lenovo Flex 5 bios need
  • pokyss1
    • Mar 2019
    • 161
    • TUNISE
    #81
    Originally posted by pokyss1
    BONJOUR
    no display issue
    model number in the bord:
    LC55-14A
    19793-3
    448.0K104.0031
      SMDFlea commented
      Editing a comment
      Post the laptop model number and Type and post the laptop serial number..........
  • shiyab
    • Sep 2023
    • 3561
    • india
    #82
    BONJOUR
    no display issue
    LC55-14A
    19793-3
    448.0K104.0031
    post snid
    • Osmarperez
      • Oct 2024
      • Ecuador
      #83
      Hi everyone!!
      Could you please help me fixing this BIOS? Thanks in advance
      Lenovo Ideapad Flex 5-14ITL05 Laptop - Type 82HS
      S/N: R912W5LD
      BIOS VERSION: FXCN49WW
      Issue: after a bad upgrade laptop won`t recognize SSD NVMe, other than that everything is ok.
      Thank you very much
      • hoaca388
        Badcaps
        • Jan 2022
        • 12713
        #84
        Originally posted by Osmarperez
        Hi everyone!!
        S/N: R912W5LD
        Thank you very much
        S/N: R912W5LD
        If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
        Subscribe to support us. It only takes 1 minute:
        https://www.badcaps.net/settings/subscriptions
        • Osmarperez
          • Oct 2024
          • Ecuador
          #85
          Originally posted by hoaca388
          S/N: R912W5LD
          Thank you very much !!
          • Osmarperez
            • Oct 2024
            • Ecuador
            #86
            Hi everyone, it`s me again this time with a question: is there a method to upgrade/flash the BIOS of the Lenovo Ideapad Flex 5-14ITL05 Laptop - Type 82HS using a bootable pendrive?
            I`ve search the Internet but I haven´t found a way to do it in Lenovo laptops. Thanks.
            • redoxy
              • Sep 2018
              • 116
              Hi everyone!!
              Could you please help me fix my BIOS?
              Lenovo IdeaPad Flex 5-14ITL05
              S/N: R912KL5Q
              Motherboard: LC65-14T 203013 448.0K121,0011
              Issue: Laptop powers on but no display. It appears the LCD backlight turns on but no image.
              Thanks, in advance.
              • hoaca388
                Badcaps
                • Jan 2022
                • 12713
                #88
                Originally posted by redoxy
                Hi everyone!!
                S/N: R912KL5Q
                Thanks, in advance.
                Flex 5-14ITL05 Laptop (ideapad) - Type 82HS
                • shiyab
                  • Sep 2023
                  • 3561
                  • india
                  #89
                  Hi everyone!!
                  S/N: R912KL5Q
                  Thanks, in advance.
                  hi try
                  • redoxy
                    • Sep 2018
                    • 116
                    Thanks, Hoaca388 and Shiyab for the files.
                    I tried Hoaca388's file and it worked. I have display.
                    However, I lost DMI info (S/N, Model #, UUID and Windows Key) as shown in the picture.
                    I tried using the Lenovo Uone tool to write the DMI info but I get an error "Locate protocol with LenovoEeprom, status [e]"
                    "Eeprom fail when reading or writing data."
                    Is there a way to fix the DMI tool error? I'd like to try that first if possible since I'd prefer not to desolder the BIOS chip again.
                    shiyab does your file retain the DMI information so I should go ahead and try that if I'm unable to write the DMI info with the tool?
                    Thanks, again for the help.
                    Cheers!
                    • qayyum786
                      • Aug 2018
                      • 1958
                      • INDIA
                      #91
                      try
                      • redoxy
                        • Sep 2018
                        • 116
                        Originally posted by qayyum786
                        try
                        Thanks, qayyum786. I made a rookie mistake in my haste to flash the BIOS. I forgot the battery was still when I was placing heat tapes on resistors and capacitors around the BIOS chip to prepare for desoldering the BIOS chip. I ended up shorting the BIOS chip (it burned). I replaced it with the same part number from a donor board and flashed your bin file but now there's no power. The laptop doesn't turn on anymore. I tried with battery only, power adapter only, and battery with power adapter with the same results, no power. I guess I might have damaged other components besides the BIOS chip
                        This is the end of this repair for me.
                        Thanks, everyone for all the help.
                        Cheers!
                        • qayyum786
                          • Aug 2018
                          • 1958
                          • INDIA
                          #93
                          Cheers!
