lenovo Flex 5 bios need
  • uvaiz
    • Jan 2014
    • 113
    • saudi arabia
    hai all
    any one please help me
    i need bios for lenovo Flex 5-14ARE05 Laptop (ideapad) - Type 81X2
    board id: LC55-14A 19793 1M
    i have my no display backup but file is currepted
    thanks
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    Re: lenovo Flex 5 bios need
    try newly build bios from lenovo support site
    • peste
      • Dec 2016
      • 12852
      • ROMANIA
      Originally posted by uvaiz
      hai all
      thanks
      bios extracted from the Lenovo site update.
      DMI B21000 - B213FF
      KEYWIN B10080 - B100BF
      • lazybigyan
        • Mar 2017
        • 79
        • Nepal
        Than you gentleman.
        It's working fine but how to update serial no in bios.
          • 20966
          Originally posted by lazybigyan
          Than you gentleman.
          Do you have a backup ? .
          • racadeguae2
            • Apr 2021
            • brasil
            hello friends good afternoon it is a great pleasure to be part of this family that each day is better and grows more and more a great day for everyone and take care
            • racadeguae2
              • Apr 2021
              • brasil
              Re: Lenovo Flex 5 bios need
              thanks for the file
              • Chipa
                • Oct 2021
                • Dominican Republic
                Hello someone can do a tutorial to fix it
                I used ch341a and AsProgrammer and my bios chip serial is GD25LB128DSIG and I worked with GDL12Q... 1.8v
                I erased my BIO, and program the new BIO and doesn't work
                I have a black screen 😣
                • peste
                  • Dec 2016
                  • 12852
                  • ROMANIA
                  do not use the clip because you may have errors, remove the bios chip from the motherboard before reading or writing, if you do not have an adapter, solder the chip to the programmer, if you have nothing to remove it, solder wires between the chip and programmer..
                  • Dan20701
                    • Sep 2020
                    • 199
                    • United Kingdom
                    Hello all, Would someone be kind enough to unlock this bios file please.
                    Lenovo Ideapad Flex 5-14ARE05
                    If i could do it myself I would, this is something I should know how to do
                    by now but I still have problems doing it, sorry.
                    Thank you.
                    • peste
                      • Dec 2016
                      • 12852
                      • ROMANIA
                      Thank you.
                      the bios is corrupt and longer... remove your bios chip from the motherboard before reading or writing.. check with the HxD program that it is correct and post again..
                      • Dan20701
                        • Sep 2020
                        • 199
                        • United Kingdom
                        Hello mate thanks for looking so quickly, The chip is out
                        I read the chip 3 times, in beyond compare all 3 files are the same.
                        I have the t56 programmer with the 200mi adaptor.
                        When reading this chip do I have the , Flash & OPT Secu R & Status Reg
                        all ticked in the 3 boxes? and save as Default or save as Flash or save as OPT?
                        if this matters?
                        I will give this chip another clean up and try again.
                        Thanks.
                        • Dan20701
                          • Sep 2020
                          • 199
                          • United Kingdom
                          Hello mate, I have cleaned up the pins and cleaned up the chip
                          it all looks really good, its the same again, maybe this bios is corrupted.
                          I have had a look at the file in the first post and its not much different.
                          Can you have one last look please mate. much appreciated.
                          Thank you.
                            • 20966
                            if this matters?
                            Is it OPT or OTP ,if its OTP (one time programmable) don`t use that. Choose the chip that isn`t OTP
                            • Dan20701
                              • Sep 2020
                              • 199
                              • United Kingdom
                              Thanks for explaining OPT & OTP SMDFlea I have never messed with this
                              and have always left it on the default settings, Now I know not to use it.
                              I have been looking for my old CH341A Programmer to see if I get the same
                              reading but can I find it, No.
                              Thanks for all your help.
                              • DireXT
                                • Feb 2014
                                • 19
                                • turkey
                                i need bios dump
                                LC55-15c
                                19792-3
                                448.0k111.0031
                                i5 10th gen.
                                nvidia gpu
                                • peste
                                  • Dec 2016
                                  • 12852
                                  • ROMANIA
                                  Originally posted by DireXT
                                  i need bios dump
                                  LC55-15c
                                  19792-3
                                  448.0k111.0031
                                  i5 10th gen.
                                  nvidia gpu
                                  read this..
                                  always keep the full name and model and the original bios even if it is corrupted..
                                  • DireXT
                                    • Feb 2014
                                    • 19
                                    • turkey
                                    black screen problematic this dump
                                    • akbari_808
                                      • Jan 2019
                                      • 20
                                      • United Kingdom
                                      hi, could anyone please dump this BIOS file for me?
                                      the model of the laptop is Lenovo ideapad flex 5 14ARE05
                                      many thanks in advance.
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11781
                                        Flex 5-14ARE05 Laptop (ideapad) - Type 81X2 - R90YJHKM
                                        • claws77
                                          lenovo flex 5 14ITL05 bios and motherboard fault
                                          by claws77
                                          my laptop is lenovo flex 5 14ITL05
                                          recently my power supply for this laptop developed a fault.
                                          which caused a short in my usb c port -- verified with a new charger.
                                          rant: so, i went to the repair tech in my country, he asked for a huge repair cost when i decided to get it done someplace else this "great person" nicked my bios chip, asked me to be aware for repair scams lol.
                                          I was stupid and unable to find the flaw at the moment. Another repair tech told me that my bios chip was stolen and an 8mb bios chip is in place of that. he told me that a 32...
                                          07-05-2024, 04:33 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
                                          Lenovo C340-15IML/FLEX-15IML/S340-15IML S340-14IML Bios Extract & DMI Edit Tutorial
                                          by SMDFlea
                                          These models use the same bios: Lenovo IdeaPad C340-15IML/FLEX-15IML/S340-15IML/S340-15IML Touch/S340-14IML Lenovo XiaoXin-15IML 2019/XiaoXin-14IML 2019
                                          Backup bios used for this tutorial https://www.badcaps.net/forum/showthread.php?t=97978 Post #13
                                          Extract & Edit.
                                          Download the lenovo update from - https://download.lenovo.com/consumer...s/crcn17ww.exe
                                          Extract the first exe using innoextract - https://constexpr.org/innoextract/#download
                                          Extract the second exe using 7-zip or winrar - https://www.7-zip.org/download.html
                                          08-11-2021, 12:22 PM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
