Many thanks to Hardware1 and the clean bios he uploaded in post #45. It worked fine in an Inspiron 3793 and eventually revived the machine. For reference, I had the 2 yellow and 3 white LED flashes, which is described by Dell as "RAM not detected". Flashing the bios has solved the problem and the device is working fine now.
Dell FDI55 LA-J081P Rev 1.0 Bios Bin
TPM NOT DETECTAttached FilesPremium supporters get full download access and other benefits.
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
8 MBAttached FilesPremium supporters get full download access and other benefits.
Inspiron 3493
Service Tag: C2TH803Attached FilesPremium supporters get full download access and other benefits.
LATE DISPLAY AND
some time detact ssd or some time not detacted. not detacted time show tpm error tpm not detacted
i this this is not orignal bios plz anyone build orignal bios for me
FDI55 LA-J081P
REV 1.0 (A00)
2019-07-26
dell inspiron 3593
p75f013Attached FilesPremium supporters get full download access and other benefits.
hi try
MOD EDIT: Delete invalid file FDI55 LA-J081P (REV 1.0) (A00) (2019-08-12).zipComment
Hi.
I might have corrupted BIOS, could I get another?
DELL Vostro 3501
Motherboard - FDI55 LA-J081P Rev 1.0 (A00)
ST - C46PLB3
Old BIOS in attachment (64mbit and 128mbit).
Thank you.Attached FilesPremium supporters get full download access and other benefits.
biosAttached FilesPremium supporters get full download access and other benefits.
i need fix bios la-j081p
no display
sv : BJ21V43Attached FilesPremium supporters get full download access and other benefits.
hi sir laptop is working good but after install intel grafics driver
screen has no display please helpAttached FilesPremium supporters get full download access and other benefits.
USBs work in bios screen. It doesn't work when desktop comes up. Can you please fix it?
la-j081p
service tag : 88C86C3
Inspiron 3501Attached FilesPremium supporters get full download access and other benefits.
by TeslaI have a Dell XPS-15 (9520) with the LA-L402P motherboard. It seems to have bricked itself after a common BIOS-Firmware upgrade. Now, it just shows BIOS screen for a few seconds before turning-itself back Off (and doesn't seem to be fully Posting). I've done these many times before with no problems.
I was hoping to please have my own-thread to work-through this (hopefully successful) repair as a whole. Apart from the possible need to have a BIOS-dump fixed-up, I have a feeling I'm going to have other questions. This includes using my new XGecu-T76 for the first time (should be here... -
Channel: BIOS Requests ONLY!
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by kantusjackHello,
I am troubleshooting a Dell XPS 12 with motherboard 9Q23 (Compal LA-8821P) that failed during a Windows 10 update. The system powered off abruptly and never booted again. Initial behaviour- No display at any time (internal or external)
- Power button would immediately shut the system off
- System auto-powers when AC adapter is connected (battery removed)
- Beep code: 3 beeps – pause – 3 beeps (continuous)
- Fan never spins
- Loading...
