Dell FDI55 LA-J081P Rev 1.0 Bios Bin
I installed another bios, the USBs worked but I got a TPM error. So I would be glad if you could fix your own bios.Comment
After trying the BIOS from message 115, the USB ports started working. However, it gave a TPM error. There wasn’t a TPM error before, so I didn’t mention it earlier.Last edited by ay_bulut; 04-15-2025, 09:09 AM.Comment
Same board, same bios corrupt, board on with no picture
Inspiron 3793
service tag 51KT293
Can you please rebuild it for me?
I try to extract bios files from dell package, but can't find the 8MB file for EC only the 16MB
Thank youAttached FilesComment
Bios. Your original has some corruption in the ME firmware.Comment
bios.Comment
hello, please help me.
my bios has a problem, it won't power on even when the cmos battery is removed. I loaded another bios but after entering the service tag, it won't power on. Please help me
thanks a lot
servic tag: 1ZZZF13Attached FilesComment
tryAttached FilesComment
Dell inspiron 3493
service tag C2TH803
Express service26291832771
error TPM device is not detectedComment
hi try and feedebackAttached FilesComment
help plz hope its bios problem
Inspiron 3593
service Tag: G9MMB53
Original backup attached
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
- Loading...
