IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
  • onepic
    • May 2019
    • 20
    • RO
    #101
    Re: IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Hi there,
    V15-ADA 82C7 power on, charging, fan spinning but remain on blank screen (the same on HDMI out). The original dump attached, but i can't extract de Windows key with BIOSdump2license.exe (serial encrypted mesage for a short time).
    So... can anyone patch the latest BIOS: https://download.lenovo.com/consumer...s/e8cn39ww.exe for Serial: PF328XV4 and MTM: 82C7008TIX?
    Thank you in advance!
    • peste
      • Dec 2016
      • 13443
      • ROMANIA
      #102
      Originally posted by onepic
      Hi there,
      did you read post #1?
      • onepic
        • May 2019
        • 20
        • RO
        #103
        Yes, but i don't want to made mistakes, because i do not have too much experience with. So is forbidden to ask some one else to help? If yes then plese delele my posts.
        • onepic
          • May 2019
          • 20
          • RO
          #104
          I have patched it by myself, write it into the bios chip but still into the black screen... Can anyone verify it the patched BIOS it's should be ok with the data posted above? Thank you!
            • 21692
            Its verified OK, you did a good job. Its worth trying an older version as well,and if that doesn`t work start looking for a hardware problem.
            • mmsuleiman
              • Dec 2019
              • 3
              • Egypt
              #106
              Thank you it's working
              • onepic
                • May 2019
                • 20
                • RO
                #107
                Unfortunately the same, also with a a BIOS from august 2022 . So it must be a hw problem.
                • narpa
                  • Aug 2017
                  • 11
                  • France
                  #108
                  Hello all, can somebody help me for a supposed bios issue (black screen)
                  Model : lenovo ideapad 15ada05 /
                  Lenovo new Bios url : https://pcsupport.lenovo.com/fr/fr/p...loads/ds543481
                  Chip is a Winbond 64n the new bios is too big
                  1. here is the backup chip desoldered from board (no clip ^^) :
                  2. The new one, downloaded from lenovo, and extracted :
                  When i try reprogramming (ch341blackedition), he say too big
                  What did i can do ? Thank for your time
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #109
                    Originally posted by narpa
                    Hello all...
                    Everything you need is explained in detail in post #1
                    You can download an already extracted from the update bios dump at posts #3, #12 or #20
                    Become a Badcaps supporter
                    Thanks to all supporters.
                    • narpa
                      • Aug 2017
                      • 11
                      • France
                      #110
                      Ok I extracted and modified the bios like post number 1, good size now. Programming was ok, I tried multiple bios file but always black screen, not a bios issue for me.
                      Thank for your time, we can't fix them all
                      Info : for this model chip Winbond 25Q64FWSIG 1.8v i used an adapter 1.8v 25xx flash for ch341.
                      • vasiacp
                        • May 2023
                        • 3
                        • Romania
                        #111
                        Originally posted by peste
                        you have everything you need for post#1, if it doesn't work it means you are writing the bios with errors...what programmer do you have??
                        Well I have a CH341
                        • reset1986
                          • 308
                          • italia
                          #112
                          lenovo nm-D151 rev 1.0 gv451 gv 551 bios dump
                          hi, I have this lenovo that turns on the fan and the LED when I turn it on, the screen seems to start up but then goes dark, I tried some bios files but I don't know if they are compatible, I am attaching the original backup, thanks
                          the chip bios is winbond 25q64fw 1.8v
                            • 21692
                            Re: lenovo nm-D151 rev 1.0 gv451 gv 551 bios dump
                            Go to the lenovo support site,enter the laptop serial number.Find the bios update listed under drivers. If the bios version is E8CN**WW (** is the version number) then yes they are compatible.
                            • reset1986
                              • 308
                              • italia
                              #114
                              from the site the version is E8CN39WW
                                • 21692
                                Everything you need is in this thread.
                                • reset1986
                                  • 308
                                  • italia
                                  #116
                                  can i use E8CN36WW?
                                    • 21692
                                    can i use E8CN36WW?
                                    Yes.It is older though, version 36. If you want to use the newest there`s a link to a guide guide at post #1 showing how to extract it yourself from the update exe.
                                    • Mistru
                                      • Jan 2023
                                      • 4
                                      • Turkey
                                      #118
                                      Hello, Lenovo V15-ADA / Model no: 82C7
                                      S/N: PF203BYH
                                      MTM:82C7001HTX
                                      there is an image harddisk and nvme does not see it ?
                                      Can you send the bios file?
                                      • peste
                                        • Dec 2016
                                        • 13443
                                        • ROMANIA
                                        #119
                                        S/N: PF203BYH
                                        MTM:82C7001HTX
                                        read post #23, but first make a copy of the original bios..
                                        • Ryzen1234
                                          • May 2022
                                          • Philippines
                                          #120
                                          Here's your new bios file, it's a virgin Bios from Lenovo with your DMI.
                                          Ryzen1234;1246821]can you help me
                                          this is my old bios
                                          Model Name : 82c6
                                          Serial Number: PF3A9JRS
                                          MTM: 82C600BLAU
                                            Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 05:00 AM
                                          • Patriarxis
                                            Lenovo IdeaPad 3 14ADA05 dosen't turn on
                                            by Patriarxis
                                            Hello.
                                            I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
                                            It takes 0.027A and the power button flashing.
                                            All the voltages on the board are ok. 3.3, 5 etc.
                                            Also is charging the buttery .
                                            What else i can check?​
                                            05-26-2025, 01:03 AM
                                          • hotcrossedbuns999
                                            IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                                            by hotcrossedbuns999
                                            First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                                            Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                                            05-21-2025, 05:59 PM
                                          • pcwhiz24
                                            Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                            by pcwhiz24
                                            Model: Lenovo IdeaPad 3 14ADA05 81W0
                                            S/N: PF2BZS7D
                                            I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                            I already have a CH341A programmer...
                                            04-07-2025, 07:10 PM
                                          • Visual_vt
                                            Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
                                            by Visual_vt
                                            Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
                                            SSD and BIOS seems to be OK.
                                            Thank you....
                                            12-30-2024, 09:14 AM
