryuk1080
              • Oct 2023
              • germany
              #26
              Anyone can recommend me another programmer that can also reprogram the EC chip on l13 gen 2 ? I had no luck gettin my hands on on vertyanov/successor in Germany.
              Thank you alot
              • vikrep
                • Sep 2011
                • 32
                #27
                Unlockable using vertyanov but config for LAR-2 is a bit wrong there. left->right works.
                Could you provide a proper config string for LAR-2? The board has a 36-pin socket with 1 pin from the left. Why need to change to right?
                Thank you
                I red firmware from Nuvoton chip but can't find data on address 36000h
                • vikrep
                  • Sep 2011
                  • 32
                  #28
                  Lenovo Thinkpad L13 Yoga Gen2
                  I downloaded EC (npce68apa0dx) firmware from LAR-2 motherboard
                  but can't find an area to clear the supervisor's password.
                  Could you help me, please?
                  SN: PW-019C2H
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1226
                    • France
                    #29
                    Re: Lenovo Thinkpad L13 Yoga Gen2
                    SN: PW-019C2H
                    try test
                    • vikrep
                      • Sep 2011
                      • 32
                      #30
                      Originally posted by Maxpower3
                      try test
                      Thank you! It works.
                      The first time was an alarming sound and message Security CRC Bad but after BIOS defaulted became good.
                      The supervisor's password is gone.
                      • Maxpower3
                        Maxpower3 commented
                        Editing a comment
                        thank you for your return
                    • volinakis
                      • Jan 2021
                      • 2734
                      • N/A
                      #31
                      Unlock Lenovo L13 Gen 2 20VJ, LAR-2 MB, EC NPCE68BPA1DX with SVOD 4:
                      1. set programmer as in photo. Power up motherboard and hit "Read ID" . I got Device ID: 1F20E20F. After that hit " config NOVUTON" and chose 384K and check NPCE68xxx
                      2. Hit "Read" and save the result. you should get a 393.216 bytes file.
                      3. fill with FF sections 5E000-5E3FF and 5F000-5F05F. Save new file, open into programmer software and write it back into EC.
                      4. you can also extract EC region from update searching in .fl1 file for header of EC region ( in my case 61870000 4E000000 DE070201 00002103) and selecting from there 393.216 bytes but you'll have warnings about serial, machine, name, etc and you have to write them with LMU. Attention, 8S label from motherboard has nothing to do with data you have to write in B0, you can take 1S (C0) and 8S (B0) from EC dump at 58000 or search for text SER#
                      • DNAGSM
                        • Jun 2023
                        • 13
                        • Algeria
                        #32
                        SN: PW-019C2H
                        Pinout JTAG ?
                        • predator_vol
                          • Mar 2016
                          • 7
                          • Ukraine
                          #33
                          Originally posted by DNAGSM
                          Pinout JTAG ?
                          no nead pinouts, select nuvoton
                          • johansel
                            • Feb 2022
                            • 34
                            • colombia
                            #34
                            Good day, I was trying to read the EC nuvoton with my svod 4 but it does not give me data, it only generates a file, I will attach a screenshot of what it reads
                            I did the steps as in the comment, however I was not successful.
                            any advice?Click image for larger version  Name:	Sin título.jpg Views:	0 Size:	389.3 KB ID:	3212985
                            • volinakis
                              • Jan 2021
                              • 2734
                              • N/A
                              #35
                              any advice?
                              when you hit " Read ID" did you get an ID? If not, check pins from programmer to correspond with pins from KBC connector with multimeter.
                              • johansel
                                • Feb 2022
                                • 34
                                • colombia
                                #36
                                When it reads the ID it does have recognition, however I will do the verification and give the results as soon as I finish.
                                • nabilgo
                                  • May 2016
                                  • 303
                                  • L.A
                                  #37
                                  can anyone unlock bios lenovo thinkpad L13 intel i5 10th
                                  serial r9-11zfbb
                                  type number 20r4-s0g500
                                  • nabilgo
                                    • May 2016
                                    • 303
                                    • L.A
                                    #38
                                    serial r9-11zfbb
                                    i did unlock it but it say bad data svp
                                    • testinglaptops
                                      • Oct 2022
                                      • 76
                                      • United Arab Emirates
                                      #39
                                      try test
                                      THANKYOU, Worked for me. 100% ok. no DMI problem. Password removed.
                                      • Stefan Steff
                                        • Mar 2024
                                        • 262
                                        • Romania
                                        #40
                                        Today I have to work with an Thinkpad L13 password remove situation.
                                        I followed exactly this volinakis guide and it's 90% accurate.
                                        I must write 00s on position 3. not FF because with FFs I got Error 2204 :System configuration data is invaid.
                                        Just an observation...
                                        Big thanks, volinakis!
                                        • RMDUiFT
                                          Should I buy a Lenovo Thinkpad E495 with bios password?
                                          by RMDUiFT
                                          Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                          I have a few questions:
                                          • If I would buy this laptop and have
                                          08-25-2024, 09:00 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          Today, 03:01 PM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          Ack
                                          Ack
                                          01-30-2025, 04:26 AM
