Need Lenovo E590 NM-B911 bios dump
  • Kartek
    • May 2020
    • 65
    • Türkiye
    #81
    Originally posted by hoaca388
    Review the serial number, it should be a string of 8 characters.
    It was a mistake to apologize. sn: PF-1DC7CC
    • Arsalan455
      • Oct 2019
      • 57
      • Pakistan
      #82
      need clear bios this bios no dsplay.
      nm-b911 FE490/FE590/FE480
      TYPE 20N9_S1NX00
      S/N;BF_224Q1A
      • aijazali
        • Dec 2019
        • 124
        • saudi arabia
        #83
        Salam need rebuild bios lenovo thnkpad e590 i try many not working kindly build bios this i attached
        Board NM-B911 rev 1.0 (Type 20nb-000had
        S/n PF1N6D9S
        • hoaca388
          Badcaps
          • Jan 2022
          • 12426
          #84
          Your "original" file is not from E590.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12426
            #85
            S/n PF1N6D9S
            E590 Laptop (ThinkPad) - Type 20NB
            • hoaca388
              Badcaps
              • Jan 2022
              • 12426
              #86
              TYPE 20N9_S1NX00
              S/N;BF_224Q1A
              Checked the serial number again. It got me nowhere.
              • aijazali
                • Dec 2019
                • 124
                • saudi arabia
                #87
                thank you dear i didn't check but in ME analyzer i got unconfigured your bios build is it work?
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12426
                  #88
                  ????? Click image for larger version
Name:	2024-11-26 08_16_48-Settings.png
                  • aijazali
                    • Dec 2019
                    • 124
                    • saudi arabia
                    #89
                    ok bro ME analyzer not up to date that's why thank you for build bios but still same issue I checked all volts are present's while pressing power btn only 1 scorned load ok then off any idea what kinda fault?
                    • Drakgon
                      • Nov 2020
                      • 23
                      • Czech Republic
                      #90
                      Hallo friend, I have problem with Lenovo E590. After repair USB-C connector notebook can´t boot. After press power on button only beep some sound and I analyse it witch LenovoPCDiagnostik App as error 0284 (TCG-compliant functionality-related error). I search it and I read on some website, that maybe flash bios can help​. Can you get me a bios dump for this motherboard please, or do you have some another idea?
                      Thank you so much for your reply!
                      Type: Lenovo E590 20NB-001YMC
                      S/N: PE-1GGEUV 19/08
                      • peste
                        • Dec 2016
                        • 13855
                        • ROMANIA
                        #91
                        post the original content of the bios chip, even if it is corrupted..
                        • Drakgon
                          • Nov 2020
                          • 23
                          • Czech Republic
                          #92
                          Hallo, here is my dump:
                          Thank you so much!
                          • peste
                            • Dec 2016
                            • 13855
                            • ROMANIA
                            #93
                            Thank you so much!
                            try..
                            • Drakgon
                              • Nov 2020
                              • 23
                              • Czech Republic
                              #94
                              try..
                              Hi, thank you for your file, but after flashing the laptop no longer plays the melody like before. After turning it on, the LED on the power button only flashes slowly.
                              Do you have some next ideas please?
                              Thank you for reply.
                              • Drakgon
                                • Nov 2020
                                • 23
                                • Czech Republic
                                #95
                                try..
                                Hallo,
                                sorry for writing to you again, but don´t you have some idea with my motherboard? After flash bios mother board no working. Only flashes slowly power led. Before flash BIOS notebook play melody whitch indicated error 0284. Now is complete quiet.
                                Thank you for reply!
                                • peste
                                  • Dec 2016
                                  • 13855
                                  • ROMANIA
                                  #96
                                  Hallo,
                                  then write the original bios again...
                                  • Drakgon
                                    • Nov 2020
                                    • 23
                                    • Czech Republic
                                    #97
                                    The laptop does not work with the original BIOS. I wrote that. I analyse it witch LenovoPCDiagnostik App as error 0284 (TCG-compliant functionality-related error)... I asked if you had any experience with this problem. Thank you.
                                      • 22203
                                      Try this bios, check your soldering carefully. If it doesn`t work or if it does boot but with the same error message you will have to replace the TPM chip with one from another lenovo donor board
                                      • Drakgon
                                        • Nov 2020
                                        • 23
                                        • Czech Republic
                                        #99
                                        Thank you for reply. I try your BIOS and no working. Only blinking power LED slowly after power on (without melody). The fan doesn't even spin for a moment. For test I try flash my original BIOS and after power on play melody again. LCD is black. Only play melody, power LED lights up and CPU FAN spin for a moment. Do you think the motherboard can be defective?​
                                        • inflex
                                          • Aug 2012
                                          • 545
                                          Apologies for asking for help
                                          NM-B911 board, PLT_RST# present but no activity other than a backlight activation and 5V on USB/HDMI.
                                          Tried a few other sample BIOS bin's here but none did anything ( in fact even worse ).
                                          Original BIN attached here.
                                          Type: 20NB-001TUS
                                          SN: PF1LTR13 ( I think this is it, I had to reconstruct the barcode as the ASCII version was rubbed out and the barcode smeared )
                                          YouTube Repair Videos - https://www.youtube.com/user/19PLD73
                                          FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
                                          • AHmad_Salal
                                            Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                            by AHmad_Salal
                                            Hello all,
                                            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                            11-28-2023, 05:28 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            ✅ What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
