Lenovo Thinkpad T480 BIOS and EEPROM request
  • krabbenhörnchen
    • Apr 2023
    Re: Lenovo Thinkpad T480 BIOS and EEPROM request
    Originally posted by LenBios
    Please try...
    Thanks, I was able to revive my notebook with that image.
    • bursauzman
      • Nov 2018
      • 42
      • türkiye
      Re: Help please Lenovo T480S Bios Password
      I have lenovo thinkpad T480 with bios password. please help
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        See post #15
        BIOS guides, methods, resources and tools
        Password removal by laptop brand
        Become a Badcaps supporter
        Thanks to all supporters.
        • bursauzman
          • Nov 2018
          • 42
          • türkiye
          I can not.
          please help
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            I can not.
            please help
            Originally posted by piernov
            Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
            • bursauzman
              • Nov 2018
              • 42
              • türkiye
              #26
              I managed to create the pach file. I am trying. I will give information
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #27
                Good for you. Before that, make sure your factory dump is properly read, use verification. Read the chip several times and compare the contents.
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #28
                  When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
                  On Windows, you can use the command "fc /b" to check if two dumps are identical.
                  Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
                  Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665
                  • bursauzman
                    • Nov 2018
                    • 42
                    • türkiye
                    #29
                    is this true. bios contents look the same
                    i guess it didn't
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #30
                      You did not understand me correctly. I meant the factory (ie original) dump.
                      Read the chip with your factory dump several times, and compare the contents. To make sure you have a reliable backup first.
                      Edit: I don't understand why you are in such a hurry.
                      Read carefully what I replied to you and then proceed with the patching of the dump.
                      • bursauzman
                        • Nov 2018
                        • 42
                        • türkiye
                        #31
                        I finally made it. Thank you for the help
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #32
                          You're welcome. Good job!
                          Please consider donation in support of the "Bios Requests" section of the forum.
                          • knguyenfl
                            • Mar 2023
                            • 8
                            • usa
                            #33
                            I have Lenovo T480 with absolute enabled on the bios. I flashed with the patched bios it boots up but will stuck forever at entering setup and can't get to bios.
                            Can anyone help me with this issue?
                            I attached both original and patch dump.
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #34
                              Originally posted by knguyenfl
                              You have Absolute enabled in the bios, but not bios password, or you have both enabled?
                              • knguyenfl
                                • Mar 2023
                                • 8
                                • usa
                                #35
                                Hi Vesko,
                                just absolute enabled only, no bios password.
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #36
                                  Hi Vesko,
                                  In this case flash back your original dump, power up the laptop then enter the bios and set supervisor password, restart, power off, dump the bios chip again and then patch the dump. Follow the "how to use the patch" steps.
                                  After that you can be able to disable Absolute.
                                  • knguyenfl
                                    • Mar 2023
                                    • 8
                                    • usa
                                    #37
                                    Absolute disabled, thank you so much for your help.
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      #38
                                      You're welcome.
                                      • alilaptops
                                        • Apr 2019
                                        • 17
                                        • Pakistan
                                        #39
                                        clear me display
                                        • bursauzman
                                          • Nov 2018
                                          • 42
                                          • türkiye
                                          #40
                                          screen comes on in 60 seconds. can you clear me area for me
                                          • lucaszmn
                                            by lucaszmn
                                            Problem:
                                            Initial Findings:
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                            Lenovo ThinkPad T480 Notebook T Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 03:21 PM
                                            09-06-2024, 02:34 PM
                                            09-06-2024, 02:28 PM
                                            09-06-2024, 12:30 PM
