Yoga 11e 5th corrupted bios
Re: Yoga 11e 5th corrupted bios
Every donation made will go towards server fees and maintenance costs. -
Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
not the bios is the problem..I sent you the bios on the site..you will not find a better one..take everything out of the laptop (dvd, wifi, hdd, etc) and start..see what is happening ... change the bios battery ... check another HDD ...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hello Guys, at first big thanks for this forum, it helped me a lot of times, I successfully unlocked t460, x250, t470s, t550 - so I know the process.
Then I got locked Yoga 11e 5th gen 20LN with procesor m3 7y30 - successfully unlocked too, for unknown reason it died after ~10 reboots but it's not the case :-).
Then I got three locked Yoga 11e 5th but with Celeron N4100 (20LM), I thought it will work, but nooo... It is different motherboard then 11e with m3 7y30, chip is MXIC 25U6473F. Autopatcher does not show any error, but after applying patched bios it turns on, Esc key led is ON, but no display. Exactly the same on the second 11e N4100 - no display...
I searched through this forum and found a post from iTman with the same symptoms, the answer was to find P24S08 and program it with attached dump, it was said that this version of motherboard stores password in this chip, unfortunately thred was not continued...
I looked carefully on the mainboard and did not find this chip. I know how it should look like, I unlocked many L520, X230, T520 with SDA/SCL method.
I'm attaching the dumps of two Yogas and photo of the mainboard; the other side of MB does not contain any larger chips. The only one chip looking similar to regular 8-pin is placed under wifi card, but it is MXIC 25L1006E...
So did anyone solve it? Any ideas? :-)Comment
maybe spi flash corrupted,change it or need to flash Nuvoton EC with Programmer or just initialize eeprom with lenovo U1 soft and fill serial and modelLast edited by mazoot; 04-18-2023, 10:50 AM.Kill the state in yourself and you will be free like a wind...Comment
bios password
any one remove this password
yoga 11e 5thgen 8mb biosAttached FilesComment
ThinkPad Yoga 11e 5th Gen LLA-1 17873-1
17873-1 has no display....
Attached backup
Tried to clean with no luckComment
Re: ThinkPad Yoga 11e 5th Gen LLA-1 17873-1
You MUST:- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
.Comment
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Lenovo yoga 11e
MB:17873-1
SN:R9-0V0ARA
Problem: No Display and beepAttached FilesComment
Attached bin file has display but on a reboot loop after displaying configuration changed, i have tried to do txe clean but that did not solve the issue,
Lenovo Yoga 11e
LLA-1, 17833-1M
can't locate type and serialnumber for now.
NB the bin uploaded shows 16mb but it should be 8mb for some reason i dont understand why i saved it that way but it perfectly works if written backAttached FilesComment
by Loki_FidoHi everyone, hope everyone's having a great day.
I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
Does this mean the BIOS is fine? making it a hardware issue?
I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...-
Channel: BIOS Requests ONLY!
by azozexdhello freind can you help me to repair a corrupted bios please
LENOVO ThinkPad X13 YOGA GEN2 LLX-1 MB 203015-1 448.0MC05.0011
the bios work but it showing me region recovery and it start recovering but after finish it say failed to recovery and its restarting withe the same error
seriel number:: R914W7AV
TYPE::20W8-003JFR...-
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by TylerHyde21Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...-
by Loli PopuHello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
- Loading...
