Can someone help me remove the password?
Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
HP EliteBook 845 G7 BIOS Pass
Every donation made will go towards server fees and maintenance costs.Comment
hi tryAttached FilesPremium supporters get full download access and other benefits.
Can someone help me remove the password? This is the stock bin file from the bottom chip.
HP ELITEBOOK 845 G7
S/N: 5CG1160KY3
ProdID: 33K13PC#UUF
MOTHERBOARD: LINDEN-6050A3147201-MB-A01 (A1)Comment
Thank you. I compare it to the one I edited using HxD, and it says its the same, so I guess we edit the same thing on the file. However, already did try this and it's still asking for bios password.
Also, should I boot the laptop to bios first ? or its just fine to boot it normally, because in my case it boot normally first, and when I boot to bios its still asking for Password, and try to read the bin file again, and the hex/code revert back to stock.Comment
Hi !
Can anyone repair my BIOS ?
HP Elitebook 845 G7
ProdID : 2E1J9UC#ABU
Warranty : 3y3y0y
SN : 5CG0521016
Thanks !Attached FilesPremium supporters get full download access and other benefits.
PLEAS ULOCK
HP ELITEBOOK 845 G7
S/N: 5CG1161Z79
ProdID: 3A6N3EC#ABD
MOTHERBOARD: LINDEN-6050A3147201-MB-A01 (A1)Attached FilesPremium supporters get full download access and other benefits.
Hi, I backed up main BIOS (Winbond 25Q256JVEN, HP ELITEBOOK 845 G7) and I tried to removing the password in HxD, but I can't find NvramActiveRegn between lines 00037000 etc... as if the password wasn't there. BUT actually it's asking for it. Can anyone help me? Thanks.Attached FilesPremium supporters get full download access and other benefits.
HP EliteBook 845 G7 Notebook PC
Serial_2TK13100N6
Product_1V4L6AV
Build Id_20WWLDDT601#SABA#DABA
Fearture byte_3X476J6S6b7B7H7M7Q7W7m7s8uaBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEnW.D3
* NvramActiveRegn is in the EC chip.Attached FilesPremium supporters get full download access and other benefits.
https://www.badcaps.net/donateComment
What's the difference between this file you sent me? Do I have to flash it? ThanksComment
hello, after an incompleted bios update this hp elitebook 845 g7 stopped working normally. now it gives the endpoint error then keep rebooting to the same error with fan at max.
SN: 5CG1158TXQ
Decription_HP EliteBook 845 G7 Notebook PC
Serial_5CG1158TXQ
Sku_2H0J3UC#ABA
Build Id_20WWLDCT601#SABA#DABA
Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdUdpdqeMfPfXguhKhkjhk8mEmV.yd
tahnk you it worked as a sharm. i still have a problem of missing hosted factory mac adderess. even after using bcu i couldnt find it. also in advenced bios settings it shows as 00Comment
PLEAS ULOCK bios pass
HP ELITEBOOK 845 G7
S/N: 5CG051226R
ProdID: 2M5C3ES#ABD
hp elitebook 845 g7 AMD RYZEN 5 PRO bios passwordAttached FilesPremium supporters get full download access and other benefits.
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by WutruHi guys,
If someone would be able to provide some expertise, I'd be very grateful.
BIOS Corruption - Cause
So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....-
Channel: BIOS Requests ONLY!
by macabookHello everyone,
07-24-2025, 02:17 PM -
by jotati7062Hello guys, I saw your posts of "hoaca388" on this fourm helping others which is very nice of him,
i do have an HP 860 G10 LOCKED, i looked at the bytes he change after an unlock and applied the same on my bios file but i get error that "bios was recovered from EC chip due to data mismatch, do you guys think you can help? if so here is my main bios backup, if i have to backup EC chip, i will, Thank you so much...-
by PmipasHello Newbie here, i recently got my hands om a elitebook 845 g11. For the last week i have been looking for ways to get this laptop functional
When starting I get a picture from wolf Security then bios Windows startup.
If i try other bot options the only options available are Windows on the hdd or a boot option from the Ethernet port
So bios is secured by a password and i have been reading about how to flash the main bios with CH341A + SOIC8 Clip. But no one seems to be successful with this method.
I know enough to post a dump of the main bios here but from what... - Loading...
