Dell E5570 - Bios / Clean ME ADM80 LA-C642P R1.0
That is because it has the same dell OEM configuration as your bios. If you go to the dell support site and view your product spec it has vPro with AMT enabled.
Try an older version, post #5 https://www.badcaps.net/forum/troubl...st#post1752856 ,and try via HDMI as well
Thanks.โAttached FilesComment
Yes, it's fine, I managed to clean the region, it starts up much faster now. However, I had the choice between two region files (see photo). I didn't know what NPDM and YPDM corresponded to. I took the first one, it works perfectly. I'll upload the clean dump to see.
Thanks.
https://winraid.level1techs.com/t/in...ols-2-15/30719
Power Down Mitigation (PDM):
At CSME v11 LP firmware, make sure to mind the PDM status which is distinguished between YPDM (Yes) and NPDM (No). PDM is some sort of erratum, which is only relevant to 100-series PCH-LP systems. Thus, it is an attribute of every CSME v11.0 - v11.8 firmware which supports 100-series PCH-LP systems. The PDM status of a firmware can be detected by ME Analyzer by loading either your SPI/BIOS image (Flash Descriptor + Engine + BIOS) or an Engine Firmware Recovery image which can be generated via FWUpdate tool parameter "-save recovery.bin".โComment
i have this bios not working
can clear me Region or fix itAttached FilesComment
try and feedbackAttached FilesComment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, ๐ ๐ ๐ ...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... - Loading...
