Lenovo Thinkpad T480 BIOS and EEPROM request
  • Birdsbeinair
    • Jul 2025
    • Chile
    #181
    Originally posted by Stefan Steff
    ...and how about this dump?
    It had worked on 2-3 other laptops that i fixed...
    Sorry for the late reply, I've been busy with some work. YES! This one worked!! 😁 But... Windows installations are as unstable as they were before the botched Bios update, and some Linux distros do install but it takes a lot of effort to make it happen. I believe this motherboard may be broken after all, but in such a weird way that I can't pinpoint exactly how, and sadly we can't refund it anymore. Still, thanks everyone involved for your time and support, I learned a lot from this!
    • Dzony83
      • Feb 2021
      • 20
      • Sweden
      #182
      I have a Lenovo T480 that is locked with an administrator password.
      I tried Auto-Patcher, and while it worked perfectly on some computers, on this one, I only get beeping and a black screen. What am I doing wrong?
      Lenovo T480
      Board: L1HF89T0373
      SN: PF1F28LP
    • hyper x
      • May 2025
      • 9
      • india
      #183
      HI IN LENOVO T480 HAS BIOS PASSWORD PLS HELP ME OUT
      SN - PF-1MMQ2U
      MODEL - T480 LENOVO
      PN- SL10R03187
      • hoaca388
        Badcaps
        • Jan 2022
        • 12429
        #184
        SN - PF-1MMQ2U
        MODEL - T480 LENOVO
        PN- SL10R03187
        https://www.badcaps.net/forum/troubl...ssword-removal
        • Dzony83
          • Feb 2021
          • 20
          • Sweden
          #185
          Lenovo T480
          Board: L1HF89T0373
          SN: PF1F28LP
          SMDFlea - Thank you for your help, but when I try that file, the BIOS remains locked.
          For example, with the original BIOS, I can skip the login and enter the BIOS (of course, I can't change anything), but with this BIOS, I don't even have that option.
            • 22216
            That bios still needs patching
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3634
              • slovakia
              #187
              have anybody dump form U15 with dump from U49?
              • Dzony83
                • Feb 2021
                • 20
                • Sweden
                #188
                Honestly, I'm a little embarrassed that it didn't occur to me at all But we are still learning, it will get better over time with fewer silly questions
                Of course I managed to remove the password when I did the patch... And of course, now I have another problem, which is Autopilot. On a couple of computers, I successfully removed Autopilot by following the instructions from volinakis, but on this one I don't see that Autopilot exists at all, and yet when I install Windows 11, it's still tied to the company. I assume something else needs to be changed, but I don't know what exactly?
                  • 22216
                  Perhaps volinakis or maxpower3 or someone else can help with that, i`m not sure what to do
                  • Stefan Steff
                    • Mar 2024
                    • 391
                    #190
                    Please try this modded (1 byte diff) bios for autopilot disable...if it's not working then probably you need to rewrite the SIO chip.
                    • Dzony83
                      • Feb 2021
                      • 20
                      • Sweden
                      #191
                      It actually works perfectly! Autopilot has been successfully removed.
                      Thanks for the help! I would be grateful if you could write down exactly what you changed, so I can try to do it myself in the future
                      I also want to thank SMDFlea for the selfless help! Well done, guys!
                      • badiycbo
                        • Sep 2025
                        • 6
                        • Sweden
                        #192
                        Hello, I bricked my bios when the spi flasher disconncted mid libreboot install. I've tried multiple bios files from this thread and changing the mac address etc but nothing works, the power button just blinks 3 times when connecting charger, any help with getting a working bios would be much appreciated.
                        Thinkpad T480 i7-8550u
                        Board: 20L5-CTO1WW
                        S/N: PF-1596D1
                        I lost the original dumps but these are the current ones on the board, let me know if more info is needed.
                        Thanks in advance
                        • Gurmeet yadav
                          • Nov 2023
                          • 8
                          • India
                          #193
                          lenovo t450
                          serial no is not available on sticker
                          nm-b501
                          no display BLACK SCREEN...TURN OFF AFTER 30 SECOND
                          help
                          • badiycbo
                            • Sep 2025
                            • 6
                            • Sweden
                            #194
                            Board: 20L5-CTO1WW
                            S/N: PF-1596D1
                            Thanks in advance
                            This thread does not seem to be very active anymore but if any knowledgeable person ends up reading this even a simple attempt to point me in the right direction would make me eternally grateful.
