Dell Latitude 5500 Bios password
  • lapfix
    • Mar 2020
    • 2769
    • my workshop
    #161
    Re: Dell Latitude 5500 Bios password
    Originally posted by totorona
    ok i have dell 5500 i whant help for unlok bios please
    Upload your original bios file
    • totorona
      • Apr 2023
      • 5
      • albanie
      #162
      Please give me step
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria đŸ‡§đŸ‡¬
        #163
        please give me step
        Аgain:
        Originally posted by vesko356
        rules update for bios requests/offers *avoid banning, read before posting*:
        Originally posted by piernov
        — you are requesting help
        if you do not abide by the following rules, your post will be deleted.
        you must:
        Become a Badcaps supporter
        Thanks to all supporters.​
        • totorona
          • Apr 2023
          • 5
          • albanie
          #164
          Originally posted by Vesko356
          Аgain:
          i searh but is complex for me . i whant say if possible to remove dor me model XXXXXXXXX-8FC8 ?
          3.4. Dell
          Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
          See: https://beta.bios-pw.org/ .
          Note: The 6FF1 suffix has a bug,use your service tag with the BF97 suffix instead,Example: 1234ABC-BF97
          There is no publicly available 8FC8 generator available at the moment.
          The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
          where is this information
          • lapfix
            • Mar 2020
            • 2769
            • my workshop
            #165
            3.4. Dell
            At least , what are you searching for here !!
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria đŸ‡§đŸ‡¬
              #166
              3.4. Dell
              • totorona
                • Apr 2023
                • 5
                • albanie
                #167
                this ans
                Last edited by Vesko356; 04-29-2023, 11:21 AM. Reason: Editing of unnecessarily large quote font size.
                • lapfix
                  • Mar 2020
                  • 2769
                  • my workshop
                  #168
                  this ans
                  Do you have a hot air , programer and twiser
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria đŸ‡§đŸ‡¬
                    #169
                    this ans
                    Again (third time), read carefully all the information in the topics I have already pointed out! Most of the questions (if not all) are answered in these threads. No one has the intention (or time) to tutor you personally here in this thread, your questions are starting to get off-topic here. Also, try to write in a literate and respectful manner, writing in slang style like "ans" and so on are not allowed. I warn you one last time!
                    1. How to dump and flash
                    1.1. BIOS
                    BIOS can be updated from software using the manufacturer's tool. It can also often be dumped from software (although not really reliable).
                    However, if you need to re-flash the BIOS because the computer does not boot and BIOS recovery procedure does not work, you need an external programmer.
                    Likewise, if you want to modify the BIOS to remove a password, it must be done with an external programmer.
                    When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
                    On Windows, you can use the command "fc /b" to check if two dumps are identical.
                    Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
                    Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665
                    • ahmedelwn
                      • Oct 2022
                      • 27
                      • egypt
                      #170
                      5500 Bios password UN PASS SER thanks
                      thanks
                      • farouk_1994
                        • Mar 2021
                        • 405
                        • algeria
                        #171
                        Re: 5500 Bios password UN PASS SER thanks
                        thanks
                        Try and replay
                        • ahmedelwn
                          • Oct 2022
                          • 27
                          • egypt
                          #172
                          Originally posted by farouk_1994
                          Try and replay
                          Thank you my friend it works
                          • ahmedmoussaa
                            • Nov 2016
                            • France
                            #173
                            please
                            can you unlock this bios
                            • aldopc
                              • Jul 2017
                              • 490
                              • Chilito
                              #174
                              Originally posted by ahmedmoussaa
                              please
                              Ready Bro
                              • interpc
                                • Feb 2015
                                • 74
                                • Mexico
                                #175
                                Originally posted by aldopc
                                Ready Bro
                                please help to unlock
                                thanks
                                • volinakis
                                  • Jan 2021
                                  • 3045
                                  • N/A
                                  #176
                                  thanks
                                  1st boot press F2, write Service Tag, disable Absolute, save, restart, 2nd boot press alt+F to exit factory mode.
                                  please support this forum
                                  • paul13
                                    • Jul 2020
                                    • 12
                                    • ukraine
                                    #177
                                    please unlock my bios
                                    • lapfix
                                      • Mar 2020
                                      • 2769
                                      • my workshop
                                      #178
                                      1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.Good luck.
                                      All donations to badcaps are welcome, click on this link to donate via PayPal. Every donation made will go towards server fees and maintenance costs.
                                      • igor-n
                                        • Jun 2023
                                        • Ukraine
                                        #179
                                        Here is the dump of Winbond 25Q256JV (Dell Latitude 5500).
                                        tried replacing me-region. laptop shuts down after 5 seconds
                                        Could you help me to unlock it, please ?
                                        Thx in advance.
                                        • lapfix
                                          • Mar 2020
                                          • 2769
                                          • my workshop
                                          #180
                                          Thx in advance.
                                          • TopPop
                                            Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                            by TopPop
                                            Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                            I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                            12-14-2025, 09:40 PM
                                          • Godfather79
                                            Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15)
                                            by Godfather79
                                            Hello everyone in the community
                                            Dear Sir,
                                            I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                            Problem details:
                                            * Model: Dell Latitude 5520.
                                            * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                            * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                            * Service Tag: (HMHJQ93)
                                            * BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt.
                                            What I need:
                                            Please help me generate...
                                            12-02-2025, 07:13 AM
                                          • Godfather79
                                            Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                            by Godfather79
                                            Dear Sir,
                                            Problem details:
                                            * Service Tag: (Enter your actual Service Tag from the laptop here)
                                            * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                            11-08-2025, 10:04 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                            DELL Latitude 5500 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5500 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5500 boardview and 5500 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5500...
                                            09-06-2024, 12:13 PM
