Need unlock HP elitebook 830 G6
  • hoaca388
    Badcaps
    • Jan 2022
    • 11430
    • Viet Nam
    #281
    Originally posted by Wooxic
    hi all, please help me clear me this bios. when you start the computer, Your computer will automatically restart during this process. I couldn't explain the window screen.
    Thank you!!
    830 G6
    S/N : 5CG015105D
    P/N : 7KJ86UT#ABA
    830 G6
    S/N: 5CG015105D
    P/N: 7KJ86UT#ABA
    • vannix
      • Mar 2018
      • 74
      • Italy
      #282
      Originally posted by hoaca388
      ELITEBOOK 830 G6
      4WE10AV
      S/N: 5CG015D4V8
      caps lock blink 5 times, but after win+b key recovery with usb seems ok!! 😃
      many thanks!!!
      i send u pm
      • machystador
        • Nov 2023
        • 9
        • France
        #283
        anyone could help please ?
        Computer is bios locked.
        Below the two dumps 256mb (BIOS) and 128mb (EC) .
        sn: 5CG015G50Z
        sku: 5PE08AV
        HP EliteBook x360 830 G6
        ​thanks
          SMDFlea commented
          Editing a comment
          Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.
      • lapfix
        • Mar 2020
        • 2649
        • my workshop
        #284
        sn: 5CG015G50Z
        sku: 5PE08AV
        ​thanks
        Try and Give Feedback
        • machystador
          • Nov 2023
          • 9
          • France
          #285
          thanks for your answer.
          I guess the file you sent, has been processed by rcunlocker.
          I had already tested it before without success.
          As it did not work, I've tried to restore original bios and ec images to flash memories but...
          I've must have broken something. The symptoms I encounter when I'm connecting laptop battery.
          I don't even need to push start button, and
          no display, no fan, caps lock led stays always ON .
          LED of power plug blinks white at around 2 HZ.
          Any idea ? thanks
          • lapfix
            • Mar 2020
            • 2649
            • my workshop
            #286
            Any idea ? thanks
            NO , i didn't use rcunlocker.did you try my file !
            • machystador
              • Nov 2023
              • 9
              • France
              #287
              Hi
              I've tried your file.
              Laptop LED of power plug now blinks orange.
              No display,
              It does not draw a lot of current (less than 60 ma).
              It is blocked. Nothing happens.
              thx
              • lapfix
                • Mar 2020
                • 2649
                • my workshop
                #288
                Hi
                No display,
                thx
                Sorry
                Flash your Original untouched EC and this main.
                first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                use BCU to write your DMI:​
                • reamon
                  • Aug 2020
                  • 24
                  • United Kingdom
                  #289
                  HP EliteBook 830 G6 CATALONI 6050A3022401-mb-a01
                  Good afternoon colleagues, two bios are needed for this model. The native bios are damaged, the laptop tries to turn on but without result
                  • lapfix
                    • Mar 2020
                    • 2649
                    • my workshop
                    #290
                    Post your damaged bios
                    Post informations : serial number
                    • machystador
                      • Nov 2023
                      • 9
                      • France
                      #291
                      Originally posted by lapfix
                      Sorry
                      thanks for your file.
                      BIOS has restored his configuration from EC settings, but password is still here. No way ton clear it.
                      Native keyboard does not work anymore. I had to use usb keyboard. Not sure there's a link with the fact I've flashed bios modification.
                      • machystador
                        • Nov 2023
                        • 9
                        • France
                        #292
                        Hi, I've finally used another flash memory chip. I've reflashed it with the file you send for EC content (it is the same content with the file I get using rcunlocker. The same tool must be used by LBE++ I suppose).
                        Now it's okay.
                        Problem with keyboard seems linked to flex connector of laptop.
                        Thanks for your help. It's amazing.
                        • bykanovm
                          • Aug 2022
                          • 95
                          • Украина
                          #293
                          Hello everyone. I got a HP Elitbook 830 G6 laptop.
                          The problem is that it doesn't turn on. When I connect the power supply, only the charging indicator lights up orange. There is no response to the button.
                          I found a tested set of EC BIOS and main 16 MB and 32 MB.
                          Flashed 2 chips. After that, the laptop turned on, an image appeared on the screen.
                          The laptop said that the memory was replaced, etc. After that, the laptop turned off and now does not turn on.
                          When connecting the power supply, the power button blinks white, the diode near the power connector blinks orange and white.
                          I suspect that the problem is in the BIOS. I am posting the dumps that I flashed and the original dumps that I saved in advance. I also forgot to clarify that the 32 MB flash drive had already been flashed before me. After I downloaded the firmware from it, it failed. I replaced it with a GD25R256DYIG, and what was mx25l25673G. But the laptop started with the new chip and gave the picture as I described
                          I removed the main 32MB BIOS chip, the blinking of the diodes remained the same, namely the power button quickly blinks 3 times white once a second. The diode near the power connector blinks 3 times orange while it is lit white.
                          I also flashed another BIOS to a 32MB flash drive, now the indicator near the power connector just lights up orange. It even charges the battery, I look at the lab power supply
                          HP Элитбук 830 G6.
                          СН 5CG0155DTF
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11430
                            • Viet Nam
                            #294
                            HP Элитбук 830 G6.
                            СН 5CG0155DTF
                            5CG0155DTF
                            • bykanovm
                              • Aug 2022
                              • 95
                              • Украина
                              #295
                              hoaca388
                              There is no reaction to the button, the orange indicator just lights up. I don't know where to look anymore. It turns out that the laptop turns on once with the set of BIOSes that I posted earlier, not the original.​
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11430
                                • Viet Nam
                                #296
                                hoaca388
                                Find issue problem.
