On Board Ram Disable via Bios Editing
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Please help disable on board ram for asus X751NV&
Read...https://www.badcaps.net/forum/troubl...-requests-only
Post the S/N...the full name and model of the laptop, motherboard model, etc..
Hi there,
Have a E14 gen2 (AMD Version) here which has a ton of errors with the onboard ram. I tried disabling the RAM by using the script provided by SMDFlea here:
https://www.badcaps.net/forum/troubl...ts#post3232220
but that didn't work.
Anyone here who can help disabling the ram? Bios attached
Board: NM-C771
Type: 20T6-000TGE
Serial: PF-2C0LQH
OngoAttached Filesif you find these attachements useful please consider making a small donation to the site
tryHi there,
Board: NM-C771
Type: 20T6-000TGE
Serial: PF-2C0LQH
try thisHi there,
Board: NM-C771
Type: 20T6-000TGE
Serial: PF-2C0LQH
asus X751NV-TY011T
BOARD X751NV ver 2.1
SN H8N0CV06U328337
ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
Still doesn't work, but thanks for your effort.
one thing i noted: When i boot with original bios, after hitting the power button, the LEDs on Esc, F1, F4 and CAPS light up shortly, go off and a few seconds later LED on ESC and F1 light up, stay on and Bios information appear on the screen.
With the bioses posted so far, i only get black screen, no more LEDs or indicators compared to a "normal" behaviour.
ongoComment
onboard ram disable or give me ok tested biosAttached Filesif you find these attachements useful please consider making a small donation to the site
TRYAttached Filesif you find these attachements useful please consider making a small donation to the site
hello can help disable RAM Asus M415UA
SN: M3N0CV24D40113B
try...Attached Filesif you find these attachements useful please consider making a small donation to the site
Main Issue: Random and consistent BSOD's with multiple error codes pertaining to failing or bad memory, otherwise device functions normally between crashes.
I've attempted editing the BIOS bin manually, using the SPD removal tool, don't have access to a board view or schematic for resistor swapping. Now just black screen which resolves by reflashing original BIOS.
I'm probably doing something wrong but I'm struggling to figure out why removing SPD results in black screen or no display. Please and thank you for any attempt!
Device: ASUS GA401IV-BS96-WH
Board: GA401IV R1.4
SN: LCNRKD01344751DAttached Filesif you find these attachements useful please consider making a small donation to the site
tryMain Issue: Random and consistent BSOD's with multiple error codes pertaining to failing or bad memory, otherwise device functions normally between crashes.
Board: GA401IV R1.4
Hello. Can someone help disable onboard ram on Asus K513E from bios?Attached Filesif you find these attachements useful please consider making a small donation to the site
please post the serial number with all bios requests https://www.badcaps.net/forum/troubl...before-posting
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
Pls help me to disable the onboard ram i. I dont have any serial or model of this laptop. not visible at the back of the laptop. I will attached the original bios.
PROBLEM: has power but no display.
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
- Loading...
