lenovo Flex 5 bios need
  • peste
    • 15331
    • ROMANIA
    #121
    Originally posted by cyraxman2003
    I cannot enter to bios , when the laptop starts, the fans starts to work then stop , the keyboard light is on then all the lights are off excepts the Caps and Esc, the Esc can be turn off with win key+ esc . all this time the display is off
    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
    It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • cyraxman2003
      • May 2025
      #122
      I see , thank you, I was think to do it via reboot FN+R or FN+B. in this case i need to go to specialist ..
        • 24100
        Did you try pressing the NOVO button
        • cyraxman2003
          • May 2025
          #124
          Yes, is doing the same , black screen , keyboard lighted , then only caps and esc on (with light ) and it seems is repeating this, keyboard light then only Caps and Esc , so on
          • freenlnl
            • May 2014
            • 36
            • The netherlands
            #125
            Hello ,can someone help with this amd bios, it didn't turn on anymore after a flash from windows ESC blinking
            Ideapad flex5 14ARE05 SN R911YHMD - MTM 81X200E1CF - MO R9N0B131200Q
              SMDFlea commented
              Editing a comment
              Post moved to Flex 5 topic.
          • peste
            • 15331
            • ROMANIA
            #126
            you have everything you need at post #34...
            https://www.badcaps.net/forum/troubl...e2#post3719172
            • soulandkey
              • Jan 2026
              • 6
              • Indonesia
              #127
              help me to unlock the amd psp from MFG mode, and serial number is not detected on my bios
              Lenovo Flex 5-14ARE05 Laptop (ideapad) - Type 81X2
              currently bios version EECN44WW
              serial number R90Y2HQG
              mtm 81X2000WUS
              mo R9N0B0429007
              factory id KS
              processor Ryzen 5 4500U
              ram 8gb
              vga amd radeon tm graphics
              Thanks!
                SMDFlea commented
                Editing a comment
                post moved to flex 5 topic.
            • m1ch43lzm
              • Mar 2019
              • 2330
              • Peru
              #128
              mtm 81X2000WUS
              mo R9N0B0429007
              factory id KS
              ram 8gb
              Thanks!
              If you have a BIOS backup before you flashed new BIOS, the DMI can be copied from original (corrupt) BIOS to a new BIOS, here are the offsets, use hex editor
              DMI B21000-B213FF
              Win key B10000-B100BF
              Otherwise if you don't have a backup of the corrupt BIOS try Golden Key USB to fill S/N, MTM, etc.
              https://www.badcaps.net/forum/troubl...e4#post3748093
              • AHSAN TARIQ
                • Jan 2025
                • 92
                • Pakistan
                #129
                mtm 81X2000WUS
                mo R9N0B0429007
                factory id KS
                ram 8gb
                Thanks!
                try this bro
                • soulandkey
                  • Jan 2026
                  • 6
                  • Indonesia
                  #130
                  how to run golden key usb? which one i download?
                  • soulandkey
                    • Jan 2026
                    • 6
                    • Indonesia
                    #131
                    Originally posted by AHSAN TARIQ
                    try this bro
                    is this bios file? what version is this? my version current is EECN44WW, i need lower version like EECN41WW
                    • soulandkey
                      • Jan 2026
                      • 6
                      • Indonesia
                      #132
                      try this bro
                      mybe do you have the exe file instead of bin file? i dont understand how to run bin file. Thanks!
                      • m1ch43lzm
                        • Mar 2019
                        • 2330
                        • Peru
                        #133
                        Click image for larger version  Name:	image.png Views:	5 Size:	3.0 KB ID:	3798320
                        It says in the post I linked...
                        Originally posted by iam5
                        I created a bootable flash drive with 3.5.79/8 (however the versioning works) and just imaged it. Not sure how long this will stay up. Just download the raw image file here and use something like win32diskimager to write it to a flash drive. Should be fully bootable/updated as of now. Minus the linux diagnostics part, which I cannot find a working download for.
                        tested it with 2 different flash drives, usbc and usba, 2.0 & 3.1, didn't have an issue booting it ever. Should ideally make the process a bit simpler/quicker.
                        Code:
                        https://archive.org/details/lenovo-u-1-tool-3-5-79
                        Win32diskimager: https://sourceforge.net/projects/win32diskimager/
                        You need a blank/empty USB drive, otherwise it will delete all data on it
                        The file by AHSAN TARIQ is meant to be flashed with a programmer directly to the BIOS chip
                        If you want the update.exe from Lenovo, earliest version available is EECN42WW https://download.lenovo.com/consumer...s/eecn42ww.exe
                        • soulandkey
                          • Jan 2026
                          • 6
                          • Indonesia
                          #134
                          THANKS FOR THE EXE FILE! I WILL TRY LATER THANKS!!!!!!
