Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Dell Latitude 5500 Bios password
  • Sparo
    commented on 's reply
    Exactly. In your case, since you don’t have a single 32mb BIOS chip but 16mb + 8mb, always patch the 8mb one only
  • Morpheusnoip
    replied
    It's already solved. I had to 8fc8patch the contents of the 8mb chip. Thanks for the help.
  • Sparo
    look for another 8MB chip and post its contents too
  • Morpheusnoip
    replied
    Hello! I need help with my BIOS password protection.
    Dell Latitude 5500, service tag JF3G9Y2, motherboard LA-G901P rev: 1.0 (A00) locked CF1B bios passworld.
    Thanks.
    Premium supporters get full download access and other benefits.
  • LBTT1121
    replied
    Originally posted by ianbak
    I have a Dell Latitude 5500 (Service Tag C4NR3X2, motherboard LA-G901P) which is locked with an -8FC8 BIOS password.
    I have successfully read and verified the contents of both the 8 and 16 MB BIOS chips (attached).
    Normally I would unlock this myself with the Rex98 Patcher, but with both of these files it says '8FC8 Hex Pattern not Found'.
    Can someone please explain what I might be doing wrong, or unlock the files for me? Thanks!
    take a photo pass 8FC8
  • ianbak
    replied
  • peste
    replied
    Originally posted by xxmcfly
    Can someone please help me with the following code?
    Dell Latitude 5500
    Service Tag: 9LNT2Z2-CF1B
    Express Service Code: 20900818766
    post the original contents of the bios chip..
  • m1ch43lzm
    Moved to Latitude 5500 password topic
  • xxmcfly
    replied
    Dell Latitude 5500
  • reformatt
    replied
    Some versions of these boards have a split BIOS across UC5/UC6 or solely in UC5. If there is only one chip fitted, then BIOS is solely in that chip.
    It's a WSON 8x6 IC, you either remove it with hot air and put in a WSON adaptor or use a POGO style pin clip if you don't want to take it off the board. These are pretty good quality if you want all 4 types.
    https://www.aliexpress.com/item/1005...67831802Q7JQNc
  • NigkonNikki
    replied
    Hello everyone and I hope you all are doing well. I'm trying to patch my bios on this Dell Latitiude 5500, but I'm having issues with locating the BIOS chip on the motherboard. Is the BIOS chip U5, U6 or something else? I'm currently using a programming and U5 is a thin chip with barley enough surface to grab and I do not have U6. Sorry for sounding off, I'm still getting use to comminating on forums. Thank you!
  • e_brandt
    replied
    Originally posted by e_brandt
    Hello, can anybody reset my Password for my Latitude 5500 with winbond chip?
    Sevice tag: 89qwxy2
    Mainboard Vers. LA-G901P
    Cip Winbond W25Q128JV
    I have treied with the Patcher but i dosn`t work. Error: 8FC8 Hex Pattern not Found
    Hello lovelies, my mistake was that I read the wrong eprom uc6 instead of uc5. now I was able to use and program the patcher successfully. Unfortunately, I don't turn on the laptop anymore. When I press the power button, only the orange led comes up at the front. Does anyone have an idea?
    Dell 5500
    Mainboard LA-901-P
    Service Tag DBQWXY2
  • LBTT1121
    replied
    Originally posted by galactici
    Hello everyone, can anyone help me to remove my bios password pls on my latitude 5400.
    The suffix Is 8FC8
    The service code is : H0JSYY2
    post the contents of the bios chip even if it is corrupted..
  • galactici
    replied
    The suffix Is 8FC8
  • e_brandt
    replied
    Sevice tag: 89qwxy2
  • nefaa.ben.jeddou
    replied
    Originally posted by nefaa.ben.jeddou
    thx for replay but patcher not working "8FC8 Hex Pattern not Found" in tow dumps
    thx for your help problem solved with new rebuild of dump
    what suffix does it show at the password screen
  • nefaa.ben.jeddou
    replied
    replied
    hi
    can any one help to unlock bios for Dell Latitude 5500
    EDC50 LA-G901P
    Service TAG: 4NXJX33
    Use the patcher - https://www.badcaps.net/forum/troubl...rces-and-tools
  • nefaa.ben.jeddou
    replied
    hi
    EDC50 LA-G901P
  • TopPop
    Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
    by TopPop
    Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
    I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
    12-14-2025, 09:40 PM
  • Godfather79
    Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SouthPeak15) bios
    by Godfather79
    Hello everyone in the community
    Dear Sir,
    I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
    Problem details:
    * Model: Dell Latitude 5520.
    * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
    * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
    * Service Tag: (Enter your actual Service Tag from the laptop here)
    * BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
    11-08-2025, 10:04 AM
  • Godfather79
    Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15)
    by Godfather79
    Dear Sir,
    Problem details:
    * Service Tag: (HMHJQ93)
    What I need:
    Please help me generate...
    12-02-2025, 07:13 AM
  • gizaha
    by gizaha
    02-13-2024, 07:18 AM
  • Boardview and Schematic Bot
    DELL Latitude 5500 Notebook 5000 Specification for Upgrade or Repair
    by Boardview and Schematic Bot
    This specification for the DELL Latitude 5500 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5500 boardview and 5500 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5500...
    09-06-2024, 12:13 PM
