Lenovo Thinkpad T480 BIOS and EEPROM request
    • 22203
    Originally posted by Luis Martin
    this bios
    Extract the attached zip folder, make a USB recovery drive with mkusbkey.bat ,boot from the USB drive and it will or should update the bios and EC.
    • Luis Martin
      • Jun 2025
      • 5
      Thanks!, it works. IDK what the EC (Embedded Control) was, but I do a quick search on Chat-GPT explained very good even teach me how to modify hex data using hex editor programs.
ID:	3655880 Click image for larger version
        SMDFlea commented
        Editing a comment
        You`re welcome :-)
    • zlo13666
      • Apr 2023
      • 9
      • Ukraine
      #163
      Pls help me to fix no boot/black screen(melody) on my T480 i7/mx150.
      Type 20L6-S29D08 S/N: PF-1J954M
      Few months ago it was purchased as dead. Some dump from here was helped but now its not booting just melody
      • hoaca388
        Badcaps
        • Jan 2022
        • 12426
        #164
        T480 Laptop (ThinkPad) - Type 20L6
        • zlo13666
          • Apr 2023
          • 9
          • Ukraine
          #165
          Same issue. Just melody((
          • Stefan Steff
            • Mar 2024
            • 389
            • Romania
            #166
            How about this dump?
            Test and provide feedback.
            • zlo13666
              • Apr 2023
              • 9
              • Ukraine
              #167
              Same issue. Possible its not bios issue
              • Stefan Steff
                • Mar 2024
                • 389
                • Romania
                #168
                Yes, indeed it's possible you have an LCD, Touchpad or RAM problem...from my "musical" experience with Lenovos
                Good luck!
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1356
                  • France
                  #169
                  the keyboard responds (caps lock indicator light).
                  if yes, start by disconnecting the battery and then disconnecting the screen from the motherboard.
                  test on an external screen
                  or use lenovo diagnostic for melody
                  • zlo13666
                    • Apr 2023
                    • 9
                    • Ukraine
                    #170
                    error 0001. Connected to board only wlan module and ram stick. Using original charger from T15 gen2.
                    • zlo13666
                      • Apr 2023
                      • 9
                      • Ukraine
                      #171
                      Good luck!
                      ram replaced again, tested with/without LCD. Caps lights up for a few seconds only...
                      • kapiras
                        • Jun 2025
                        • bobr Kurwa
                        #172
                        Has anyone tried shorting eeprom chip of t480 laptop.? i heard that on older models shorting just before bios setup removes bios pasword, like in this video https://www.youtube.com/watch?v=FW-RLkzjAS8
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1356
                          • France
                          #173
                          https://www.badcaps.net/forum/troubl...-ec-pwd-bypass
                          • JoshaintPosh
                            • Jul 2025
                            • England
                            #174
                            T480
                            info from bios
                            M 20L6S38300
                            S/N PF-159HEV
                            M/B L1HF88t003h
                            intel i7 8th gen
                            please Help
                            i got a bricked T480 and got my self a ch341a and flash the bios that I have attached this did not work and after trying different .bin files I tried to flash heads this work and then after re-flashing with the attached bios it worked and have done a USB bios utility update which worked since then have done a full Lenovo Diagnostics which found nothing wrong. Though, I think the PCIe cable is broken. So I have tied to boot form USB and two things have happened when I used balenaetcher is says error file '/boot/' not found and when using Ventoy and using normal boot it most often it is just blank with a _ in the top left of the screen when using grub2 and don't select anything after a few seconds it goes to Ubuntu loading screen but nothing happens if you actively select you get a load of text that according to Google Lens means something about security_inode_alloc I have also had xz corrupted data come up once have i flashed the bios wrong or is it the TB 3 flashing that is coursing it. After pressing the ESC key when Ubuntu is stuck loading, this comes up ​
                            Thanks in advance
                            F
                            • Bunkee
                              • Jul 2025
                              • 3
                              S-L-O-W boot times.
                              I recently acquired a ThinkPad T480 - Type 20L6-S0HG00, Build date: 18/05, S/N: PF17SPX4, Intel i7 - 8th generation with a locked / supervisor password protected BIOS. I successfully patched the BIOS using the autopatch instructions I found on here. BIG thanks to Knucklegrumble!
                              After patching and flashing, per the instructions I set BIOS settings to their default and then updated the old BIOS that it came installed with (dated 2018) to the newest 03.2025 BIOS from Lenovo's official site. I now experience unusually long boot times that take 19 seconds just to get to the red LENOVO logo and 68 seconds to get to the Linux Mint logon screen. This is with a NVMe SSD and 32GB RAM. I have read about cleaning the ME Region. Could this be the answer to the horribly long boot times?
                              • Bunkee
                                • Jul 2025
                                • 3
                                [ADDED INFO]
                                systemd-analyze
                                Startup finished in 31.776s (firmware) + 6.613s (loader) + 12.448s (kernel) + 14.378s (userspace) = 1min 5.217s
                                • Birdsbeinair
                                  • Jul 2025
                                  • 4
                                  • Chile
                                  #177
                                  Hello! My Aliexpress-bought motherboard was very problematic when trying to get any stable Windows installation on it, so I tried updating the bios in case it was the culprit but the process failed miserably and now it just sings Error code 0285. Managed to read the Winbond 25Q128JVSQ chip by desoldering it (otherwise it would crash my CH341A) but I did it under the "25Q128JV" label that AsProgrammer lists, so I wonder if it's a valid bios dump even?
                                  Model: T480
                                  Bios Version(suspected to crash Windows?): N24ET49W (1.24 )
                                  board No: ET480 NM-B501 (2018)
                                  s/n: PF-1JGUWZ 18/12
                                  System Board serial number: L1HF8CC01TT
                                  Machine Type: 20L6-S3PV00
                                  CPU: Intel Core i5-8350U
                                  Requesting a working Bios to recover functionality of the machine, and also so I can confirm the old one crashed Windows or not.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12426
                                    #178
                                    Model: T480
                                    • Birdsbeinair
                                      • Jul 2025
                                      • 4
                                      • Chile
                                      #179
                                      Hey, thank you for the reply! Unfortunately this Bios didn't work for me, the machine just blinks 3 times when I plug it in but shows no other signs of life. 😞
                                      • Stefan Steff
                                        • Mar 2024
                                        • 389
                                        • Romania
                                        #180
                                        ...and how about this dump?
                                        It had worked on 2-3 other laptops that i fixed...
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          10-24-2025, 01:35 AM
                                          Lenovo ThinkPad T480 Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 03:21 PM
                                          09-06-2024, 02:34 PM
                                          09-06-2024, 02:28 PM
