Lenovo Thinkpad T480 BIOS and EEPROM request
  • Stefan Steff
    • Mar 2024
    • 277
    • Romania
    #121
    Originally posted by qwerty4512
    I need your help, can anyone help me open the locked bios file?
    TYPE: T490
    CODE:NM-B901
    S/N:PF1VJMDX
    THANK YOU
    Here it's the T490 thread :
    https://www.badcaps.net/forum/troubl...t490-and-t490s
    • qwerty4512
      • Dec 2024
      • 29
      • US
      #122
      Originally posted by Stefan Steff
      SORRY, allready post there
      • monkeyclone
        • Jan 2025
        • 4
        Hey all,
        Having some trouble with patching my T480 bios so I can access the advanced menu. I dumped the bios and believed I patched it correctly, following a few guides. However when I reflash the laptop will let out a musical chime and not boot. I've tried a couple of times to fix the patched bios however I've hit a wall and have no idea what I'm doing wrong. Refreshing the original gets everything back to working order.
        Some searching has led me to believe it's the bios version that was on the laptop that could be causing issues. It's running 1.53 I believe and I saw people with 1.52 saying they had issues but I'm at a complete loss as to what I should do next.
        I've attached a copy of my working bios and a copy of the patched one. Any help would be massively appreciated and sorry for coming with what is probably a simple problem.
        Edit-
        apologies I missed the rule about where to post. my SN is PF-0YY9FP
      • Ivan Parra
        • Jan 2025
        • 3
        • Mexico
        #124
        Hi everyone, i just brick my t480 when i was updating the bios the laptop just shutdown, i supose the battery in bad condition.
        ​​I flashed a bios patched and only change mac, cause i read in a thread that just changing the mac had workdd, but didnt work for me. I want to know what else i need to do.
        I would vert greatful if you could help me.
        Lenovo et480 NM-B501
        SN: PF-1LQ0Q4
        • volinakis
          • Jan 2021
          • 2750
          • N/A
          #125
          Originally posted by monkeyclone
          Hey all,
          Edit-
          follow steps from autopatcher
          • volinakis
            • Jan 2021
            • 2750
            • N/A
            #126
            SN: PF-1LQ0Q4
            try
            • Ivan Parra
              • Jan 2025
              • 3
              • Mexico
              #127
              Originally posted by volinakis
              try
              Flawless and thank you very much :').what was the change?, if i may ask, im new in this literally since yesterday.
              • volinakis
                • Jan 2021
                • 2750
                • N/A
                #128
                I extracted bios region from update and replaced it in your backup and performed a clean_ME with intel FIT. You are welcome.
                • Ivan Parra
                  • Jan 2025
                  • 3
                  • Mexico
                  #129
                  Just a question, by unlocking the advanced bios menu you can exceed the temperature limit of the GPU and CPU?
                  • kevinizm
                    • Sep 2023
                    • 4
                    • New Zealand
                    #130
                    I mucked around with my bios a bit too much and now it doesn't power on, however still charges. I'm suspecting a fried motherboard and ordered a new motherboard just in case.
                    I would be grateful for some help
                    Type 20L6-S3H109 SN PF-18HAF
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11901
                      #131
                      PF-18HAF belong to Edge E531 (ThinkPad) - Type 6885
                      T480 Laptop (ThinkPad) - Type 20L6
                      Serial _PF18HCAF
                      • kevinizm
                        • Sep 2023
                        • 4
                        • New Zealand
                        #132
                        Serial _PF18HCAF
                        Sorry, you are correct, did you have a look at it? How messed up was it?
                        • Tix2
                          • Feb 2014
                          • 59
                          i have an Lenovo T480 with a company block or something like this.
                          Whenever i tried to install Windows OS i have to connect to a company.
                          Can someone help me to delete this?
                          Thank you
                          My laptop:
                          Lenovo T480
                          Type: 20L5-0007GE
                          SN: PF-0YZ1R8
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1226
                            • France
                            #134
                            Thank you
                            My laptop:
                            Lenovo T480
                            Type: 20L5-0007GE
                            SN: PF-0YZ1R8
                            not found computrace but autopilot yes
                            try
                            • Tix2
                              • Feb 2014
                              • 59
                              try
                              Worked.
                              Thank you very much...
                              • PacoGT
                                • Sep 2022
                                • 100
                                • Guatemala
                                #136
                                hello the laptop turn on and is on black screen, no video can you clearme , my bos thanks
                                sn: pf-1gz3kw
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11901
                                  #137
                                  sn: pf-1gz3kw
                                  • tracker1
                                    • Jul 2017
                                    • 118
                                    • romania
                                    #138
                                    Need help to remove supervisor password, tryed lenovo autopatcher and its doesnt work( "sings" after few second and no picture).
                                    Type 20L6-5SDR1S
                                    S/N PF-1MNEN3 19/03
                                    • tracker1
                                      • Jul 2017
                                      • 118
                                      • romania
                                      #139
                                      Type 20L6-5SDR1S
                                      S/N PF-1MNEN3 19/03
                                      I used autopilot remove from Maxpower 3 post, used lenovo autopatcher on it and and then writ it on the laptop ,press space few times , then write back my own original dump and the passwort wass gone .. i have no idea what i did and why its work but its works, thx all for help!.
                                      • subaracz
                                        • Sep 2023
                                        • 12
                                        • Poland
                                        #140
                                        Hi, I need clear ME for my T480
                                        Type 20L6-SDBL03
                                        SN: PF-1XFTJ6
                                        Tried autopatcher, but during operation it shows error that bin is corrupted. Can anyone help me?
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                          Lenovo ThinkPad T480 Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 03:21 PM
                                          09-06-2024, 02:34 PM
                                          09-06-2024, 02:28 PM
                                          09-06-2024, 12:30 PM
