Need Lenovo E590 NM-B911 bios dump
need clear bios this bios no dsplay.
nm-b911 FE490/FE590/FE480
TYPE 20N9_S1NX00
S/N;BF_224Q1AComment
Salam need rebuild bios lenovo thnkpad e590 i try many not working kindly build bios this i attached
Board NM-B911 rev 1.0 (Type 20nb-000had
S/n PF1N6D9SAttached FilesComment
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hallo friend, I have problem with Lenovo E590. After repair USB-C connector notebook can´t boot. After press power on button only beep some sound and I analyse it witch LenovoPCDiagnostik App as error 0284 (TCG-compliant functionality-related error). I search it and I read on some website, that maybe flash bios can help. Can you get me a bios dump for this motherboard please, or do you have some another idea?
Thank you so much for your reply!
Type: Lenovo E590 20NB-001YMC
S/N: PE-1GGEUV 19/08Comment
S/N: PE-1GGEUV 19/08Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Hallo, here is my dump:
Thank you so much!Attached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hallo,
sorry for writing to you again, but don´t you have some idea with my motherboard? After flash bios mother board no working. Only flashes slowly power led. Before flash BIOS notebook play melody whitch indicated error 0284. Now is complete quiet.
Thank you for reply!Comment
Hallo,
Thank you for reply!Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Thank you for reply. I try your BIOS and no working. Only blinking power LED slowly after power on (without melody). The fan doesn't even spin for a moment. For test I try flash my original BIOS and after power on play melody again. LCD is black. Only play melody, power LED lights up and CPU FAN spin for a moment. Do you think the motherboard can be defective?Comment
Apologies for asking for help
NM-B911 board, PLT_RST# present but no activity other than a backlight activation and 5V on USB/HDMI.
Tried a few other sample BIOS bin's here but none did anything ( in fact even worse ).
Original BIN attached here.
Type: 20NB-001TUS
SN: PF1LTR13 ( I think this is it, I had to reconstruct the barcode as the ASCII version was rubbed out and the barcode smeared )Attached FilesYouTube Repair Videos - https://www.youtube.com/user/19PLD73
FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbvComment
by AHmad_SalalHello all,
I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by JoluvillasHi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
Channel: BIOS Requests ONLY!
Hi, I hope this is the right place to post this. This is my first post on this forum.
A friend helped me get a prototype Lenovo motherboard from China, it's got a hole drilled in it but I'm working on trying to revive it to some degree. I dumped the bios in hopes that it might be useful to someone, since this board is configured with the 3rd NVMe SSD slot and maybe it is useful as a reference for modding another bios to support this function. For example the M90q Gen 2 / P350's unpopulated 3rd NVMe slot footprint maybe.
This bios dump is straight from the chip, nothing has been...-
by mrkmpnLenovo X1 Carbon 7th Gen Type 20R1
SN: PF1Y5BBJ
Board: GX490 NM-C661 Rev: 1.0
I have made two dumps of this bios, with the bios chip removed from the board and the hashes match on both dumps, but I cannot find the DMI information in the dumps except for the Windows product key, so I think it is corrupted. I have downloaded two bios updates from the Lenovo support site, but they contain small .PAT file, and 4 subfolders containing .FL1 and .FL2 files, which I don't understand enough to figure out how to use to fix my dump.
The problem with the laptop is that...-
- Loading...