                            At this point I've tried a couple BIOSes posted in this thread and also extracting their bios region, replacing the mac address with the one i backed up before i bricked the computer (using hexedit) and stitching it to the BIOS region of my bios dump but nothing has worked. All i get is a black screen and the powerbutton blinks 3 times when i plug it in, but does not react to presses.
                            I'm completely out of ideas at this point so if anyone knows a potential fix or if there is further modification needed to the bios before flashing or something like that, Ill try anything at this point.
                            Wizards of badcaps.net I call upon thee
                            • Stefan Steff
                              • Mar 2024
                              • 391
                              #195
                              Did you try this dump ?
                              • badiycbo
                                • Sep 2025
                                • 6
                                • Sweden
                                #196
                                Wow that was quick, thanks for taking the time trying to help! I think I did but I could try again to make sure. Do you mean to just flash it as is, or should i extract the bios region and replace the mac address etc?
                                • Stefan Steff
                                  • Mar 2024
                                  • 391
                                  #197
                                  First read and backup your existing bios content as is the whole W25Q128JV chip content I mean...
                                  Then write the file I have sent as is.
                                  Your DMI info it's in EC so it should work as is.
                                  • badiycbo
                                    • Sep 2025
                                    • 6
                                    • Sweden
                                    #198
                                    Unfortunately no result, i'll tell you exactly what I did.
                                    1. removed external battery
                                    2. open chassi
                                    3. disconnected internal battery
                                    4. connected ch341a spi flasher to W25Q128JV chip
                                    5. read the chip using flashrom:
                                    Code:
                                    sudo flashrom -p ch341a_spi -c "W25Q128.V" -r backup.bin
                                    flashrom v1.5.1 on Linux 6.12.47 (x86_64)
                                    flashrom is free software, get the source code at https://flashrom.org
                                    Found Winbond flash chip "W25Q128.V" (16384 kB, SPI) on ch341a_spi.
                                    Reading flash... done.​
                                    6. flashed the file you suggested using flashrom:
                                    Code:
                                    sudo flashrom -p ch341a_spi -c "W25Q128.V" -w Lenovo_T480_ME_Clean.bin
                                    Reading old flash chip contents... done.
                                    Updating flash chip contents... Erase/write done from 0 to ffffff
                                    Verifying flash... VERIFIED.​
                                    Then i removed the spi flasher, reconnected internal battery, closed chassi, reconnected external battery and plugged in to power. Still black screen and power button flashes 3 times. No luck it seems. Unfortunately i lost the original BIOS dumps from before bricking the system so the ones i uploaded in my first post never worked and might contain wrong data. May I ask, what is the DMI info? I'm not familiar with the term. A shot in the dark but could the issue have something to do with the other SOIC8 chip containing the thunderbolt firmware maby?
                                    (The file i upload is the dump from reading the chip at step 5)​
                                    • Stefan Steff
                                      • Mar 2024
                                      • 391
                                      #199
                                      2. open chassi
                                      Code:
                                      Code:
                                      The Desktop Management Interface (DMI) is a standard industry framework for managing and tracking components in a laptop/PC and it contains all sort of data about the hardware like laptop serial number, main-board serial number, model number, etc and the computer boots, but with a lot of errors if this data is missing or is incomplete...
                                      You did everything ok...I think...I'm not a Linux fan...but I see there are no errors on read/write.
                                      What I can suggest is to try more dumps (attached) .
                                      This dumps worked on other T480 hardware....we don't know exactly what's yours because of the bricked backup.
                                      Good luck!
                                      • badiycbo
                                        • Sep 2025
                                        • 6
                                        • Sweden
                                        #200
                                        Good luck!
                                        Yes the write seems to working at least (if i can trust flashrom hehe), so I'll keep trying dumps like you said. Ugh I feel so stupid that I overwrote the original backups but thank you very much for trying to help, I feel more hopeful now knowing it is most likely just about finding the right bios dump for my hardware. Cheers!
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • to5it0
                                          by to5it0
                                          10-24-2025, 01:35 AM
                                          Lenovo ThinkPad T480 Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 03:21 PM
                                          09-06-2024, 02:34 PM
                                          09-06-2024, 02:28 PM
