Hello guys please help black screen not booting nor bios. Ideapad 3 15ADA05 81W1 SN PF28B53H MTM 81W1008WGM Attaching original bios from laptop
IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
Attached Files↵
https://www.badcaps.net/donateComment
Hello All,
Can you also remove internal RAM from my *.bin BIOS file.
IdeaPad 3 17ADA05
chip:W25Q64JWSIQ
Model:81W2
MTM 81W20006QPB
SN: PF2JYYSM
Thanks in advance!!!
RemAttached FilesComment
Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Thank you for the file, unfortunately it turned out that the files that I read with the programmer do not work correctly (black screen) and only the *.BAK file that I read with the Lenovo program for BIOS upgrade works. Is it possible to trim such a file?
Thank you very much for your help.Attached FilesComment
Hi friend,pls help,I will paste old file.
my notebook has black screen
lenovo v14-ADA
MODEL: 826C
Hi i have a lenovo ideapad 15ada05 with power button flashing..probably is the bios..i dont have bios file because accidentally i erased this with ch341a...can anyone help me with file bios to flash?i attached the photo with SN...thanks..
gs450&gs550&gs750 NM-C821
Rev 1.0Comment
Rev 1.0
post S/N,TYPE,etc.
Ciao, ho un Lenovo IdeaPad 15ADA05 con il pulsante di accensione lampeggiante. Probabilmente è il BIOS. Non ho il file BIOS perché l'ho cancellato accidentalmente con CH341A. Qualcuno può aiutarmi con il file BIOS da flashare? Grazie.
GS450&GS550&GS750 NM-C821Rev 1.0S/N pc20xnda
Hi, I have a Lenovo IdeaPad 15ADA05 with the power button flashing. It is probably the BIOS. I don't have the BIOS file because I accidentally deleted it with CH341A. Can anyone help me with the BIOS file to flash? Thanks.
Version 1.0
Serial number pc20xndaComment
Version 1.0
Attached Files↵
Hello guys, please help, black screen not booting bios. Lenovo V14-ADA 82C6 SN PF22W33AK. There is only a faulty bios dump.
This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...09-07-2024, 05:00 AM
by PatriarxisHello.
I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
It takes 0.027A and the power button flashing.
All the voltages on the board are ok. 3.3, 5 etc.
Also is charging the buttery .
What else i can check?05-26-2025, 01:03 AM -
First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...-
Channel: BIOS Requests ONLY!
by pcwhiz24Model: Lenovo IdeaPad 3 14ADA05 81W0
S/N: PF2BZS7D
I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
I already have a CH341A programmer...-
by Visual_vtLenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
SSD and BIOS seems to be OK.
Thank you.... - Loading...
