LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
@Ariu
Try
Rewrite only the uc8m1
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for...Attached FilesComment
I will try it now and I report...Comment
Unfortunately no post, It keeps restarting now after 10 seconds in a loop .
I waited more than 2 minutes but the same....Comment
how do u patch the file because i am getting always BIN is corrupted or does not contain a valid dump. when i try to patch...Comment
here is my own uc8m1 original backup, but it is corrupted, can u perhaps take a look if u can repair it...Last edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
Because the thread here is just for help to patch a locked bin file and not to repair a corrupted dump...
For this I thought nobody can help here and decided to open a new thread to include both possible problems...Comment
Ah ok,heres the fixed bios
The ME firmware was corrupt,it still needs patching.
thank u i tried it already and now my own backup is working , but u had right it still needs to be patched... password still there.
the problem is that i cannot patch it i get always error that the file is corrupt or invalid...
.Comment
I'm new here and just getting my feet wet. I noticed that the instructions imply that the eprom be soldered to the MB. Is this absolutely necessary? I had a locked mb but I unfortunately broke a lead off of the chip removing it. No problem, I just desoldered the epprom from another MB from exactly the same model the as my locked patient a Yoga X1 1st gen. However, this unit had issues that CN easily be resolve and it was not locked. I de-soldered the chip (successfully) and was able to get a verified bin file using flashrom and diff. Can I just flash it using your utility or do I need to solder it to the receiving mb?
TIA,
TGigabyte Tuf Gaming X570-PLUS
AMD Ryzen 7 2700X Eight-Core Processor
16GB SkilSaws
1 1TB SHGP31-1000GM-2 nvme
1 1TB 3.5" Spinner
Nvidia GeForce GTX 1660 SUPER/PCIe/SSE2Comment
UC8M1 and UC8M2 fixed .It still needs patching.Last edited by SMDFlea; 11-25-2021, 04:00 PM.Comment
Sry, didn't read all topic first) i figure out the trick at STEP 5 and finally unlock thinkpad t580 sup! thanks a lot!!!
But now i have a problems with Thinkpad T590. After booting notebook with patched BIOS it doesn't stop beeping and doesn't show any pre-bios screen. I tried remove hard disk or hold the anti-tamper switch, but still the same, continuous beeps. Any ideas?
Here my original backup, in case i patched it wrongLast edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
@korhy
Starting with most 9th Generation ThinkPad models Lenovo introduced the Self-Healing bioses, then bios chip has a backup of bios (32MB), meaning that if you patch both copies, laptop won’t POST, won’t boot; if you patch second copy it will Self-Heal upon powering up the laptop and recover itself with unmodified bios; if you patch first bios copy I believe nothing will happen, it will work as normal booting from second bios copy.
What you need is a EC/KBC programmer (supposing Supervisor Password is SET), a programmer such as Vertyanov JIG or similar, but is advisable to first check what’s the EC/KBC chip part number to ensure programmer compatibility.Last edited by AAAC; 11-26-2021, 11:21 AM.Comment
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
