Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • bilen
    • Aug 2014
    • 638
    • istanbul
    #181
    Re: HP Elitebook 850 G8 bios locked
    Originally posted by hoaca388
    HxD editor.
    How do we remove it with the HxD editor?
      • 20873
      By comparing a locked and unlocked file using the File-compare option "Analysis -> Data comparison -> Compare.." .Its not easy to understand at first but if you keep comparing lots of other files on the forum you`ll start to see it
      • bilen
        • Aug 2014
        • 638
        • istanbul
        #183
        thanks i will try
        • ba7bou7a
          • Nov 2017
          • 49
          • canada
          #184
          hi , i need help unlocking my HP 840 G8 BIOS pls
          • hardware1
            • Sep 2021
            • 2930
            • N/A
            #185
            Here's your Unlocked file, if the password still present upload the other chip (EC), it could be 16MB or 32MB.
            all donations are welcome,
            • lapfix
              • Mar 2020
              • 2720
              • my workshop
              #186
              Try.
              • ba7bou7a
                • Nov 2017
                • 49
                • canada
                #187
                didn t work but thank u for trying
                • ba7bou7a
                  • Nov 2017
                  • 49
                  • canada
                  #188
                  Originally posted by lapfix
                  Try.
                  it worked thank u
                  • ba7bou7a
                    • Nov 2017
                    • 49
                    • canada
                    #189
                    Try.
                    i was able to log in to bios but if i try to reset the bios it is asking for password...since u was able to remove it from the log in screen , are you able to tell me what was it ?
                    thank you
                    • lapfix
                      • Mar 2020
                      • 2720
                      • my workshop
                      #190
                      As hardware mention before ; if the password still present upload the other chip (EC), it could be 16MB or 32MB.
                      • gerlach
                        • Jan 2020
                        • 13
                        • Poland
                        #191
                        Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
                        Hello.
                        I have a problem with the Elitebook 840 G8. When enabled, there is a POST Power-on Password prompt. Possibly there is also an Admin Bios password. Can anyone help get rid of the problem?
                        • ba7bou7a
                          • Nov 2017
                          • 49
                          • canada
                          #192
                          ok this is the two files needed , remove all passwords pls so i can reset the bios and gain full control
                          thank u
                          • miansh621
                            Banned
                            • May 2022
                            • 133
                            • pakistan
                            #193
                            thank u
                            is these from diffrent laptops
                            • ba7bou7a
                              • Nov 2017
                              • 49
                              • canada
                              #194
                              no , same laptop but i uploaded the the original files , keep in mind that what i have in the laptop eprom 1 is modified by the pervious post which i was able to log in to bios but i couldn t reset it (still asking for password)
                              should i try the file u uploaded now ? or should i reprogram the original files and turn the laptop on then reupload them on the forum?
                              thank u for your time
                              • miansh621
                                Banned
                                • May 2022
                                • 133
                                • pakistan
                                #195
                                should i try the file u uploaded now ? Or should i reprogram the original files and turn the laptop on then reupload them on the forum?
                                Thank u for your time
                                reprogram this file u will done it
                                • hardware1
                                  • Sep 2021
                                  • 2930
                                  • N/A
                                  #196
                                  Originally posted by gerlach
                                  Hello.
                                  Here are your Unlocked files, hope it works fine.
                                  Program the both chips together, in the first boot go to Bios Menu and disable security options (Default).
                                  • gerlach
                                    • Jan 2020
                                    • 13
                                    • Poland
                                    #197
                                    Thanks a lot. It works
                                    • classicandy
                                      • Apr 2018
                                      • 308
                                      • Nigeria
                                      #198
                                      Hi Everyone.
                                      Please I need help in unlocking BIOS password for this EliteBook 840 G8. I tried the BIOS Patch but it didn't work. I wonder where the problem is now.
                                      The patched BIOS is the current one in the BIOS chip
                                      Thanks.
                                      • vignesharivuslm
                                        • Nov 2014
                                        • 31
                                        • India
                                        #199
                                        PLS HELP, ATTACHED 2 FILES, SVP AND SWAT LOCK.
                                        UNLOCK PLS
                                        • miansh621
                                          Banned
                                          • May 2022
                                          • 133
                                          • pakistan
                                          #200
                                          Originally posted by vignesharivuslm
                                          Pls help, attached 2 files, svp and swat lock.
                                          Unlock pls
                                          feedback
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
