Yoga 11e 5th corrupted bios
  • emzo
    • Mar 2020
    • 6
    • BG
    Hello, i have the following problem:
    No matter what i do i get reboot loop. Can't enter bios.
    From lenovo site i can download bios in FL1 format, which i don't know hot to extract.
    Here is a dump of my current bios.
    Any help would be appreciated.
    p.s. cmos battery is replaced and problem is present
  • peste
    • Dec 2016
    • 13661
    • ROMANIA
    Re: Yoga 11e 5th corrupted bios
    post the original bios of the laptop ... and the full name and model ...
    • emzo
      • Mar 2020
      • 6
      • BG
      Yoga 11e 5th Gen (Type 20LN 20LM) Laptop (ThinkPad)
      Original bios , read with SPI programmer is attached in the first post.
      • peste
        • Dec 2016
        • 13661
        • ROMANIA
        bios extracted from the Lenovo site update.
        • emzo
          • Mar 2020
          • 6
          • BG
          I too have The Fl1 from Lenovo site , but mine was 9.71Mb.
          Thanks , i'll test and report in 30 min.
          Let's hope this is fo celeron processor, as i forgot to mention it.
          • emzo
            • Mar 2020
            • 6
            • BG
            Flashed it, the problem is still present.
            keeps rebooting
            • peste
              • Dec 2016
              • 13661
              • ROMANIA
              keeps rebooting
              not the bios is the problem..I sent you the bios on the site..you will not find a better one..take everything out of the laptop (dvd, wifi, hdd, etc) and start..see what is happening ... change the bios battery ... check another HDD ...
              • ossasin
                • Oct 2020
                • Poland
                Hello Guys, at first big thanks for this forum, it helped me a lot of times, I successfully unlocked t460, x250, t470s, t550 - so I know the process.
                Then I got locked Yoga 11e 5th gen 20LN with procesor m3 7y30 - successfully unlocked too, for unknown reason it died after ~10 reboots but it's not the case :-).
                Then I got three locked Yoga 11e 5th but with Celeron N4100 (20LM), I thought it will work, but nooo... It is different motherboard then 11e with m3 7y30, chip is MXIC 25U6473F. Autopatcher does not show any error, but after applying patched bios it turns on, Esc key led is ON, but no display. Exactly the same on the second 11e N4100 - no display...
                I searched through this forum and found a post from iTman with the same symptoms, the answer was to find P24S08 and program it with attached dump, it was said that this version of motherboard stores password in this chip, unfortunately thred was not continued...
                I looked carefully on the mainboard and did not find this chip. I know how it should look like, I unlocked many L520, X230, T520 with SDA/SCL method.
                I'm attaching the dumps of two Yogas and photo of the mainboard; the other side of MB does not contain any larger chips. The only one chip looking similar to regular 8-pin is placed under wifi card, but it is MXIC 25L1006E...
                So did anyone solve it? Any ideas? :-)
                • peste
                  peste commented
                  Editing a comment
                  merged post..
              • ilior
                • Apr 2023
                • usa
                had the same problem , any solution ?
                • mazoot
                  iFixit
                  • Jan 2019
                  • 41
                  • Moldova
                  maybe spi flash corrupted,change it or need to flash Nuvoton EC with Programmer or just initialize eeprom with lenovo U1 soft and fill serial and model
                  Kill the state in yourself and you will be free like a wind...
                  • bhatt
                    • Dec 2015
                    • 95
                    • pakistan
                    bios password
                    any one remove this password
                    yoga 11e 5thgen 8mb bios
                    • dahnking
                      • Apr 2018
                      • 264
                      • kenya
                      ThinkPad Yoga 11e 5th Gen LLA-1 17873-1
                      17873-1 has no display....
                      Attached backup
                      Tried to clean with no luck
                        • 22001
                        Re: ThinkPad Yoga 11e 5th Gen LLA-1 17873-1
                        Attached backup
                        You MUST:
                        • cccamgeek
                          • May 2009
                          • 13
                          thx for this post i just use this bios dump for my laptop with the same fault
                          error:271 and it worked great for me ! thx
                          I JUST NOTICED THAT I AM A MEMBRE SINCE 2009 !!!
                          • User0897
                            • Mar 2020
                            • Asdf
                            Did you ever solve this? I have the exact issue.
                            • peste
                              peste commented
                              Editing a comment
                              merged post...
                          • volinakis
                            • Jan 2021
                            • 2874
                            • N/A
                            post serial number, machine type and bios backup and I can help.
                            • YOVISVAS
                              • Jul 2019
                              • Colombia
                              The file .bin is corrupt, the motherboard 17873-1 have ic bios w25q128fvsiq of 16mb
                              • cccamgeek
                                • May 2009
                                • 13
                                but it worked for me haha i just use this laptop to reply now !!
                                just i notised that there no serial number in my bios !
                                in my os linux if i change my passwor it not change mybe thue to this biose or to my OS !
                                but thedump is working !!!
                                • waqarali
                                  • Nov 2023
                                  • 49
                                  • United Arab emirates
                                  Lenovo yoga 11e
                                  MB:17873-1
                                  SN:R9-0V0ARA
                                  Problem: No Display and beep
                                  • motanya
                                    • Nov 2021
                                    • 162
                                    • Kenya
                                    Attached bin file has display but on a reboot loop after displaying configuration changed, i have tried to do txe clean but that did not solve the issue,
                                    Lenovo Yoga 11e
                                    LLA-1, 17833-1M
                                    can't locate type and serialnumber for now.
                                    NB the bin uploaded shows 16mb but it should be 8mb for some reason i dont understand why i saved it that way but it perfectly works if written back
                                    • peste
                                      peste commented
                                      Editing a comment
                                      merged post..
                                  • Loki_Fido
                                    Thinkpad X1 Yoga Gen 3 ,How to know if the BIOS is corrupted
                                    by Loki_Fido
                                    Hi everyone, hope everyone's having a great day.
                                    I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
                                    I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
                                    So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
                                    Does this mean the BIOS is fine? making it a hardware issue?
                                    I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...
                                    03-14-2025, 07:42 PM
                                  • FalconPunch
                                    Surface Pro X 1876 Bios corrupted
                                    by FalconPunch
                                    Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                                    Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                                    08-09-2025, 03:56 AM
                                  • zlr8r
                                    Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                    by zlr8r
                                    Greetings
                                    I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                    Serial Number: 5CG3202C16
                                    Product #/SKU: 739P0AV
                                    CT Number: PRTUE00WBI30YX
                                    Description: HP ZBook Firefly 14 inch G10
                                    BuildID: 23WWWGAZ602#SABU#DABU
                                    Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                    MAC address not found.
                                    • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                    10-28-2025, 01:56 PM
                                  • azozexd
                                    LENOVO ThinkPad X13 YOGA GEN2 bios me region corrupted
                                    by azozexd
                                    hello freind can you help me to repair a corrupted bios please
                                    LENOVO ThinkPad X13 YOGA GEN2 LLX-1 MB 203015-1 448.0MC05.0011
                                    the bios work but it showing me region recovery and it start recovering but after finish it say failed to recovery and its restarting withe the same error
                                    seriel number:: R914W7AV
                                    TYPE::20W8-003JFR...
                                    04-14-2025, 05:37 AM
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
