Dell Latitude 5500 Bios password
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
Re: Dell Latitude 5500 Bios password
It worked great!
Thank you for your work.
I have another laptop like this, also with a Bios password.
Please remove the BIOS password.
LA-G901P, Latitude 5500
Service Tag: 97HN3Z2-8FC8Attached FilesComment
Any donations to Badcaps are welcome. Become a Badcaps supporter >>>>> click this link to donate <<<<< Thank you to all the supporters. -- -------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hello. Can you help me unlock the bios?
Service Tag: BVD55Y2-8FC8
Thank youComment
BIOS guides, methods, resources and tools
https://www.badcaps.net/forum/showthread.php?t=103526
3.4. Dell
Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
See: https://beta.bios-pw.org/ .
Note: The 6FF1 suffix has a bug,use your service tag with the BF97 suffix instead,Example: 1234ABC-BF97
There is no publicly available 8FC8 generator available at the moment.
The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.1. How to dump and flash
1.1. BIOS
BIOS can be updated from software using the manufacturer's tool. It can also often be dumped from software (although not really reliable).
However, if you need to re-flash the BIOS because the computer does not boot and BIOS recovery procedure does not work, you need an external programmer.
Likewise, if you want to modify the BIOS to remove a password, it must be done with an external programmer.
When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
On Windows, you can use the command "fc /b" to check if two dumps are identical.
Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Hi, could you please help me to unlock this BIOS?
Model: Dell Latitude 5500
Board: LA-G901P Rev:1.0
S/N and suffix: 71FJYY2-8FC8
Posting UC5 dump (32mb).
Greetings from Czechia, and thanks a lot!!
TomAttached FilesComment
Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hi, can you help me to unlock this BIOS?
Code: F9QN8Y2-8FC8
Thanks a lot!!Attached FilesComment
But for the future there is also a wonderful script in this forum that anyone can use to do it themselves.
https://www.badcaps.net/forum/showthread.php?t=125468Comment
Here is the unlocked file ...
For next time i use the script!
Hi
Please need to unlock dell latitude 5500
SERVICE TAG HVL92R2Attached FilesLast edited by jags46; 12-06-2023, 09:28 AM.Comment
You MUST post the service tag,please read the rules !
https://www.badcaps.net/forum/troubl...sting?t=103570
Dell 8FC8 Bios Password Patcher
Could someone upload this I need to download it but the links are down
plz read the rulez n post da service tag !
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://badcaps.net/forum/showthread.php?t=88758 )
- Name your thread with model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
Board: LA-G902P Rev:1.0
Code: 48190r2-8FC8
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
This specification for the DELL Latitude 5500 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5500 boardview and 5500 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5500...09-06-2024, 12:13 PM
- Loading...
