HP EliteBook 845 G7 BIOS Pass
  • pnilip
    • Mar 2021
    • 9
    i have read many post on google and here about bios pass removal from various hp models but i couldn´t find any information about a HP Elitebook 845 G7
    i found the bios chip on the board. it is a winbond 25Q256JVEN
    i don´t have a dump right now because i don´t have the correct programmer.
    but before ordering a programmer i want to ask about the procedur.
    at first i will have to order a TL866II PLUS and create a dump from the winbond.
    but after that? will the HPUnlocker be able to remove the password?
    or can the dump be edited via a hexeditor so the bios has a clean password? i saw that in a youtube video but not sure if this work on newer models.
    is it even possible to erase bios passwords on such a new model?
    im happy about any information which helps me making some progress
    kind regards
    pnilip
  • Bonzas
    • 475
    • Indonesia
    Re: HP EliteBook 845 G7 BIOS Pass
    Please try this bios when your programmer arrives, but compare it with your backup before flashing.
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      No
      You should read both main bios and EC bios. One is 256Mb, other should be 128Mbit. Then upload them here.
      • pnilip
        • Mar 2021
        • 9
        thanks for the fast replies
        where do i find the ec chip? is it one of the red marked ones on the pictures below? i don´t wanne order the programmer if i´m not sure that i can fix the bios.
        again thanks in advance for helping me out
        • Akintunde
          • Mar 2017
          • 160
          • Nigeria
          • Reading
          Good day Everyone, Please i need Advice on which BIOS programmer to buy that support
          256Mb and 128Mb
          • sh4rp
            • Apr 2021
            • 8
            • Slovensko
            Akintunde: I have sucessfully used Revelprog IS very neat, works well and easy to use. (no affiliation)
            And as I cannot post a new thread yet. I will hijack (and resurrect) this thread instead.
            To my question now:
            I have aswell an HP 845 G7 with a power-on password, which I have accidentally set, both password and fingerprints don't work to my disappointment. HP Support suggested to replace the main board (which is about 80-90% of the price of the device, great help...) I have set also some recovery questions, which are however neatly disabled by default...
            Anyway, to the point... I have identified both flash chips one is a MX25L25673G and the other a W25Q256JV as mentioned by OP both 256 MBit.
            I made the dumps: https://1drv.ms/u/s!AvOVJlqOmxV_mGv9...OtKu1?e=IPb8kN
            Can someone help with them?
            Also a tip: do not connect the flash chip with wires "in air" (in picture), it will not work even though the wires are (relatively) short.
            I made 6 reads, progressivelly lowering the clock rate, but the every time the read was different, so obviously it was reading garbage. Well... it was in the manual of the programmer, so I have been warned.
            So I made some WSON-8 6x4 adapters and everything was well.
            This is a week old laptop (well... I used it for a week...), and I would really like to fix it. So any help is apreciated.
            • sh4rp
              • Apr 2021
              • 8
              • Slovensko
              pnilip:
              The other chip is on the other (bottom) side of the board - directly under the Winbond (in your case... for some reason I had the Winbond on the bottom...).
              So you have to disconnect all the wires and remove the screws. Also I didn't unscrew the cpu fan so I don't have to mess with thermal paste.
              • sh4rp
                • Apr 2021
                • 8
                • Slovensko
                HP EliteBook 845 G7 (8VZ07AV) Power-on password
                Hello I need to remove Power-on password on this notebook HP EliteBook 845 G7 Notebook PC (8VZ07AV).
                Product Number: 24Z96EA
                Board: LINDEN-6050A3147201-MB-A01(A1)
                Board part no: m22244-601
                The chips are:
                Winbond W25Q256JVEN (256Mbit) U366/U365 Bottom side
                MXIC MX25L25673GZ4I-08G (256Mbit) U367 Top side
                Dump of both BIOS chips in attachment.
                Please help.
                Winbond - location picture - bottom side:
                Winbond closeup:
                MXIC - location picture - top side:
                MXIC closeup:
                • peste
                  • 14876
                  • ROMANIA
                  Re: HP EliteBook 845 G7 (8VZ07AV) Power-on password
                  replace the contents of the MX25L25635E bios chip with the bios extracted from the update on the HP site..the other chip remains with the original bios of the laptop ..
                  If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
                  It only takes 1 minute:
                  https://www.badcaps.net/settings/subscriptions
                  • sh4rp
                    • Apr 2021
                    • 8
                    • Slovensko
                    Thx for the suggestion, unfortunatelly the pc won't boot in this setting...
                    • peste
                      • 14876
                      • ROMANIA
                      replace both contents of the bios chips with the same update on the site.
