Flash image tool 16.1
Hello please i need Flash image tool 16.1.exe if someone has it and could upload it thank you
ME Firmware Cleaning Guide
Re: ME Firmware Cleaning Guide
See.. https://youtu.be/a63Lhep3Jz0Last edited by santoslao; 08-20-2023, 05:15 PM.Leave a comment:
Greetings friends, I've been trying to understand how the new way to clean the ME from a bios works for some time, and in this version 16.1.xxx it's quite complex! If anyone knows or can explain it to me I would be very grateful. In the example I use a bios of a dell precision 3571, where I can't even unzip the file, even with the MFIT in the current version of the file or in the previous version according to the error that appears.Leave a comment:
Some motherboards have dual bios chips.FIT can`t work without first joining the bios backups together into one file.
To join two files together you can use a hex editor,file joining software or a batch script that runs from the windows command line.
To make a batch script copy the text without the quotes "" into notepad:
"@ECHO OFF
copy 8MB.bin /B + 16MB.bin /B 8+16MB_Joined.bin /B
pause"
Save the file with any name you like followed by a .bat file extension,for example: Join_8+16MB.bat
When the batch file is run the files named 8MB.bin and 16MB.bin are joined together and a new file is made called 8+16MB_Joined.bin
Both filenames must be renamed to match your own filenames,or you can rename your bios backups to match the script filenames.
Multiple scripts can be made and kept in the same folder.
After cleaning the ME firmware FIT will split the files back again.
.Leave a comment:
.Leave a comment:
Win-raid doesnt exist anymore, how can i get the flash bios tools now? thanks!Leave a comment:
Thank you so much SMDFlea for the great and easy to follow guide.
I am recently trying to clean the ME on Surface Pro 7 (CSME 13), however I am unable to find the "SMIP signning field" in the FIT. The FIT only lists non-zero OEM Public Key and OEM Key Manifest Binary.
I tried to ignore this step, but simply overwritting the ME Sub Partition with a clean one and exporting the bios is not working - the tablet just turns on and off.
Thank youLeave a comment:
Thank you very much, it is very good informationLeave a comment:
Does anyone have the tool to clear ME 16.1.25.1932 ?Leave a comment:
Hi guys
Mentioned in the Win Raid forum
D4. CSME 11 - 15 & CSTXE 3 - 4
15. is the "fptw64 -greset" step unnecessary when writing with a ROM writer?Leave a comment:
by SMDFleaIf you have to clean the ME firmware on **some microsoft surface models the touchscreen can stop working.
** Some models do not need this fix.
*You should install the latest updates from microsoft,including the driver packs before assuming there is a hardware problem.* - See Post #2
EDIT: If nothing else works try this fix - https://www.badcaps.net/forum/showpo...8&postcount=40
Always check a working dump from the same model using FIT.If the working dump default setting for "Integrated Sensor Hub Supported" is set to "NO"...-
Channel: BIOS Requests ONLY!
by Wachenaggoi know a tool https://github.com/MuertoGB/MacEfiToolkit is capable of SN change and Clean ME but not updating EFI Version of the BIN file. is there a guide or a BIOS structure to update the firmware??...03-06-2024, 01:34 AM
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...02-10-2024, 02:07 PM -
by gurj1979Hi guys.
I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
Got New chip and writes good.
THE PROBLEM...
It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
Does anyone have a Good Firmware I can have?...-
Channel: Troubleshooting & Designing Networks
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
- Loading...
