Dell XPS 15 9550 AAM00 LA-C361P REV 1.0 BIOS
  • ub6ib969
    • Jul 2010
    • 198
    I require most recent clean bios for Dell XPS 15 9550 AAM00 LA-C361P REV 1.0 BIOS
    thank you in advance.
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria πŸ‡§πŸ‡¬
    Re: Dell XPS 15 9550 AAM00 LA-C361P REV 1.0 BIOS
    O! And maybe also coffee and donuts? How about flowers?
    And after the coffee, would you like to specify what the problem is? I mean so we can help you in the best possible way?
    Become a Badcaps supporter
    Thanks to all supporters.​
    • ub6ib969
      • Jul 2010
      • 198
      Thank you again Vesko356!
      Unit does not post but powers on.
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria πŸ‡§πŸ‡¬
        How did this situation happen? Failed BIOS update, or ...?
        Have you tried another (known good) ram memory? Did you tried to remove main and RTC battery, to exclude possible bios freezing?
        • ub6ib969
          • Jul 2010
          • 198
          I suspect failed bios update, I replaced the CMOS battery and check all memory modules.
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria πŸ‡§πŸ‡¬
            What do you mean - "suspect"? Did you tried bios update or not?
            Try the attached dump (it's your original + latest available 1.14.0 bios version at the Dell support page for your model).
            If the problem remains, I'll additionally clean the ME firmware.
            • ub6ib969
              • Jul 2010
              • 198
              I do not own the unit, this is the information I was told. Will let you know shortly.
              • ub6ib969
                • Jul 2010
                • 198
                no dice, can you provide clean ME firmware.
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria πŸ‡§πŸ‡¬
                  Here:
                  • babanu
                    • Jan 2011
                    • 57
                    Hello
                    I have a DELL XPS15 9550 - LA-C361P which, due to a failed bios upgrade, I no longer had an image
                    I rewrote a bios dump but now it starts very hard
                    Can someone help me?
                    thank you​
                    • Vesko356
                      Vesko356 commented
                      Editing a comment
                      Read the rules before posting
                      You MUST:
                      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                  • rex98
                    • Feb 2023
                    • 1276
                    • Mandaue CEBU, Philippines
                    Originally posted by babanu
                    Hello
                    thank you​
                    try.
                    • Markus1741
                      • Sep 2020
                      • 843
                      • N/A
                      Hello
                      thank you
                      Hello try this me clean file from your orig file ...
                      Your Service Tag: C176R72
                      Good luck
                      • babanu
                        • Jan 2011
                        • 57
                        Hello !!
                        thank you for the help!!
                        rex98's dump works with Marcus's dump doesn't start!!
                        But I still have a problem. When I connect the battery to the bios, it doesn't start anymore
                        When starting, the power LEDs blink orange 3 times and white once
                          • 20826
                          [QUOTE=babanu;n3223821
                          rex98's dump works with Marcus's dump doesn't start!![/QUOTE]
                          Thats strange,as both files are exactly the same
                          • Danny159
                            • Dec 2021
                            • 25
                            • RomΓ’nia
                            Originally posted by rex98
                            try.
                            thank you it works perfect, great man!!!
                            • Sofian75
                              • Aug 2023
                              • 85
                              • France
                              DELL XPS15 9550 - AAM00 LA-C361P Rev 1.0 too.
                              I can't provide the serial number since I can't boot the laptop and the back cover is not the original.
                              I attach the bios backup if you can provide a clean bios please.
                              • Markus1741
                                • Sep 2020
                                • 843
                                • N/A
                                Try ... your original service tag = C0W2RC2
                                • Sofian75
                                  • Aug 2023
                                  • 85
                                  • France
                                  I get an error with both Neoprogrammer and CH341 Programmer. "Chip main memory with the contents are in disagreement"
                                  • Sofian75
                                    • Aug 2023
                                    • 85
                                    • France
                                    Fixed by soldering the chip instead of using the clip.
                                    But now the vrm mosfets are getting very hot.
                                    • inspirim
                                      • May 2013
                                      • 282
                                      • Italy
                                      please fix my bios no video, i attach original bios.
                                      model: XPS 15 9550
                                      ervice tag: 1TH6CG2
                                      thanks to all​
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • mikeybass
                                        by mikeybass
                                        04-23-2025, 04:30 PM
                                      • jhanra
                                        by jhanra
                                        in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                                        11-02-2024, 04:19 AM
                                      • gizaha
                                        by gizaha
                                        02-13-2024, 07:18 AM
                                      • mrrubik
                                        Dell Optiplex 7010 micro bad BIOS flash?
                                        by mrrubik
                                        Hi folks,
                                        I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                        After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                        Steps I took:
                                        1. Read BIOS with CH341a, verified hash twice
                                        2. Patched
                                        12-23-2024, 04:11 PM