                          flash old bios and check dose it turn on
                          • redoxy
                            • Sep 2018
                            • 116
                            I ordered new BIOS chips. I'll try and report back once I receive it.
                            Thanks.
                            • redoxy
                              • Sep 2018
                              • 116
                              I received the new BIOS chip and flashed the old BIOS. It still does not turn on.
                              • Lukosiukas
                                • Jul 2018
                                • 118
                                • Lithuania
                                • Motherboard repairs at component level.
                                #96
                                Hello, i need bios rebuild or dmi and widnows key trasfered. Turns on, black screen, no post. Tried dump with no dmi (from #3 post) computer turns on, works perfectly.
                                IDEAPAD FLEX 5 14ARE05
                                SN R9121R2B
                                MTM 81X2009JLT
                                BOARD LC55-14A 19793-3
                                • peste
                                  • 15718
                                  • ROMANIA
                                  #97
                                  SN R9121R2B
                                  MTM 81X2009JLT
                                  now you have everything you need at post #3...transfer DMI AND KEYWIN yourself...
                                  the bios from post # is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
                                  select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
                                  If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12713
                                    #98
                                    SN R9121R2B
                                    MTM 81X2009JLT
                                    Flex 5-14ARE05 Laptop (ideapad) - Type 81X2
                                    • Shako
                                      • Jan 2025
                                      • 26
                                      • IT, electronics.
                                      #99
                                      Hello guys. Can you please help me with my BIOS. Laptop turns on and has a black screen.
                                      Lenovo IdeaPad Flex 5 14ARE05 Type:81X2
                                      SN: R9128CCK
                                      MTM:81X20099GE
                                      MO:R9N0B132700F
                                      I would really love to keep my Serial Number.
                                      Thanks in advance.
                                      • peste
                                        • 15718
                                        • ROMANIA
                                        #100
                                        SN: R9128CCK
                                        MTM:81X20099GE
                                        MO:R9N0B132700F
                                        Thanks in advance.
                                        try post #4..
                                        https://www.badcaps.net/forum/troubl...os#post1758667
                                        • Do_Yuri
                                          Lenovo IdeaPad 3 15ADA05 (81W1) — cannot enter BIOS, system always boots in Legacy mode
                                          by Do_Yuri
                                          Hello.
                                          I’m trying to diagnose a Lenovo IdeaPad 3 15ADA05 (Model 81W1).
                                          Hardware
                                          Model: Lenovo IdeaPad 3 15ADA05 (81W1)
                                          BIOS version: E8CN34WW
                                          Internal drive: NVMe SSD (detected normally)
                                          Symptoms
                                          BIOS Setup is almost impossible to enter.
                                          Pressing F2 during power-on usually freezes on the Lenovo logo or is ignored.
                                          The Novo button opens the Novo Menu, but selecting BIOS Setup...
                                          08-01-2026, 01:58 PM
                                        • yellowtiger
                                          Lenovo Slim 7i 14IMH9 - Failed BIOS Update and Stuck in Boot Loop - BIOS Request
                                          by yellowtiger
                                          Hello Everyone,
                                          I have a Lenovo Slim 7i 14IMH9 that got stuck in a boot loop with black screen after a failed BIOS update through Lenovo Vantage.
                                          Here are my laptop details:
                                          - Model: Lenovo Slim 7i 14IMH9
                                          - Serial Number: YX09M0K7
                                          - Machine type: 83D80003US
                                          **Problem:**
                                          About two weeks ago a BIOS update for this laptop failed and the laptop has been stuck in a boot loop with black screen ever since. Now when I press the power button, the keyboard lights come on and the fan starts running. However, the screen remains black. The laptop...
                                          06-14-2026, 11:04 AM
                                        • claws77
                                          lenovo flex 5 14ITL05 bios and motherboard fault
                                          by claws77
                                          my laptop is lenovo flex 5 14ITL05
                                          recently my power supply for this laptop developed a fault.
                                          which caused a short in my usb c port -- verified with a new charger.
                                          rant: so, i went to the repair tech in my country, he asked for a huge repair cost when i decided to get it done someplace else this "great person" nicked my bios chip, asked me to be aware for repair scams lol.
                                          I was stupid and unable to find the flaw at the moment. Another repair tech told me that my bios chip was stolen and an 8mb bios chip is in place of that. he told me that a 32...
                                          07-05-2024, 04:33 PM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
