Dell XPS 15 9550 AAM00 LA-C361P REV 1.0 BIOS
  • ub6ib969
    • Jul 2010
    • 201
    I require most recent clean bios for Dell XPS 15 9550 AAM00 LA-C361P REV 1.0 BIOS
    thank you in advance.
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria πŸ‡§πŸ‡¬
    Re: Dell XPS 15 9550 AAM00 LA-C361P REV 1.0 BIOS
    O! And maybe also coffee and donuts? How about flowers?
    And after the coffee, would you like to specify what the problem is? I mean so we can help you in the best possible way?
    Become a Badcaps supporter
    Thanks to all supporters.​
    • ub6ib969
      • Jul 2010
      • 201
      Thank you again Vesko356!
      Unit does not post but powers on.
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria πŸ‡§πŸ‡¬
        How did this situation happen? Failed BIOS update, or ...?
        Have you tried another (known good) ram memory? Did you tried to remove main and RTC battery, to exclude possible bios freezing?
        • ub6ib969
          • Jul 2010
          • 201
          I suspect failed bios update, I replaced the CMOS battery and check all memory modules.
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria πŸ‡§πŸ‡¬
            What do you mean - "suspect"? Did you tried bios update or not?
            Try the attached dump (it's your original + latest available 1.14.0 bios version at the Dell support page for your model).
            If the problem remains, I'll additionally clean the ME firmware.
            • ub6ib969
              • Jul 2010
              • 201
              I do not own the unit, this is the information I was told. Will let you know shortly.
              • ub6ib969
                • Jul 2010
                • 201
                no dice, can you provide clean ME firmware.
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria πŸ‡§πŸ‡¬
                  Here:
                  • babanu
                    • Jan 2011
                    • 61
                    Hello
                    I have a DELL XPS15 9550 - LA-C361P which, due to a failed bios upgrade, I no longer had an image
                    I rewrote a bios dump but now it starts very hard
                    Can someone help me?
                    thank you​
                      Vesko356 commented
                      Editing a comment
                      Read the rules before posting
                      You MUST:
                      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                  • rex98
                    • Feb 2023
                    • 1296
                    • Mandaue CEBU, Philippines
                    Originally posted by babanu
                    Hello
                    thank you​
                    try.
                    • Markus1741
                      • Sep 2020
                      • 967
                      • N/A
                      Hello
                      thank you
                      Hello try this me clean file from your orig file ...
                      Your Service Tag: C176R72
                      Good luck
                      • babanu
                        • Jan 2011
                        • 61
                        Hello !!
                        thank you for the help!!
                        rex98's dump works with Marcus's dump doesn't start!!
                        But I still have a problem. When I connect the battery to the bios, it doesn't start anymore
                        When starting, the power LEDs blink orange 3 times and white once
                          • 22119
                          [QUOTE=babanu;n3223821
                          rex98's dump works with Marcus's dump doesn't start!![/QUOTE]
                          Thats strange,as both files are exactly the same
                          • Danny159
                            • Dec 2021
                            • 25
                            • RomΓ’nia
                            Originally posted by rex98
                            try.
                            thank you it works perfect, great man!!!
                            • Sofian75
                              • Aug 2023
                              • 87
                              • France
                              DELL XPS15 9550 - AAM00 LA-C361P Rev 1.0 too.
                              I can't provide the serial number since I can't boot the laptop and the back cover is not the original.
                              I attach the bios backup if you can provide a clean bios please.
                              • Markus1741
                                • Sep 2020
                                • 967
                                • N/A
                                Try ... your original service tag = C0W2RC2
                                • Sofian75
                                  • Aug 2023
                                  • 87
                                  • France
                                  I get an error with both Neoprogrammer and CH341 Programmer. "Chip main memory with the contents are in disagreement"
                                  • Sofian75
                                    • Aug 2023
                                    • 87
                                    • France
                                    Fixed by soldering the chip instead of using the clip.
                                    But now the vrm mosfets are getting very hot.
                                    • inspirim
                                      • May 2013
                                      • 287
                                      • Italy
                                      please fix my bios no video, i attach original bios.
                                      model: XPS 15 9550
                                      ervice tag: 1TH6CG2
                                      thanks to all​
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • mikeybass
                                        by mikeybass
                                        04-23-2025, 04:30 PM
                                      • capoplays
                                        Help with BIOS update on Dell G15 5515 after chip replacement
                                        by capoplays
                                        Hey everyone,
                                        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                        When I check the BIOS using the F12 menu Flash...
                                        10-24-2025, 06:53 AM
                                      • Akhlz001
                                        by Akhlz001
                                        09-20-2025, 07:15 PM
                                      • Sathsul
                                        Dell Latitude 5431 issues with dumping bios
                                        by Sathsul
                                        So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                        The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                        However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                        10-28-2025, 07:49 AM
