On Board Ram Disable via Bios Editing
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1356
    • France
    #561
    Originally posted by rena629
    I've already tried BIOS Memory SPD Removal Tool 1.6
    it is not this program but identical result
    • toannh92it
      • Oct 2021
      • 10
      • Viet Nam
      #562
      Asus X513ean has an onboard ram error, I tried to delete the ram with SPD v1.7 but failed, I even deleted and added an external ram code but still failed. I programmed the bios of X515EA, the machine displays but does not recognize NVME and only recognizes external ram.
      Information:
      - Asus X513EAN REV 5.3
      - SN: MAN0CV12674042B
      - Original X513EAN BIOS is attached below.
      - X515EA BIOS displays but does not recognize NVME attached below.
      • f@brice
        • Nov 2019
        • 78
        • France
        #563
        @toannh92it, compare this file with SPD v1.7 one, if it's different, try it, and report result please.
        • AlfredoHdez
          • Apr 2022
          • 7
          • México
          #564
          Please help disable on board ram for
          Asus Vivobook 15 X1504Z-NJ972W
          BOARD X1404ZA R3.0
          SN S5N0CX07K58421A
          • toannh92it
            • Oct 2021
            • 10
            • Viet Nam
            #565
            Thank you, I tried with SDP 1.6 and 1.7, but the device posted the 0.7xx amp line and then turned off again. I tried programming the bios of the a515ea and the device showed a good image, only recognizing the removable ram, but not nvme.
            I tried replacing the entire profile of a515 with x513 but the status is still the same as above.
            • toannh92it
              • Oct 2021
              • 10
              • Viet Nam
              #566
              BOARD X1404ZA R3.0
              SN S5N0CX07K58421A
              no ram original & no ram clearme
                • 22135
                There should be a QR code on the motherboard similar to this https://www.badcaps.net/filedata/fetch?id=3528659 ,scan it .The model number in the scan is the bios version you want.
                • AlfredoHdez
                  • Apr 2022
                  • 7
                  • México
                  #568
                  • AlfredoHdez
                    • Apr 2022
                    • 7
                    • México
                    #569
                    Support me to rebuild it, please. It turns on without an image.
                    Marca: ASAP
                    Modelo:
                    BOARD: JOYARD4_J_X133S_V10 2020216 r1
                    SN: 1404824348958
                    ​​​​​​Thank you
                    • Nguyễn vy
                      • Mar 2023
                      • Việt nam
                      #570
                      Information:
                      bạn làm được vui lòng cho mình xin file x513ea noram
                      • danito
                        • Jun 2016
                        • 1180
                        #571
                        english only
                        • Nguyễn vy
                          • Mar 2023
                          • Việt nam
                          #572
                          Thank you
                          • Nguyễn vy
                            • Mar 2023
                            • Việt nam
                            #573
                            Please help remove ram main x513ea mãhine code A515e ,i lost the original file only the download on the homepage remains .thank you
                              • 22135
                              Type the laptop serial number
                              read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                              • Nguyễn vy
                                • Mar 2023
                                • Việt nam
                                #575
                                Sorry for the inconvenience ,here is the serial number of the machine .please help ,thank you
                                Type the laptop serial number M7N0CV10H472284
                                  SMDFlea commented
                                  Editing a comment
                                  If the ram is ddr4 try the macro script patcher https://www.badcaps.net/forum/troubl...20#post3232220 .Alternatively search the internet for SPD removal tool. If it doesn`t boot after patching the ram flash your old bios back .Disabling by hardware might be one option, check the forum posts.
                              • toannh92it
                                • Oct 2021
                                • 10
                                • Viet Nam
                                #576
                                see post 566 my new bios build for both model, try and feedback
                                • expert-werkstatt
                                  • Nov 2025
                                  Please send me a Bios without RAM for:
                                  Lenovo V15-ADA
                                  Model Name: 82C7
                                  SN: PF22HLR3
                                  MTM: 82C70005GE
                                  Cheers
                                    • 22135
                                    Lenovo V15-ADA
                                    Model Name: 82C7
                                    SN: PF22HLR3
                                    MTM: 82C70005GE
                                    Cheers
                                    Patch your own bios backup , try the script patcher https://www.badcaps.net/forum/troubl...20#post3232220
                                    • VeSoN
                                      • Jun 2017
                                      • 11
                                      • turkey
                                      #579
                                      Hello, please could you please disable the ram?
                                      Thank you very much
                                      Lenovo V15 G2 ALC (HV461&HV561 NM-D522 Rev: 2.0)
                                    • VeSoN
                                      • Jun 2017
                                      • 11
                                      • turkey
                                      #580
                                      Thank you very much
                                      It didn't work, I couldn't do it.
                                      Could you please edit it and send it? Thank you.
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
                                      • grimacelord
                                        by grimacelord
                                        07-10-2025, 02:52 PM
                                      • DynaxSC
                                        by DynaxSC
                                        11-17-2023, 10:56 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • throwaway327
                                        by throwaway327
                                        Model No: RC72LA
                                        Serial No: SBNVKD001014459
                                        06-18-2025, 05:52 PM
