  • grimacelord
    • Jan 2017
    • 415
    Hello there.
    History:
    I searched for this error online and discovered quite a few people had this very same problem with this very same computer and the ultimate solution was to flash a new BIOS and the problem would be solved.
    The problem was, the provided BIOS update from Lenovo was meant to be flashed from within Windows and I was unable to boot Windows (or anything else for that matter) due to the error message when first powering on the computer. I could enter CMOS and I tried to load "Optimized Defaults" or to change boot order so I could boot off of a CD/USB, and while I could change those settings, it would never go beyond that error message after first turning on/rebooting the computer.
    2. So then, I first removed the BIOS chip from the motherboard and attached it to a CH341A programmer with a 1.8V adapter and took an initial dump of the original BIOS. That file is attached to this post.
    3. I erased the chip and then flashed it with the .bin from the Lenovo BIOS update and soldered the chip back to the motherboard.
    4. Computer does turn on, but no POST. Fans spin, case LEDs illuminate, but nothing ever appears on the display. I let it sit this way for as long as 20 minutes and it never produces an image.
    5. I reflashed the original BIOS back to the chip and the computer still does not POST now. At least before, the computer would POST, but now, even with the original BIOS back on the chip, the computer will not POST.
    6. I compared the original dump with the BIOS update .bin in HxD and saw many large sections of code that are different from my dump and the update file. I assume some of it is vendor specific data like SN and whatnot, but I am not sure how to "merge" in that data from my dump and into the update file or if that is even the problem.
    I was hoping someone could look at my dump and the rest of this info and possibly help me create a working BIOS file I can flash back to the chip to get this computer POSTing again.
    Thank you in advance.
    Computer information:
    Model: Legion T5-26AMR5 Desktop (Lenovo) - Type 90RB
    SN: MJ0G16B7
    Motherboard Model Number: AMDP19ME2 VER:1.0
    Original BIOS version already on chip: O4MKT23A (it seems. I was able to find this by searching the bin in HxD)
    Lenovo BIOS Update: Here is the official Lenovo download page, but I have also attached it in a ZIP to this message.
    BIOS Chip Model: MXIC25U12872F - (I think it might be worth noting that ASProgrammer and NeoProgrammer both detect the chip as MXIC25U12873F, which is incorrect. Mine is ends in 72F)
    If you need more information, please ask and I will get it to you right away. Attached are my original BIOS dump and the update file from Lenovo.
    • 25649
    Re: Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
    try this one.
    • grimacelord
      • Jan 2017
      • 415
      Originally posted by SMDFlea
      try this one.
      Hi there. Thank you for taking some time to try and help me, but unfortunately the BIOS you provided makes the computer behave the same way. It does power on, all lights and fans spin, but nothing ever appears on screen.
      • MacAttack
        • Jun 2020
        Did you ever find a fix? Just got one with the same problem today. However, the customer had knocked off a zener diode in the bottom corner of the board. A 1HC Z. I am trying to figure out the exact replacement for it.
        • grimacelord
          • Jan 2017
          • 415
          Unfortunately, no. I tried flashing the BIOS multiple times with multiple different versions released by Lenovo for that board and none of them worked. I even tried replacing the BIOS chip itself and flashing it and that didn't help either.
          Due to time constraints with my customer, I had little choice but to simply offer a motherboard replacement. I offered them a replacement with the original motherboard which was about $170 if I remember plus labor or to replace with another B550 chipset board that gave all the same functionality as the original just lacked the proprietary connector for Lenovo's LED strips. That board was significantly less expensive, though. The customer ultimately went with the 3rd party (GIGABYTE) B550 board because they didn't want to spend a lot for the original OEM board. Everything worked fine after the board swap.
          I wish I had more time to try repairing that board/BIOS/whatever it was, but my customer was in a hurry so oh well.
          While I had this board, I was looking for schematics for it to hopefully help me narrow down some other problem it must have had, but I was never successful in finding it, even on pay-wall sites. You'll probably have to find schematics for a similar board and then find the value of the zener diode for that board and hope it was the same design/value used in the one you're trying to repair.
