  • DynaxSC
    • Apr 2021
    • 559
    • Poland
    I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of data sections. Once I have such a bios image, I can modify it for my board basing on the stickers data from the board, so I will not use the bios dump 1:1.
    Would appreciate sombody to help me with this. You can also PM me if you are afraid this "personalized" BIOS data might be missused.
  • marcusah
    MSI MS-7C02 ( MSI B450 Tomahawk Max ) v1.0 board BIOS
    by marcusah
    I have an MSI B450 Tomahawk Max v1.0 board here. I updated the BIOS to 7C02v3M5 over the BIOS on the board from 2020. The system would not get a picture afterwards. The BIOS flashback wouldn't work either. I downloaded 7C02v30​ and installed it via the CH341A cable on the JSPI1 header with my CH341A and 1.8v adapter and NeoProgrammer. I was able to have the latest BIOS renamed to MSI.ROM on a flash drive and when I put it in the USB port for BIOS Flashback and pushed the button it blinked away for about 5 to 10 minutes and then the board turned on. I'm guessing the BIOS...
    10-18-2026, 08:28 PM
  • kantusjack
    Dell XPS12 9Q23 board – no POST after BIOS corruption, now unstable after crossflash
    by kantusjack
    I am troubleshooting a Dell XPS 12 with motherboard 9Q23 (Compal LA-8821P) that failed during a Windows 10 update. The system powered off abruptly and never booted again. Initial behaviour
    • No display at any time (internal or external)
    • Power button would immediately shut the system off
    • System auto-powers when AC adapter is connected (battery removed)
    • Beep code: 3 beeps – pause – 3 beeps (continuous)
    • Fan never spins
    This behaviour suggests that POST starts but fails very early in initialization. On this platform, 3 beeps are generally associated with system board / chipset...
    03-14-2026, 10:33 AM
  • DavidChunco
    Lenovo NM-D031 board, no video, shuts down after 25s despite stable power rails, need bios rebuild
    by DavidChunco
    Hi, I have this machine on the work bench (Lenovo IdeaPad/NM-D031/GS454/GS554/GV450/GV550 board, no DGPU).
    I’m trying to diagnose a power-on issue and I would appreciate some guidance or a clean BIOS rebuild.
    • Board powers on correctly
    • All power rails remain stable
    • No video is ever produced
    • System always shuts down after ~20-25 seconds (very consistent timing) and requires full power cycle to restart.
    • BIOS was previously reflashed with a known-good image and cleaned ME region (when reflashing with clean ME region it power cycles several times but then shuts down and returns
    06-20-2026, 03:50 PM
  • Shoiab
    Subject: Need Original BIOS Files for LA-J371P (FDZ41) Board
    by Shoiab
    I need the original BIOS files for a laptop motherboard with the following details:
    Board Model: FDZ41 LA-J371P Rev: 1.0 (A00)
    Date: 2020-03-10
    The board has two BIOS chips:
    Main BIOS: 32MB
    Secondary BIOS (located near the USB Type-C port): 1MB
    The original TPS65987 USB Type-C PD Controller was faulty and has been replaced with a new one. After replacing the TPS65987, I need clean/original firmware files for both BIOS chips to complete the repair.
    If anyone has:
    Original dump files
    Working BIOS backup...
    06-06-2026, 12:28 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
