Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • hoaca388
    Badcaps
    • Jan 2022
    • 12507
    #61
    Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Originally posted by synet2k
    Hi, I need to dump both of my bios to file in order to unlock the bios? or I can just flash the file from post #54 will do?
    You need to dump both of my bios to file in order to unlock the bios.
    Code:
    No, don't do that.
    • bhatt
      • Dec 2015
      • 95
      • pakistan
      #62
      I cant understand plz u rebuild this bios
      HP 840 G8 11 GEN PSWD
      • hoaca388
        Badcaps
        • Jan 2022
        • 12507
        #63
        What's your problem ? Bios corrupt or bios has a password ?
        • bhatt
          • Dec 2015
          • 95
          • pakistan
          #64
          this bios have password can u remove this password
          am waiting your reply thanks
          • hoaca388
            Badcaps
            • Jan 2022
            • 12507
            #65
            Description : HP EliteBook 840 G8
            CT Number : 6LGWR0EWYF795L
            Serial number : 5CG12869TG
            SKU number : 3E9K6UP#ABA
            Feature byte : 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwnVng.Q4
            Build Id : 21WWCVCT601#SABA#DABA
            Product Number : 3E9K6UP
            • bhatt
              • Dec 2015
              • 95
              • pakistan
              #66
              thanks Hoaca388
              my job time is finished
              I will check tomorrow and give you result,
              • bhatt
                • Dec 2015
                • 95
                • pakistan
                #67
                brother password is clear but its give manufacture mode error
                when i entered the information not save same error
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12507
                  #68
                  Post data of 2nd SPI chip . It's 16MB or 32MB.
                  • Kicique
                    • Jul 2022
                    #69
                    hello, i have an elitebook 840 g8 with bios pass, can u hel me ?
                    • Kicique
                      • Jul 2022
                      #70
                      what should i do ?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12507
                        #71
                        Originally posted by Kicique
                        what should i do ?
                        Buy a programmer, find bios and ec chips of device, use that programmer for read data from bios and ec chips , post both that files here.
                        • farouk_1994
                          • Mar 2021
                          • 403
                          • algeria
                          #72
                          HP Elitebook 850 G8 bios locked
                          Hello i have HP Elitebook 850 G8 bios locked need help please.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12507
                            #73
                            Re: HP Elitebook 850 G8 bios locked
                            Post 2nd bios chip.
                            • Udemzy
                              • May 2017
                              • 168
                              • Guatemala
                              #74
                              Use the Rc unlock tool with the 16mb chip at the back of the board , works fine with 840 g7, i believe it will work fine with this too.
                              for easy access you can use the ic test clip probe,no need to take out the chip
                              • farouk_1994
                                • Mar 2021
                                • 403
                                • algeria
                                #75
                                Originally posted by hoaca388
                                post 2nd bios chip.
                                here it is the seconde bin
                                • farouk_1994
                                  • Mar 2021
                                  • 403
                                  • algeria
                                  #76
                                  Originally posted by udemzy
                                  use the rc unlock tool with the 16mb chip at the back of the board , works fine with 840 g7, i believe it will work fine with this too.
                                  For easy access you can use the ic test clip probe,no need to take out the chip
                                  but it is 32 mb chip it won't work
                                  • farouk_1994
                                    • Mar 2021
                                    • 403
                                    • algeria
                                    #77
                                    Post 2nd bios chip.
                                    Can you help me with that
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12507
                                      #78
                                      Ofcourse . In the first boot, you have to go into bios setting for dissable all the security options.
                                      • farouk_1994
                                        • Mar 2021
                                        • 403
                                        • algeria
                                        #79
                                        thank you sir it works appreciate
                                        • lenovx
                                          • Nov 2016
                                          • 12
                                          • maroc
                                          #80
                                          Please look for the 6050A3217501-MB-A011086 L2 file clearME
                                          840 g8 11th
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
