Dell Latitude 5500 Bios password
  • hardware1
    • Sep 2021
    • 2887
    • N/A
    #221
    Re: Dell Latitude 5500 Bios password
    Originally posted by StanislavSh
    Hello!
    Please remove the BIOS password.
    As far as I understand, only the 8 MB chip needs to be edited.
    LA-G901P, Latitude 5500
    Service Tag: 7B40Y33-8FC8
    Here is your Unlocked BIOS, hope it works fine.
    all donations are welcome,
    • StanislavSh
      • Sep 2023
      • 3
      • Ukraine
      #222
      It worked great!
      Thank you for your work.
      I have another laptop like this, also with a Bios password.
      Service Tag: 97HN3Z2-8FC8
      • hoaca388
        Badcaps
        • Jan 2022
        • 11160
        • Viet Nam
        #223
        It worked great!
        FFFFf
        Mọi khoản quyên góp cho Badcaps đều được hoan nghênh . Trở thành người ủng hộ Badcaps >>>>> nhấp vào liên kết này để quyên góp <<<<< Cảm ơn tất cả những người ủng hộ . -------------------------------------------------------------------------------------------------------------------------------------------------------------
        • StanislavSh
          • Sep 2023
          • 3
          • Ukraine
          #224
          Originally posted by hoaca388
          FFFFf
          Everything worked out great! Thank you very much!
          • tomas140292
            • Oct 2019
            • 4
            • Ukraine
            #225
            Hello. Can you help me unlock the bios?
            Service Tag: BVD55Y2-8FC8
            Thank you
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #226
              Thank you
              Read the rules before posting:
              BIOS guides, methods, resources and tools
              https://www.badcaps.net/forum/showthread.php?t=103526
              3.4. Dell
              Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
              See: https://beta.bios-pw.org/ .
              Note: The 6FF1 suffix has a bug,use your service tag with the BF97 suffix instead,Example: 1234ABC-BF97
              There is no publicly available 8FC8 generator available at the moment.
              The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
              1. How to dump and flash
              1.1. BIOS
              BIOS can be updated from software using the manufacturer's tool. It can also often be dumped from software (although not really reliable).
              However, if you need to re-flash the BIOS because the computer does not boot and BIOS recovery procedure does not work, you need an external programmer.
              Likewise, if you want to modify the BIOS to remove a password, it must be done with an external programmer.
              When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
              On Windows, you can use the command "fc /b" to check if two dumps are identical.
              Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
              Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665
              Become a Badcaps supporter
              Thanks to all supporters.
              • tritom
                • May 2020
                • Czech Republic
                #227
                Hi, could you please help me to unlock this BIOS?
                Model: Dell Latitude 5500
                Board: LA-G901P Rev:1.0
                S/N and suffix: 71FJYY2-8FC8
                Posting UC5 dump (32mb).
                Greetings from Czechia, and thanks a lot!!
                Tom
                • volinakis
                  • Jan 2021
                  • 2616
                  • N/A
                  #228
                  Tom
                  here
                  • tritom
                    • May 2020
                    • Czech Republic
                    #229
                    Originally posted by volinakis
                    here
                    Great!!! Working right away, thank you
                    • Lunixman
                      • Oct 2023
                      LA-G901P, Latitude 5500 bios location?
                      • volinakis
                        • Jan 2021
                        • 2616
                        • N/A
                        #231
                        see image
                        • Lunixman
                          • Oct 2023
                          see image
                          Thank you the 8mb chip that I will need to modify it right ❤️❤️
                          • dudochnicht
                            • Nov 2020
                            • 25
                            • GER
                            #233
                            Hi, can you help me to unlock this BIOS?
                            Code: F9QN8Y2-8FC8
                            Thanks a lot!!
                            • Markus1741
                              • Sep 2020
                              • 842
                              • N/A
                              #234
                              Code: F9QN8Y2-8FC8
                              Thanks a lot!!
                              Here is the unlocked file ...
                              But for the future there is also a wonderful script in this forum that anyone can use to do it themselves.
                              https://www.badcaps.net/forum/showthread.php?t=125468
                              • dudochnicht
                                • Nov 2020
                                • 25
                                • GER
                                #235
                                Thanks, it works :-)
                                For next time i use the script!
                                • jags46
                                  • Mar 2022
                                  • 10
                                  • República Dominicana
                                  #236
                                  Hi
                                  Please need to unlock dell latitude 5500
                                  SERVICE TAG HVL92R2
                                • jags46
                                  • Mar 2022
                                  • 10
                                  #237
                                  Dell 8FC8 Bios Password Patcher
                                  Could someone upload this I need to download it but the links are down
                                • karemkf
                                  • May 2020
                                  • 21
                                  • egypt
                                  #238
                                  hi i need unlock plz dell 5500
                                    • 20299
                                    plz read the rulez n post da service tag !
                                    https://www.badcaps.net/forum/troubl...sting?t=103570
                                    You MUST:
                                    • karemkf
                                      • May 2020
                                      • 21
                                      • egypt
                                      #240
                                      Board: LA-G902P Rev:1.0
                                      Code: 48190r2-8FC8
                                      • gizaha
                                        by gizaha
                                        02-13-2024, 07:18 AM
                                        DELL Latitude 5500 Notebook 5000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 5500 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5500 boardview and 5500 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5500...
                                        09-06-2024, 12:13 PM
