Extract bios password from EliteBook 840 G8 Bios dump, possible?
+ More Options
Posts
  • unleadedblues
    • Apr 2019
    • 6
    • us
    #81
    Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
    I'm assuming that the stock BIOS image extracted from the official HP BIOS exe can not be directly flashed, right ?
    Also, should the patch in post #9 be used on both chips?
    And, how is this patch found? I mean is there work we can individually do to contribute to solutions on other laptops? I'd rather not just be a helpless leech like now...
    • m3mo3y
      • 31
      • Sweden
      #82
      HP EliteBook 850 G8 unlock please
      hello guys
      i tried RC unlocker but it give me error to try with 16mb chip
      i read that i need a modefied dump to work . but i dont know how to mod it
      if anyone can help that would be awesome
      this dump is for the 32mb chip on the back
      and please tell me how it done so i dont bother you guys again
      thanks
      • m3mo3y
        • 31
        • Sweden
        #83
        Re: HP Elitebook 850 G8 bios locked
        Originally posted by hoaca388
        Ofcourse . In the first boot, you have to go into bios setting for dissable all the security options.
        hopefully you can help me , and please tell me how
        • hoaca388
          Badcaps
          • Jan 2022
          • 12020
          #84
          Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------
          • m3mo3y
            • 31
            • Sweden
            #85
            NvramActiveRegn section removed ??? thanks man i will try it
            you are awesome
            • m3mo3y
              • 31
              • Sweden
              #86
              After flashing the bios and verifying the flash
              I got a 6 blinking caps lock led
              Which on hp website indicates a BIOS authentication issue
              Any suggestions??
              • hoaca388
                Badcaps
                • Jan 2022
                • 12020
                #87
                Check your process again, is it good to solder the bios chip to the motherboard, is the data written to the chip through the programmer guaranteed?
                • m3mo3y
                  • 31
                  • Sweden
                  #88
                  I did a mistake reading the chip , but i don't think it's going to effect
                  The chip is 3v and i tried to dump ut using 1.8v adapter then i realized it's 3v chip
                  But it read and write fine..
                  Is that a problem??
                  • m3mo3y
                    • 31
                    • Sweden
                    #89
                    Yup it was a bridge solder joint 😄 and fixed and the laptop boots fine now with no password
                    Thanks my manā¤ļøā¤ļø
                    • lleg0
                      tuzbiosu'ma-tii
                      • Jul 2022
                      • 17
                      #90
                      Hello, I don't want to steal the thread but can you please indicate what IC programmer did you use?
                      Thank you
                      • Mazorca
                        • Jan 2017
                        • 463
                        If you are doing this for one time, go for the cheap ones, and IF for a living or to learn further, medium price are OK, I use a tl866-ll plus, never had issues with it, except when I tried reading two wson chips at the same time. Consider this: you are messing with a several hundred dollar machine, do not expect everything to go OK with a cheap one, soldering skills are needed too, best not to use a clip nor wires. It makes more sense to take MOBO to a skilled phone repair shop, just for desoldering and soldering back. Takes them a few minutes, even seconds to take out chip.
                        • m3mo3y
                          • 31
                          • Sweden
                          #92
                          Thank you
                          its a cheap ch341 3.3v moded programmer it does the job for me and i have 1.8v adapter also i recommend you to buy the new version (ch341a programmer v1.7)
                          • adom
                            • Sep 2021
                            • 12
                            • Switzerland
                            #93
                            i have 840 G8 locked, i need unlock (patch didn't work)
                            • Mazorca
                              • Jan 2017
                              • 463
                              I can't unlock it either, perhaps post the other chip contents?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12020
                                #95
                                In the first boot you have to go into bios setting to disable all the security options for avoid activate " Absotute " or " computrace " feature.
                                • metropolisystem
                                  • Jan 2016
                                  • 40
                                  • Colombia
                                  #96
                                  Re: hp elitebook 840 g8 bios password
                                  hi friend, I have a problem with this same laptop, when it enters windows a lock message appears, I send an image with the lock, can I correct this with the HxD program?
                                  Thank you
                                  • metropolisystem
                                    • Jan 2016
                                    • 40
                                    • Colombia
                                    #97
                                    hi Hoaca388, can you help me ?
                                    • lleg0
                                      tuzbiosu'ma-tii
                                      • Jul 2022
                                      • 17
                                      #98
                                      Elitebook 840 G8 bios unlock (Administrator Password)
                                      Can you help me unlocking the admin password for HP Elitebokk 840 G8? (i5 gen 11th)
                                      Dump attached, contains the BIOS and EC ROM;
                                      no luck with RCUnlocker
                                      Thank you!
                                      • miansh621
                                        Banned
                                        • May 2022
                                        • 133
                                        • pakistan
                                        #99
                                        Re: Elitebook 840 G8 bios unlock (Administrator Password)
                                        hello,
                                        can you help me unlocking the admin password for hp elitebokk 840 g8? (i5 gen 11th)
                                        dump attached, contains the bios and ec rom;
                                        no luck with rcunlocker
                                        thank you!
                                        feedback reprogram only ec
                                        • lleg0
                                          tuzbiosu'ma-tii
                                          • Jul 2022
                                          • 17
                                          #100
                                          I tried using stock (locked) bios and your EC and laptop doesn't power on; Caps lock on and that's it;
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