          Good luck!
          • grimacelord
            • Jan 2017
            • 415
            Also, are you sure it's a zener diode?
            You may take a look at this one: https://www.digikey.com/en/products/...32MR-G/2138119
            I found that using: https://smd.yooneed.one/ - which has helped me in the past identify components. Pretty cool website. According to it, the digikey link I posted above could be your component, which is a voltage regulator. Use the datasheet to see if it matches the size and appearance of your's. You could also use that value/part number to help you search through similar Lenovo board schematics to see if it's a part commonly used in that circuit.
            If you're sure it is a zener diode, you could try using that component lookup site and see if you can come across something that seems to match.
            • MacAttack
              • Jun 2020
              Thanks for replying! It is definitely a SOT-23 Package. I keep seeing different things regarding the marking. I believe it is zener diode as I learned how to test one and that confirmed it. I just don't know how to get the correct replacement other than finding the schematic.
              • RockitRepairs
                • May 2024
                Hey, so I recently came across the same issue (When powering on the device would beep twice and then display "0135 fan error", after prompting F2 the device would then show "BiInitializeLibrary failed 0xc0000001". I ordered a new board for the customer, which appeared to be defective (the CPU debug light turned on). I put the old board back just in case to see if I may have damaged the CPU when I swapped it over. The only connections I had at the time were CPU, GPU, and MB. Got the "0135 fan error" upon boot, looked into the bios, and saw that the CPU was being recognized. Okay cool, so the CPU is still working fine. For shits and giggle I decided to press f2 and it booted into the os just fine. I then updated the bios and the issue has been resolved. Not sure if it was just luck but maybe try booting into the os with bare minimum connections.
                • CirebeaTiberiu
                  • Aug 2021
                  • 26
                  Hello team Can someone repair this bios file? I restarted the PC during the bios update because it seems blocked
                    • 25649
                    Post the model number, motherboard etc. The laptop/PC serial number , SNID or service tag must be posted with every bios request -> https://www.badcaps.net/forum/troubl...before-posting
                    • CirebeaTiberiu
                      CirebeaTiberiu commented
                      Editing a comment
                      Lenovo Legion T5-26AMR5 Desktop. Motherboard T550 MB AMDP19ME2 Ver 1.2
                    • Sparo
                      Sparo commented
                      Editing a comment
                      CirebeaTiberiu Only the serial number is left as mentioned above and you're good to go 😁
                  • hobostove
                    • May 2023
                    • 79
                    Hey guys,
                    I had one of these come in today with the same "BiInitializeLibrary failed 0xc0000001" and "0135 fan error" issues. I flashed a BIOS straight from Lenovo (probably the same as SMDFlea posted above) and that fixed the issue. It now boots into Windows and doesn't have the fan messages.
                    Could someone give me a hand with the DMI stuff? I'm way out of practice and the help would be very appreciated. I've attached the backup and the original Lenovo BIOS I have flashed currently.
                    Thanks!
                    Machine Type: 90R8
                    Product: Lenovo Legion T5 26AMR5
                    MTM: 90RB001LUS
                    SN: MJ0G09BT
                    MO: MJ9021A26969
                    MB#: T550
                    • geeksmart
                      geeksmart commented
                      Editing a comment
                      hola consulta como lo flasheaste con adaptador ???1.8v
                  • Sparo
                    Quicksilver
                    • Jan 2022
                    • 5444
                    • M\A
                    • Anime, Edge Computing, Football, Snooker
                    Originally posted by hobostove
                    Hey guys,
                    Thanks!
                    Machine Type: 90R8
                    MTM: 90RB001LUS
                    SN: MJ0G09BT
                    MO: MJ9021A26969
                    MB#: T550
                    Hi Master Yi x) Try this see if it works
                    Enjoying our forum? Subscribe to unlock extra perks!
                    >> Upgrade here <<
                    šŸš€šŸ’¬šŸš€
                    • hobostove
                      • May 2023
                      • 79
                      Worked absolutely perfect. Thanks Sparo!
