Yoga 11e 5th corrupted bios
i have two thinkpad yoga 11e type 20ln so , one of them have problem : configuration changed, Restart the system , i flash bios with this file , the problem is solved , for second thinkpad no display after bios update from windows , so i flash bios with this file , the problem is solved , thank you ^^Comment
Is there a solution to the problem of my computer working normally and only the time setting appears on the screen and then restarts in the same way and does not stop?
LENOVO YOGA 11E LA--1 17833-1M 448.0DA05.001M
TYPE 20LN-S0CG00 S/N R9-0V6LYJ 19/05Comment
Where is your bios file ?
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
LENOVO YOGA 11E LA--1 17833-1M 448.0DA06.001M , shows 'bad cmos checksum ... ' , can't access to bios settings , can't extract serial number , my 4MB dump bellows ! Any help !Attached FilesComment
I need help with my bios. I can't get to bios because there is a password inside
and i get bad time and date error and bad crc of security error at startup
20LN-S06E00 S/N R9-0v7zyp 19/06
Thanks for any helpAttached FilesComment
type 20LN-S0CG00 S/N R9-0TGD7119/03Attached FilesComment
what should we do with this??/what's your problem?
post S/N, full name and model, motherboard model, TYPE,etc.
Don't post pictures unless asked....No one wastes time enlarging pictures, turning them, or using a magnifying glass to see numbers or letters..
it makes our work easier, not yours..
write with the keyboard..
Every donation made will go towards server fees and maintenance costs.Comment
write with the keyboard..Comment
by Loki_FidoHi everyone, hope everyone's having a great day.
I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
Does this mean the BIOS is fine? making it a hardware issue?
I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...-
Channel: BIOS Requests ONLY!
by azozexdhello freind can you help me to repair a corrupted bios please
LENOVO ThinkPad X13 YOGA GEN2 LLX-1 MB 203015-1 448.0MC05.0011
the bios work but it showing me region recovery and it start recovering but after finish it say failed to recovery and its restarting withe the same error
seriel number:: R914W7AV
TYPE::20W8-003JFR...-
by TylerHyde21Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...-
by Loli PopuHello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
by Ugur87Hello
ive got a brand new Xplus Series 81 mini Notebook, but its not turning on, my friend take it and make something with it, everthing looks fine , charging , power input perfect , fans spinning but no image, now i read the bios chip with ch341a programmer, i think its corrupted, is there any way to fix a corrupted bios bin ? please help...-
- Loading...
