Dell XPS 9310 GDA30 LA-J143P bios repair please
  • MicroSMD Lab
    • Sep 2018
    • 145
    • Trinidad and Tobago
    This laptop hangs on Dell logo and gives 2 amber, 4 white blink code (service manual suggest RAM failure). I tried another bios from "bios archives" and got a solid white light which blinks when the charger is plugged in. Processor gets hot enough to turn on the fans and the fans spin constantly even though the lid is closed. All voltages seem to be present and no low resistance on any of the inductors. Thanks in advance.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12432
    Re: Dell XPS 9310 GDA30 LA-J143P bios repair please
    Originally posted by microsmd lab
    this laptop hangs on dell logo and gives 2 amber, 4 white blink code (service manual suggest ram failure). I tried another bios from "bios archives" and got a solid white light which blinks when the charger is plugged in. Processor gets hot enough to turn on the fans and the fans spin constantly even though the lid is closed. All voltages seem to be present and no low resistance on any of the inductors. Thanks in advance.
    xps 13 9310
    • MicroSMD Lab
      • Sep 2018
      • 145
      Thanks, are these dumps from other laptops? Should I try both if the first one I try does not work?
      • cmn.fix
        • 41
        Hello guys! not sure if I should reply to this thread. I have a Dell XPS 13 9310 with 3 amber and 6 white flashes (which normally means corrupt bios or incomplete flash). Is there any way to recover from this? Is someone able to repair this somehow if I post the bios dump? Also, I can see 2 chips: 1 winbond and 1 XMC next to the CPU, which one should I read? Thank you in advance!
        • hardware1
          • Sep 2021
          • 2949
          • N/A
          Read the both chips, upload its content, write your device service tag and someone will try to help you.
          all donations are welcome,
          • cmn.fix
            • 41
            Thank you for the quick reply! I have tried to read the XMC QH256BX1Q with my TL866II Plus and realized it's not supported. Can anyone recommend a programmer for this chip?
              • 22236
              Do you have the latest TL866II software version installed, its in the support list as WSON8
              http://www.autoelectric.cn/MiniPro/TL866II_List.txt
              XM25QH256B @WSON8
              • cmn.fix
                • 41
                XM25QH256B @WSON8
                Top man! I was still on version 7.51. I have managed to read the XMC but not sure if the Winbond 25Q80DV1G read is fine as flash detect gives me 26 possible selections. Also, second chip looks mostly empty after reading.
                Thank you guys for taking your time with a newb!
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12432
                  top man! I was still on version 7.51. I have managed to read the xmc but not sure if the winbond 25q80dv1g read is fine as flash detect gives me 26 possible selections. Also, second chip looks mostly empty after reading.
                  xps 13 9310
                  • cmn.fix
                    • 41
                    Originally posted by hoaca388
                    xps 13 9310
                    Thank you! I see they are different size and can't tell what chip to flash each of them (I guess the _R goes to the winbond?). Also I forgot to post the service tag for it: 7HC0Q73
                      • 22236
                      The winbond chip is only 1MB and its not the bios chip , its only 8 Mega Bits . The XM25QH256B is 256 Mega bits ,divide 256 by 8 = 32 ,so 32MB.
                      Both files posted by hoaca388 are 32MB .Dell provide 2 different updates in the bios update, and he doesn`t know which one is for laptop so he`s posted both. Your laptop spec from the service tag doesn`t give the CPU ID ,but does list the platform as MODENA TGL .Try the TGL bios first, the other one i assume is for Tiger Lake Refresh CPU`s.
                      https://www.dell.com/support/home/en...QT090/overview
                      • cmn.fix
                        • 41
                        First one worked like a charm. You guys are amazing. Thank you hoaca388 and thank you SMDFlea!
                        • sikocan
                          • Oct 2019
                          • 347
                          Can someone fix this BIOS file? Stuck on blank screen, same as his, 3 amber 6 white LED.
                          • lapfix
                            • Mar 2020
                            • 2765
                            • my workshop
                            Your servicetag !
                            • sikocan
                              • Oct 2019
                              • 347
                              Hlb6793
                              • lapfix
                                • Mar 2020
                                • 2765
                                • my workshop
                                Hlb6793
                                Try this clean me of your bios and give feedback
                                • Don-qie
                                  • Feb 2023
                                  • 5
                                  hello,
                                  I'm also in a similar predicament as above. I flashed with the modenaTGL bios and that brought everything back to life.
                                  I'm curious as to the method graft the new service tag and windows OEM key (another question here, the above threads looks to be only modifying service tag -- not windows key... are the dell keys generic? ) into a clean ME bios on these new dell laptops? I've taken a look at this bios via HxD and UEFITool but it looks like the bios guard requires disassembly ( dinked around a bit with Dell PFS Update Extractor too )
                                  anyways, would be cool to learn how to do it if anyone could point me in the right direction. feels weird just asking others to do the work for me.
                                  Thanks!
                                  • Don-qie
                                    • Feb 2023
                                    • 5
                                    i looked at the bin files a bit more last night. was able to spot the windows key and replace no problem. this service tag thing is a bit strange though. cant seem to spot it anywhere in the bios. any suggestions?
                                    • lapfix
                                      • Mar 2020
                                      • 2765
                                      • my workshop
                                      You ask about :
                                      1 = how to built a new bios
                                      2 = How to copy servicetag and windows key from old to new dump
                                      3 = How to clean me the new built
                                      this is it !
                                      • Don-qie
                                        • Feb 2023
                                        • 5
                                        yes sir, in so many words!
                                        reading up on this site for bios editing seems straight forward to me. however, these new style dell laptops feel a little bit different and documentation feels a little flimsy -- at least from what I've found lately
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