                      • pnilip
                        • Mar 2021
                        • 9
                        pnilip:
                        @sharp
                        Thanks for your answer and sorry for the late reply, but i didnot have much time past weeks.
                        Having the second chip on the lower side of the board, i read on threads about other models but because of no time i wasn´t able to have a look at. today i took the time and unscrewed the board.
                        But as you can see on the pictures added, i have two winbonds (both 256Mbit) on my board. So how do you know that the MX25L25673G was the right one to chose on your board???
                        Can anybody of the pros tell me if i should now just order a TL866II PLUS, create dumps of each chip and post them here? or am i doing sth wrong??
                        Upperside:
                        Lowerside:
                        • sh4rp
                          • Apr 2021
                          • 8
                          • Slovensko
                          @pnilip
                          I think it doesn't really matter which actual chip it is. But so far I have been unable to fix it. I tried multiple times to flash it with different flashes and some ppl were tinkering with the source code to fix it. But no luck. It's a bit frustrating, and you have to solder, desolder the chips plug all the cables back so on.
                          After looking through the code I found some account details on the U367(top) chip ie. my name that shows on the lock screen in the actual code. So I suppose the U367(top) chip is more important.
                          • pnilip
                            • Mar 2021
                            • 9
                            @pnilip
                            hello again. today i finally managed to read both chips properly.
                            at first i tried to read and create backups without desoldering the chips with a selfmade probe made out of wires and pogo pins. but with no luck. everytime different results when comparing the backups. reason was that i´m a bit afraid of destroying the board/chips when de- and resoldering the chips over and over again. hope that someone can remove password from attached files and it works on first try.
                            so because of my flop with selfmade tool, i ordered a wson8 connector, desoldered both chips with hotair. and created 3 backups from each chip and compared the backups with a hexeditor. this time everthing went well.
                            @RethoricalCheese: can you please have a look at the files attached and customize/remove pass for me?
                            hopefully the long waiting times for my orders and the money spent will be worthwhile
                            thanks in advance
                            • peste
                              • 14876
                              • ROMANIA
                              thanks in advance
                              try this..modify only this bios ... the other one stays the same ..
                              • pnilip
                                • Mar 2021
                                • 9
                                many thx for trying but still asking for password
                                • peste
                                  • 14876
                                  • ROMANIA
                                  replace only this bios ... the other one remains the same ..
                                  • pnilip
                                    • Mar 2021
                                    • 9
                                    thanks again for having a try. i again only flashed your modified bin file to the bottom chip (U367).
                                    this time something happened. took some time the fan went to full speed and it showed:
                                    after some time showed:
                                    i pressed ok, it restarted, showed:
                                    when trying to enter bios, still shows:
                                    any ideas?
                                    //edit:
                                    i noticed that now i could boot from usb stick. maybe a chance to install clean bios via usb hp update?
                                    • peste
                                      • 14876
                                      • ROMANIA
                                      the bios has been updated ..can you change something in the bios ???
                                      • pnilip
                                        • Mar 2021
                                        • 9
                                        i cant access bios. see last picture in my last post. still asking for password.
                                        but usb boot was disabled on original bios. now it works.
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • Wutru
                                          HP Elitebook 820 G4 BIOS repair assistance required
                                          by Wutru
                                          Hi guys,
                                          If someone would be able to provide some expertise, I'd be very grateful.
                                          BIOS Corruption - Cause
                                          So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                          After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                          09-06-2025, 10:32 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • jotati7062
                                          Hp Elitebook 860 G10 Admin/bios Pass
                                          by jotati7062
                                          Hello guys, I saw your posts of "hoaca388" on this fourm helping others which is very nice of him,
                                          i do have an HP 860 G10 LOCKED, i looked at the bytes he change after an unlock and applied the same on my bios file but i get error that "bios was recovered from EC chip due to data mismatch, do you guys think you can help? if so here is my main bios backup, if i have to backup EC chip, i will, Thank you so much...
                                          08-13-2025, 04:33 AM
                                        • Pmipas
                                          HP Elitebook 845 g11. Bios impossible?
                                          by Pmipas
                                          Hello Newbie here, i recently got my hands om a elitebook 845 g11. For the last week i have been looking for ways to get this laptop functional
                                          When starting I get a picture from wolf Security then bios Windows startup.
                                          If i try other bot options the only options available are Windows on the hdd or a boot option from the Ethernet port
                                          So bios is secured by a password and i have been reading about how to flash the main bios with CH341A + SOIC8 Clip. But no one seems to be successful with this method.
                                          I know enough to post a dump of the main bios here but from what...
                                          02-10-2026, 04:48 PM