                          • soulandkey
                            • Jan 2026
                            • 6
                            • Indonesia
                            #135
                            btw any lower version from EECN42WW(exe)? thanks!
                            • AHSAN TARIQ
                              • Jan 2025
                              • 92
                              • Pakistan
                              #136
                              tell me that this bios is ok or not
                              • Surloin
                                • Jan 2026
                                I recently tried updating the BIOS on my Lenovo IdeaPad Flex 5 and after about 15 - 20 minutes of waiting and a few restarts, the screen was completely black. I tried a bunch of different recovery methods but none seemed to work. I managed to get a BIOS dump using the tools I had on hand, but after looking into what I had to do in order to keep device data like UUID, SN, MAC address etc. I was a little intimidated and feared I might mess up and irreversibly damage my board. Was hoping someone much more knowledgeable with these things could create a usable BIOS as I'm way out of my depth here.
                                Device Specs:
                                Model: Lenovo IdeaPad Flex 5 14ARE05
                                CPU: AMD Ryzen 5 4500U
                                SN: R91281DR
                                Board ID: LNVNB161216
                                P/N: 5B20S44391
                                I have both the BIOS dump from the board and the extracted CAP file from the latest Lenovo BIOS update version EECN44WW. I believe the original BIOS version on my machine was EECN33WW but I'm not 100% sure. Was hoping someone could rebuild/merge the NVRAM, PSP/SMU firmware, and Board-specific data with the BIOS in the CAP file. If anything else is needed don't hesitate to let me know. Thanks in advance for any help.
                                BIOS Dump & CAP File:
                                • m1ch43lzm
                                  m1ch43lzm commented
                                  Editing a comment
                                  Thread merged
                              • m1ch43lzm
                                • Mar 2019
                                • 2330
                                • Peru
                                #138
                                Originally posted by Surloin
                                Device Specs:
                                SN: R91281DR
                                P/N: 5B20S44391
                                Try, DMI + Win key inserted
                                BIOS ver. EECN44WW
                                S/N R91281DR​
                                MTM 81X20005US​
                                DMI B21000-B213FF
                                • mingrepair
                                  • Mar 2020
                                  • 16
                                  • canada
                                  #139
                                  Hi There
                                  can anyone help me to fix this Lenovo bios files cruued not working
                                  no boot
                                  no display no touch
                                  no touchpad
                                  • Blaze Tech
                                    Learner
                                    • 324
                                    • Ghana
                                    • Repairs
                                    #140
                                    Originally posted by mingrepair
                                    Hi There
                                    no boot
                                    no display no touch
                                    no touchpad
                                    Write your serial number and model number
                                    • claws77
                                      lenovo flex 5 14ITL05 bios and motherboard fault
                                      by claws77
                                      my laptop is lenovo flex 5 14ITL05
                                      recently my power supply for this laptop developed a fault.
                                      which caused a short in my usb c port -- verified with a new charger.
                                      rant: so, i went to the repair tech in my country, he asked for a huge repair cost when i decided to get it done someplace else this "great person" nicked my bios chip, asked me to be aware for repair scams lol.
                                      I was stupid and unable to find the flaw at the moment. Another repair tech told me that my bios chip was stolen and an 8mb bios chip is in place of that. he told me that a 32...
                                      07-05-2024, 04:33 PM
                                    • lucaszmn
                                      by lucaszmn
                                      Problem:
                                      Initial Findings:
                                      • I concluded that the
                                      08-12-2025, 03:01 PM
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
                                    • gestalt.exe
                                      Lenovo Legion Y540 – Need help repairing BIOS after bad downgrade
                                      by gestalt.exe
                                      My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
                                      Laptop stopped booting entirely.
                                      I used a CH341A programmer to dump the corrupted 16MB BIOS.
                                      i then attempted the following:
                                      1. Downloaded stock BIOS BHCN39WW from Lenovo
                                      2. Trimmed it to 16MB
                                      3. Extracted the BIOS region from the corrupted dump
                                      4. Extracted the BIOS region from the stock 39WW
                                      5. Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
                                      6. Injected back my LDGB / DMI
                                      11-30-2025, 10:38 AM
                                    • to5it0
                                      by to5it0
                                      10-24-2025, 01:35 AM
