HP EliteBook 845 G7 BIOS Pass
  • kpassako
    • 9
    • ivory coast
    #81
    Re: HP EliteBook 845 G7 BIOS Pass
    Originally posted by kangajoe
    I have found that much of the information in many forums around this problem have been missing a lot of vital information.
    After my own research and experience I have documented exactly what worked for me.
    I hope that others may find this helpful.
    Thanks i solved the problem with this method using back dump ...
    • dariuxzy
      • Mar 2023
      • 44
      • italy
      #82
      I wanted to remove the password in my hp elitebook 845 g7, but initially when I unsoldered the W25Q256JV chip (bottom), I broke a pin and I couldn't even make a backup... so I bought a new W25Q256JV chip, I programmed it with one of the bin files already modified by some user in this thread, but the laptop doesn't start and "caps lock" blinks 7 times. Any suggestions? Thank you so much
      • alfredposadas09
        • Aug 2020
        • 342
        • Philippines
        #83
        i think your laptop is already dead.. the ec and main must be match
        • dariuxzy
          • Mar 2023
          • 44
          • italy
          #84
          i should try programming both bios and ec, again with someone's already modified bin files. I have programmed only the EC
          • Arrow16
            • Apr 2022
            • 229
            • Philippines
            #85
            Bios lock, i cannot find active region this time i need some help remove bios lock, tnx
            • Arrow16
              • Apr 2022
              • 229
              • Philippines
              #86
              Up
              • Arrow16
                • Apr 2022
                • 229
                • Philippines
                #87
                Need help
                • anhbanxoi
                  • Sep 2021
                  • 178
                  • VN
                  #88
                  Need help
                  Try
                  • dariuxzy
                    • Mar 2023
                    • 44
                    • italy
                    #89
                    Originally posted by Vesko356
                    Next - program both spi chips with the corresponding files from the attached archive and you're good to go.
                    I tried to program both the bios and the EC but now the caps lock flashes 7 times. Unfortunately I had to use these files, as I broke the EC chip "25Q256JVEN", so to match both the bios and the new EC, I thought of programming the files of some other computer the same. What should I do? Thanks
                    Edit: the weld is perfect and have been programmed correctly
                    • dariuxzy
                      • Mar 2023
                      • 44
                      • italy
                      #90
                      HP EliteBook 845 G7 bios cleared request
                      hey, i'm looking for clean bios and ec dumps, i tried to flash both with files taken in a thread but the laptop won't start and caps lock blinking 7 times (I guess because they are not clean)
                      I don't have the original backup up because the original ec i broke it before i even read it..., so i buy another one!
                      Thank you so much, I'm losing my mind for this laptop!
                      Bios: MX25L25673
                      EC: W25Q256JVEN
                      Motherboard: LINDEN-6050A3147201-MB-A01(A1)
                      • dariuxzy
                        • Mar 2023
                        • 44
                        • italy
                        #91
                        Re: HP EliteBook 845 G7 bios cleared request
                        Bios: MX25L25673
                        EC: W25Q256JVEN
                        Please help
                        • dariuxzy
                          • Mar 2023
                          • 44
                          • italy
                          #92
                          Bios: MX25L25673
                          EC: W25Q256JVEN
                          I noticed that the new EC chip I bought has a different code... W25Q256JVEM, but the original is W25Q256JVEN. Could this be the cause of the laptop blinking 7 times caps lock? Thanks
                          • dariuxzy
                            • Mar 2023
                            • 44
                            • italy
                            #93
                            Bios: MX25L25673
                            EC: W25Q256JVEN
                            Up
                            • Dan20701
                              • Sep 2020
                              • 202
                              #94
                              Hello all, Can someone please unlock this bios, its the original chip
                              Winbond 256mb. I tried RCUnlocker.
                              HP EliteBook 845 G7, Thanks so much.
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #95
                                Upload the dump from the second chip (U366-at the back of the board).
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                • Dan20701
                                  • Sep 2020
                                  • 202
                                  #96
                                  Thanks mate, I will have to wait till I get back from Spain
                                  I have a wedding to go to, I will upload the file when I am back.
                                  busy packing today. Thanks again mate.
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #97
                                    You're welcome! Have fun at the wedding!
                                    • Dan20701
                                      • Sep 2020
                                      • 202
                                      #98
                                      Hello mate I am back now, Just got around to reading this chip, Here is the second dump, Thanks mate.
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #99
                                        Program this chip only, leave the other as is. At fist boot enter the bios and reset security settings to default:
                                        • Dan20701
                                          • Sep 2020
                                          • 202
                                          #100
                                          Thank you very much for being so quick.
                                          Thanks.
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • jotati7062
                                            Hp Elitebook 860 G10 Admin/bios Pass
                                            by jotati7062
                                            Hello guys, I saw your posts of "hoaca388" on this fourm helping others which is very nice of him,
                                            i do have an HP 860 G10 LOCKED, i looked at the bytes he change after an unlock and applied the same on my bios file but i get error that "bios was recovered from EC chip due to data mismatch, do you guys think you can help? if so here is my main bios backup, if i have to backup EC chip, i will, Thank you so much...
                                            08-13-2025, 04:33 AM
                                          • zlr8r
                                            looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                            by zlr8r
                                            looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                            cheers
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                            Attached;
                                            1. My saved bios using a programmer
                                            2. Dells Bios updater .exe (v1.16)
                                            3. Dells Bios recovery file
                                            4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                            5. Image of ME...
                                            12-18-2023, 03:08 PM
