HP EliteBook 845 G7 BIOS Pass
  • kpassako
    • 9
    • ivory coast
    #81
    Re: HP EliteBook 845 G7 BIOS Pass
    Originally posted by kangajoe
    I have found that much of the information in many forums around this problem have been missing a lot of vital information.
    After my own research and experience I have documented exactly what worked for me.
    I hope that others may find this helpful.
    Thanks i solved the problem with this method using back dump ...
    • dariuxzy
      • Mar 2023
      • 41
      • italy
      #82
      I wanted to remove the password in my hp elitebook 845 g7, but initially when I unsoldered the W25Q256JV chip (bottom), I broke a pin and I couldn't even make a backup... so I bought a new W25Q256JV chip, I programmed it with one of the bin files already modified by some user in this thread, but the laptop doesn't start and "caps lock" blinks 7 times. Any suggestions? Thank you so much
      • alfredposadas09
        • Aug 2020
        • 343
        • Philippines
        #83
        i think your laptop is already dead.. the ec and main must be match
        • dariuxzy
          • Mar 2023
          • 41
          • italy
          #84
          i should try programming both bios and ec, again with someone's already modified bin files. I have programmed only the EC
          • Arrow16
            • Apr 2022
            • 229
            • Philippines
            #85
            Bios lock, i cannot find active region this time i need some help remove bios lock, tnx
            • Arrow16
              • Apr 2022
              • 229
              • Philippines
              #86
              Up
              • Arrow16
                • Apr 2022
                • 229
                • Philippines
                #87
                Need help
                • anhbanxoi
                  • Sep 2021
                  • 173
                  • VN
                  #88
                  Need help
                  Try
                  • dariuxzy
                    • Mar 2023
                    • 41
                    • italy
                    #89
                    Originally posted by Vesko356
                    Next - program both spi chips with the corresponding files from the attached archive and you're good to go.
                    I tried to program both the bios and the EC but now the caps lock flashes 7 times. Unfortunately I had to use these files, as I broke the EC chip "25Q256JVEN", so to match both the bios and the new EC, I thought of programming the files of some other computer the same. What should I do? Thanks
                    Edit: the weld is perfect and have been programmed correctly
                    • dariuxzy
                      • Mar 2023
                      • 41
                      • italy
                      #90
                      HP EliteBook 845 G7 bios cleared request
                      hey, i'm looking for clean bios and ec dumps, i tried to flash both with files taken in a thread but the laptop won't start and caps lock blinking 7 times (I guess because they are not clean)
                      I don't have the original backup up because the original ec i broke it before i even read it..., so i buy another one!
                      Thank you so much, I'm losing my mind for this laptop!
                      Bios: MX25L25673
                      EC: W25Q256JVEN
                      Motherboard: LINDEN-6050A3147201-MB-A01(A1)
                      • dariuxzy
                        • Mar 2023
                        • 41
                        • italy
                        #91
                        Re: HP EliteBook 845 G7 bios cleared request
                        Bios: MX25L25673
                        EC: W25Q256JVEN
                        Please help
                        • dariuxzy
                          • Mar 2023
                          • 41
                          • italy
                          #92
                          Bios: MX25L25673
                          EC: W25Q256JVEN
                          I noticed that the new EC chip I bought has a different code... W25Q256JVEM, but the original is W25Q256JVEN. Could this be the cause of the laptop blinking 7 times caps lock? Thanks
                          • dariuxzy
                            • Mar 2023
                            • 41
                            • italy
                            #93
                            Bios: MX25L25673
                            EC: W25Q256JVEN
                            Up
                            • Dan20701
                              • Sep 2020
                              • 199
                              • United Kingdom
                              #94
                              Hello all, Can someone please unlock this bios, its the original chip
                              Winbond 256mb. I tried RCUnlocker.
                              HP EliteBook 845 G7, Thanks so much.
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #95
                                Upload the dump from the second chip (U366-at the back of the board).
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                • Dan20701
                                  • Sep 2020
                                  • 199
                                  • United Kingdom
                                  #96
                                  Thanks mate, I will have to wait till I get back from Spain
                                  I have a wedding to go to, I will upload the file when I am back.
                                  busy packing today. Thanks again mate.
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #97
                                    You're welcome! Have fun at the wedding!
                                    • Dan20701
                                      • Sep 2020
                                      • 199
                                      • United Kingdom
                                      #98
                                      Hello mate I am back now, Just got around to reading this chip, Here is the second dump, Thanks mate.
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #99
                                        Program this chip only, leave the other as is. At fist boot enter the bios and reset security settings to default:
                                        • Dan20701
                                          • Sep 2020
                                          • 199
                                          • United Kingdom
                                          #100
                                          Thank you very much for being so quick.
                                          Thanks.
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • jotati7062
                                            Hp Elitebook 860 G10 Admin/bios Pass
                                            by jotati7062
                                            Hello guys, I saw your posts of "hoaca388" on this fourm helping others which is very nice of him,
                                            i do have an HP 860 G10 LOCKED, i looked at the bytes he change after an unlock and applied the same on my bios file but i get error that "bios was recovered from EC chip due to data mismatch, do you guys think you can help? if so here is my main bios backup, if i have to backup EC chip, i will, Thank you so much...
                                            Yesterday, 04:33 AM
                                          • zlr8r
                                            looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                            by zlr8r
                                            looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                            cheers
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                            Attached;
                                            1. My saved bios using a programmer
                                            2. Dells Bios updater .exe (v1.16)
                                            3. Dells Bios recovery file
                                            4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                            5. Image of ME...
                                            12-18-2023, 03:08 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
