Lenovo Thinkpad T480 BIOS and EEPROM request
    Hi Everyone,Need help to remove Password
    Lenovo ThinkPad T480
    Type 20L6-A02HAT
    S/N: PF-16SGBL
    P/N: SL10Q67064
    Motherboard: ET480 NM-B501 Rev: 1.0 2018-03-05
    Thank you!
    Type 20L6-A02HAT
    S/N: PF-16SGBL
    P/N: SL10Q67064
    Thank you!
    Did you tried "LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal"?
    Become a Badcaps supporter
    Thanks to all supporters.​
      Yes,meanwhile i found the post about Lenovo auto patcher,tried and succeeded
      Thank you and greetings to everyone!
        Please help. Remove password AUTO-PATCHER. after that it won't start
        I am attaching the original bios
        Type 20L6-S5NW01 S/N PF-1PTLAL Lenovo T480
        Please help
          Please help
          Hello, please take a picture of your BIOS chip so that the resistors are not damaged.
              Hello try this BIOS file hope it helps you ....
                Thanks, working. The BIOS is password protected on this dump. I'll try to remove password AUTO-PATCHER it now
                P.S. Thanks again. Removed password. Everything is working!
                  Good day everyone.
                  I have a Lenovo t480 that does not display, it had a broken type c charging port, I replaced it and was only switching for a few seconds. I discovered that the board has burnt charging IC, I changed it, now the board only turns on but no display, all voltages are available, now I'm 100% sure the bios is corrupt,
                  I have also tried most bios files on this thread and there is still no display.
                  LENOVO T480
                  SN /PF-18R47R
                  MB Model/ ET480 NM-B501
                  Fault / no display
                    Originally posted by mahlon simwnaja View Post
                    Good day everyone.
                    LENOVO T480
                    SN /PF-18R47R
                    Fault / no display
                    try
                      Originally posted by piszpunta View Post
                      try
                      Good day
                      Thank you for the response, unfortunately the bios did not work, it just blinks once and no action after that.
                        Hi, good people i have a lenovo t480s type 20lb when i try to do installation it does not give any option to skip WIFI when in UEFI First boot i tried to patch the image but still can not go beyond there, my thought is it might be WMI ENCRYPTION.
                        PLEASE ANY HELP? HERE IS MY ORIGINAL BIN FILE
                          Hello to all,
                          my t480 not starting not even showing the Lenovo screen.
                          16mb dump attached below, please help.
                          TYPE: 20L6-S3SL01
                          S/N: PF-1LZLDB
                          Board: ET480 NM-B501 Rev:1.0 2018-03-05
                          hi, you can always bypass this step during the installation using oobe command from shift+f10 CLI
                            Hello, Need help, I was trying to use the autopatcher, and I somehow managed to fry my bios chip while trying to take a dump, rookie mistake, I desoldered the chip and it's completely dead, can't read it, I don't have any dump, what are my options? can I buy a new chip and program it with a dump from another machine? any suggestions? should I just replace the motherboard?
                            Would appreciate any help or guidance.
                            Thank you
                              Thank you
                              can you check if your programmer clip is working fine? sometimes the wires from the ch341 to the test clip gets pulled off due the small length of cable and you cant read any chip, just use a multimeter and see if the points on the programmer and clip are connected.
                                Yeah I checked them, they do work, and I also desoldered the chip and soldered it to the programmer, and I have also did the 3 volt mod. chip is dead confirmed.
                                  I need a bios for t480 I don't have a copy of my original bios plzz need help
                                  patch
                                    Originally posted by ali akbar View Post
                                    patch
                                    read the rules..https://www.badcaps.net/forum/troubl...before-posting
                                    post the S/N, the original bios of the laptop, the motherboard model, etc.
