Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
Hello All.
Would someone be able to help me with removing the system password from my Surface Pro 5 1796 please? SN: 023447182053. Board number: M1007506-015. If someone could point me in the right direction I would be so very grateful. I don't understand the AWORD thing?!
Thanks in advanceAttached FilesLast edited by Landy110; 11-23-2023, 03:48 PM.Comment
Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
try thisAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
please remove me bios password Surface pro 5
MODEL: 1796
IC: 3048A-1796
motherboard: M1007506-015
Attached FilesComment
Send to you, try, Merry christmas !!Comment
The password has been removed successfully thank you
I have another device with the same specifications
Does the first file work with it?
SN 072132684853Comment
Hello, can someone help me with the bios, the surface shows the logo for 2 seconds and the screen get black.
Surface pro 5 1796
SN: 008793174853
ThanksAttached FilesComment
Attached Files↵
https://www.badcaps.net/donateComment
Hi. Could you pleas help. Surface shows logo for few seconds and goes black.
Model 1796
Mobo M1007506-5015
SN: 023873573753Attached FilesComment
Pleas if you can check another bios dump if there is trace of failed updated or anything that can prevent surface from booting? Thanks so much.
Surface pro 5
Model 1796
Mobo M1007506-015
SN: 054826391553
Thread merged.
Before making a new thread please read the rules first, so I don't have to move your request at the existing thread again:
You MUST:- Post under a related thread if it exists
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
N° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by AhariHi all,
I...-
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
Channel: BIOS Requests ONLY!
by shadow666hello
i need surface book 3 dump bios
Model : 1899
MB : 1899_TOP
Rev 2.0
Serial : 037248401157
CPU :Core i7-1035G7
Dump Bios problem is no power
Problem is after update windows surface is blue screen after force shutdown , surface won,t turn on
Regard...-
- Loading...