                      • Sparo
                        Sparo commented
                        Editing a comment
                        You're Welcome!
                    • sencha
                      • Sep 2020
                      • 6
                      • Ireland
                      Did anyone succeed in unlocking advanced menu (like ram speed setting, etc) ?
                      • Sparo
                        Quicksilver
                        • Jan 2022
                        • 5444
                        • M\A
                        Hi, maybe post the Serial Number, Machine Type and a BIOS dump so users know exactly which machine you're talking about
                        (although I doubt unlocking it is possible because of Boot Guard protected sections)
                        >> Upgrade here <<
                        šŸš€šŸ’¬šŸš€
                        • JoshCER
                          Lenovo Legion T5 26AMR5 (90RB001LUS) - Powers on but no POST / no display - BIOS dump attached
                          by JoshCER
                          I've got a Lenovo Legion T5 26AMR5 (MTM 90RB001LUS, SN MJ0FTYZZ) on the bench that's giving me a bit of a headache.
                          The machine powers on normally. All fans spin, RGB comes on, and everything looks like it's starting up, but there's no display and no POST. It just sits there powered on.
                          So far I've swapped in known-good:
                          • CPU
                          • GPU
                          • RAM
                          • PSU
                          The behavior is exactly the same with every combination.
                          I've also:
                          • Cleared the CMOS
                          • Tried one RAM stick at a time in different slots
                          • Tested multiple video outputs/GPUs
                          • Looked
                          07-06-2026, 08:43 AM
                        • Do_Yuri
                          Lenovo IdeaPad 3 15ADA05 (81W1) — cannot enter BIOS, system always boots in Legacy mode
                          by Do_Yuri
                          Hello.
                          I’m trying to diagnose a Lenovo IdeaPad 3 15ADA05 (Model 81W1).
                          Hardware
                          Model: Lenovo IdeaPad 3 15ADA05 (81W1)
                          BIOS version: E8CN34WW
                          Internal drive: NVMe SSD (detected normally)
                          Symptoms
                          BIOS Setup is almost impossible to enter.
                          Pressing F2 during power-on usually freezes on the Lenovo logo or is ignored.
                          The Novo button opens the Novo Menu, but selecting BIOS Setup...
                          08-01-2026, 01:58 PM
                        • yellowtiger
                          Lenovo Slim 7i 14IMH9 - Failed BIOS Update and Stuck in Boot Loop - BIOS Request
                          by yellowtiger
                          Hello Everyone,
                          I have a Lenovo Slim 7i 14IMH9 that got stuck in a boot loop with black screen after a failed BIOS update through Lenovo Vantage.
                          Here are my laptop details:
                          - Model: Lenovo Slim 7i 14IMH9
                          - Serial Number: YX09M0K7
                          - Machine type: 83D80003US
                          **Problem:**
                          About two weeks ago a BIOS update for this laptop failed and the laptop has been stuck in a boot loop with black screen ever since. Now when I press the power button, the keyboard lights come on and the fan starts running. However, the screen remains black. The laptop...
                          06-14-2026, 11:04 AM
                        • scailermeerkat0
                          Lenovo Legion S5 Gen 8 (14APH8) - Issues with BIOS Flash in Crisis Mode
                          by scailermeerkat0
                          My Lenovo Legion Slim 5 Gen 8 was unable to post/boot following a failed BIOS upgrade attempt in Lenovo Vantage. As the upgrade installation assistant was running in Windows, the device blue-screened and has not been able to post since.
                          I have attempted to restore the device using Crisis Mode by taking the following steps:
                          1. Identified the crisis recovery file expected name to be macn.bin using this guide
                          2. Downloaded the MACN24WW BIOS installation package from Lenovo's website --> Extracted the installation package --> Renamed the ".fd" file to
                          01-02-2026, 08:08 AM
                        • lucaszmn
                          by lucaszmn
                          Problem:
                          Initial Findings:
                          • I concluded that the
                          08-12-2025, 03:01 PM
