  • Cunninghood
    • Jun 2020
    • 21
    • Singapore
    #41
    This is the patched file using python27.
    Could you help me try patching it using your setup? T460.bin is the original file.
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1521
      • France
      #42
      your file t460 patched 32 mo
      my ori t460 patched 16mo
      very weird
      I don't understand why your file is 32mb while mine of the same model (t460) is only 16mb
      • Cunninghood
        • Jun 2020
        • 21
        • Singapore
        #43
        Thank you so much. Yes this is weird, might need knucklegrumble to enlighten
        • Cunninghood
          • Jun 2020
          • 21
          • Singapore
          #44
          Oh wait, you mean you tried to patch my original file, but it is showing 32mb too right.
          Mmmmm.... I tried to patch using manual replacement of "lenovotranslate" and "bootoption", my machine can power on, but there is no display.
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1521
            • France
            #45
            yes if I patch your file, it is 32mb.
            and if I take one of mine it is 16mb.
            you can try my patch file for your machine that should unlock the Password.
            there is something else to modify than boot and translate for this model.
            nvram must also be cleaned up
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1521
              • France
              #46
              read the original several times to be sure of your reading
              • Cunninghood
                • Jun 2020
                • 21
                • Singapore
                #47
                Thanks for enlightenment
                How do I go about clearing the nvram?
                • Cunninghood
                  • Jun 2020
                  • 21
                  • Singapore
                  #48
                  Also other than clearing the nvram, what else do I need to do?
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1521
                    • France
                    #49
                    you have to compare the files to find out how to patch them.
                    all the keys are in the patch
                    • Cunninghood
                      • Jun 2020
                      • 21
                      • Singapore
                      #50
                      If not too tough, can you guide me? If it is a cumbersome process then forget it. Appreciate ur reply
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1521
                        • France
                        #51
                        the explanation is in the discussion thread.
                        look at message # 19 and in other topics like Remove_SMM ... UEFI.
                        The best learning is to learn and understand on your own
                        read the topics and come back if you don't understand
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1521
                          • France
                          #52
                          Originally posted by earthoo7
                          same issue with t560 t570.
                          j'ai vu le probleme ,je vais regardé ca ,pourquoi ca fonctionne pas
                          I saw the problem, I'm going to look at it, why is it not working
                          • Knucklegrumble
                            • Jun 2020
                            • 78
                            • US
                            #53
                            Sorry guys I did not have time to look at your files. I'm going to test them and let you know what I come up with as soon as I can.
                            • Cunninghood
                              • Jun 2020
                              • 21
                              • Singapore
                              #54
                              thank you maxpower and knucklegrumble
                              • Knucklegrumble
                                • Jun 2020
                                • 78
                                • US
                                #55
                                OK... I found the reason why your file was doubling in size.
                                I rewrote the cleaning step of the script and modified the process. It should work as intended now.
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1521
                                  • France
                                  #56
                                  good job thanks
                                  • Cunninghood
                                    • Jun 2020
                                    • 21
                                    • Singapore
                                    #57
                                    Thank you!
                                    • Bonzas
                                      • 475
                                      • Indonesia
                                      #58
                                      Tried your script with python 2 give me error, but ok using python 3. i use windows. first attempt with locked spv password X250 success, but i need to press small button on the buttom.
                                      • Cunninghood
                                        • Jun 2020
                                        • 21
                                        • Singapore
                                        #59
                                        Hi Knucklegrumble,
                                        It worked on the old laptop, but I tried on another laptop, also T460, and it couldnt work again
                                        I manually patched it already.
                                        However, if you are interested, I have attached the bios dump of the new laptop.
                                        That being said, really appreciate your automated file! It really saves alot of time and effort
                                        • Knucklegrumble
                                          • Jun 2020
                                          • 78
                                          • US
                                          #60
                                          If I could have the script press the button for you I would... There are limits to what technology can do for now...
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • TopPop
                                            Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                            by TopPop
                                            Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                            I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                            12-14-2025, 09:40 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                          • Deniz
                                            IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
                                            by Deniz
                                            Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
                                            I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
                                            I had the BIOS cleaned, but the issue was not resolved and there was still no image.
                                            Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
                                            After that, I tried to update the...
                                            01-27-2026, 06:56 AM
