Lenovo Thinkpad T480 BIOS and EEPROM request
  • Xargon1975
    • Apr 2025
    • 13
    • España
    #141
    Hi, I've been trying to unlock my T480's BIOS for over two weeks now.
    I followed all the instructions, tried AutoPatcher and other BIOS versions, but no luck.
    I found out that if the CRC check is wrong, the laptop plays a beep and shows a black screen. I fixed that issue, but now I'm stuck at a stage where the laptop just shuts down.
    If I restore the original BIOS, it asks for the password again and stays locked. What can I do???
    Type: 20L6-SDR213
    Serial No: PF-14H8HB
    Bios N24ET77W (1.52 )
    • hoaca388
      Badcaps
      • Jan 2022
      • 11254
      • Viet Nam
      #142
      Type: 20L6-SDR213
      Try agian with AutoPatcher.
      • Xargon1975
        • Apr 2025
        • 13
        • España
        #143
        Thank you for your response and for your assistance.
        I attempted to patch the file you provided, but the issue persists.
        The system plays the startup melody followed by a blank screen (no display output).
        When I revert to the original file you shared, the device boots successfully, but the BIOS remains locked.
        • khrapr
          khrapr
          • Apr 2025
          • Indonesia
          #144
          Please need help to remove supervisor password, I've been tried run Lenovo auto patcher and its doesn't work, after power on my laptop "sings" or melody after few second and no picture.
          Type T480 20L5-20L6
          S/N PF1GR4NL
          Bios Version : N24ET79W 1.54
          Thank's for your help.​
          • eKuliscool
            • May 2025
            Hello guys I really need your support because i tried to modify my bios and flashed it and after that nothing worked anymore...
            My Thinkpad T480 doesnt turn on anymore and there are no lights, fan spinning etc... - so basically dead. The only thing working is when i plug it via AC then it charges.
            I flashed the bios Chip with a lot of other verions provided in this post and nothing helped unfortunalty.
            My Setup is the following:
            Type: 20L6-S29E0C
            S/N: PP-1QC3TB
            Mainboard: i can"t tell you the exact Mainboard because i couldnt find any information about it on itself but i guess its ET480 NM-B501 as usual because i havent seen any other serial number for it.
            I would really appreciate the help because i really despair at this task.
            So if someone could help me and also need some more information i would love to provide them.
            (If its possible to give me an bios with a patched version (advanced menu, overclocking and erasing wwan whitelist) it would be even more perfect but not needed )
            I have no back up bios - because mine was broke and the only thing that matter is that my T480 will work again.
            Best regards and Thanks
            • anirash25
              • Nov 2013
              • 8
              • India
              #146
              Please help Clear the Bios Password Lenovo T480
              MB Part No: NM-B501
              Laptop Serial No : PF-1K59S7
            • ali0robot
              • Mar 2023
              • 61
              • N/A
              #147
              MB Part No: NM-B501
              try
              • ali0robot
                • Mar 2023
                • 61
                • N/A
                #148
                Type: 20L6-S29E0C
                S/N: PP-1QC3TB
                if you have 3.3 on bios chip look for resistance around bios chip, sometime one of those resistance are misplace or lost. in most cases they are 33 or 50 ohm
                • OrcunerenGungen
                  • Jul 2021
                  • 6
                  • kmlklkm
                  #149
                  Hello I have a t480 with supervisor password. I dumped the bios and patched it with the patcher on this forum. I got verification errors at first but after using another software to write with ch341a I was able to write and verify. But laptops power button blinks 3 times and nothing happens even with original bios. Can anyone take a look at my dump? I also tried other dumps from sit e but same thing. Also I noticed a resistor and 2 caps missing I bridged the resistor and left the caps as is Any Help is Much Appreciated. The resistor is r694 and it is 33 ohm and 2 missing 33p caps c576 and c577 There is 1.6v at vcc of bios and 3.3v at cs
                    • 20361
                    Type the laptop serial number, full name and model, motherboard model, etc.
                    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                    • OrcunerenGungen
                      • Jul 2021
                      • 6
                      • kmlklkm
                      #151
                      SN:PF1AQ6LW Model:20L6S0AF00 cant find mobo model
                      • OrcunerenGungen
                        • Jul 2021
                        • 6
                        • kmlklkm
                        #152
                        I couldnt edit my post The 3.3v comes to CS after plugging adapter doesnt come with battery
                          • 20361
                          Replace the caps and resistors then it might just work properly.
                          • OrcunerenGungen
                            • Jul 2021
                            • 6
                            • kmlklkm
                            #154
                            I fixed the issue it was the d12 diode on the back I put a wire for now I hope it helps someone else Also you can put a wire instead of 33 ohm resistors no problem but putting a new diode is recommended
                            • Luis Martin
                              • Jun 2025
                              • 5
                              Lenovo T480 bricked during a firmware update on ubuntu system, light on power button and fan turn on, no screen or HDMI output. Bip bip sound when turn on without RAM.
                              Brand: Lenovo T480
                              board No: Et480 nm-b501 (2018)
                              s/n: Pf-1EQ53J 18/09
                              Type: 20L5-000WUS
                              processor type: i5
                              issue: bricked during a firmware update
                              requesting: working BIOS.
                              The 3 attached files are the same DUMP with 3 different chips names for redundancy.
                                • 20361
                                Brand: Lenovo T480
                                Type: 20L5-000WUS
                                processor type: i5
                                try this one.
                                • Luis Martin
                                  • Jun 2025
                                  • 5
                                  Originally posted by SMDFlea
                                  try this one.
                                  Thank you SMDFlea.
                                  Unfortunately doesn't work.
                                    • 20361
                                    Thank you SMDFlea.
                                    Did you get the update from LVFS https://fwupd.org/ ,was the EC updated as well.
                                    • Luis Martin
                                      • Jun 2025
                                      • 5
                                      To be honest idk, i just get a update firmware pop-up and click on it.
                                      I find this .bin on another forum and I flash it, and it works now i got Lenovo screen and i can go to bios but .... now if i plug a hdd/ssd the system just start blinking the screen in black.
                                      If I remove ssd the system boot from my usb to install operating system but I can't because no ssd installed​. 🤔
                                      • Luis Martin
                                        • Jun 2025
                                        • 5
                                        this bios
                                          Lenovo ThinkPad T480 Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 03:21 PM
                                          09-06-2024, 02:34 PM
                                          09-06-2024, 02:28 PM
                                          09-06-2024, 12:30 PM
                                          09-06-2024, 11:39 AM
